| New Reply |
Where is the center of the universe? |
Share Thread | Thread Tools |
| Jan25-12, 02:35 PM | #103 |
If the universe is homogenous, then at which ever point you stand, the result should be the same. Constant expansion, rewound to a denser universe 13.7 billion years ago. This leads to the conclusion that 13.7 billion years ago the entire sha-bang was bound up together. In fact, playing with the expansion rate and altering the age shouldn't make any difference. It all starts at the big bang, not just our observable bit.
| Jan25-12, 03:10 PM | #104 |
| Jan25-12, 03:36 PM | #105 |
Anyway, expansionm age and density imply a significantly smaller universe, which we seem to both agree on. |
| Jan25-12, 03:43 PM | #106 |
| Jan25-12, 05:15 PM | #107 |
| Jan25-12, 06:56 PM | #108 |
So your question about the size of the BB and if it popped into existence should be reworded as the size of the Universe and such. And our only answers are: "We don't know" |
| Feb7-12, 08:17 AM | #109 |
On sci channel, Nikodem Poplawski. Google him and check it!!! This feller also thinks the center of our universe, when found, will be a black hole from which our universe was "puked" and, in my own opinion, still is puking"!! Peace Brothers and Sisters!!!!!
| Mar16-12, 11:30 AM | #110 |
You really can't tell. If everything was energy, then you could just trace the straight line back to the source, but due to matter which has gravity, then light becomes curved and all jumbled up till you really can't find the center or origin
| Mar16-12, 11:50 AM | #111 |
| Mar16-12, 11:53 AM | #112 |
| Mar16-12, 06:57 PM | #113 |
Fair enough, I stand corrected!
| Mar26-12, 09:07 PM | #114 |
| Mar27-12, 04:30 AM | #115 |
maybe there is no middle.
could it be at any point anywhere. we have in our mind that the first action of reaction must mean the middle but in my mind there is no middle in anything |
| Mar27-12, 07:06 AM | #116 |
| Apr8-12, 06:29 AM | #117 |
I have read most of the discussion up to date and believe that the question of the whereabouts of the centre of the universe is in danger of joining such topics as religion, politics and global warming by manmade carbon dioxide emissions, in that we are unlikely to get to the bottom of the question. The answer might be found at the end of the scientific process, which requires observation and theory: that is observations are made and a theory formed to explain them. Further observations are made and as long as the observations support the theory, we may have more confidence in the theory, but if observations contradict the theory we should be ready to discard or at least modify the theory.
A relevant observation to the question is the Hubble result, namely, that the further away a galaxy is, the faster it is moving from us. A theory (or analogy), which will also help, is the balloon model of the universe (used also by Stephen Hawking in explaining his Big bang theory). Debris (or galaxies) originating from the Big Bang is contained in the skin of the balloon model. The skin moves away from the point of Big Bang (or centre of the universe) at a speed (estimated with the Hubble constant), which we can denote as V. Now, a galaxy, which is diametrically opposite our observational point in terms of our approximately spherical balloon model will also be moving at V from the point of Big Bang, but in the opposite direction, with resultant parting velocity of 2V. Other galaxies on the skin will be closer and the parting velocities will be less than 2V because they will be made up of the observer's velocity plus a component of the observed galaxy's velocity. To make this clearer consider the special case of a plane through the centre of the balloon universe, and intersecting the observer's point and the diametrically opposite observed galaxy. The plane will also intersect other galaxies around the skin. On this plane the parting velocities (Pv) between the observer and the observed will be given by: Pv = V(1+ cosθ) (1) where θ is the angle between the diameter of the balloon universe, (a diameter which intersects the observer) and the line of inclination (or declination) of the observed galaxy. From (1) it is seen that the parting velocities of all the galaxies will vary from 0 to 2V as theta varies from pi/2 to - pi/2. To locate the direction of the universe's centre is now a simple task: just find the direction of the most red-shifted galaxy i.e. the one with the maximal Pv and this line will intersect the centre of the universe. The distance of the centre of the universe along this line, apart from being approximately half way, could be estimated using age of the universe times the estimate for V. This outline of where the centre of the universe is uses existing robust theories and observations with a little thinking. |
| Apr8-12, 07:08 AM | #118 |
Bill Crean, your post is nonsense. That the universe has no center is observational fact, not theology and you misunderstand the baloon analogy.
| Apr8-12, 09:28 AM | #119 |
From Earth? You will find Earth is the centre of the universe. From Andromeda? You will find Andromeda is the centre of the universe. From M247? You will find M247 is the centre of the universe. The observations will be the same no matter where you are. Each point of observations will reveal a spherical observable universe equidistant in all directions, with highest red shift at its farthest points. How does your explanation work now? |
| New Reply |
| Thread Tools | |
Similar Threads for: Where is the center of the universe?
| Thread | Forum | Replies | ||
| Center of the universe | Cosmology | 62 | ||
| Center of the Universe | Special & General Relativity | 7 | ||
| The Center of the Universe | Cosmology | 55 | ||
