New Reply
∫dx/((x^(2/3)(x+1)), integrated over [0,∞]
Share Thread Thread Tools
Feb5-12, 09:10 PM   #1
1. The problem statement, all variables and given/known data
As in thread title.
2. Relevant equations
Residue Theorem.
3. The attempt at a solution
I just need help figuring out the circle C I'll be using. Suggestions?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Feb6-12, 04:06 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Retired Staff Staff Emeritus
What does the presence of z2/3 tell you?
Feb6-12, 09:14 AM   #3
Quote by vela View Post
Other than that there's a pole at z=0?
Feb6-12, 10:03 AM   #4
Recognitions:
Yes, other than that. In particular, what's the effect of the fractional power?
Feb6-12, 10:27 AM   #5
Change the distance between z and the origin from r to r2/3
Change the angle between z and the x-axis from ø to 2ø/3
Feb6-12, 10:53 AM   #6
Recognitions:
Right. Do you know what a branch point and a branch cut are?
Feb6-12, 12:00 PM   #7
Yeah, I somehow need a loop that avoid z=-1 and z=0. Right?
Feb6-12, 12:03 PM   #8
Recognitions:
It's more that you want to avoid crossing the branch cut than avoiding z=0, and you obviously want a piece or pieces of the contour to correspond to the original integral.
Feb6-12, 12:22 PM   #9
So I'd take R>1 and make a half circle of radius R in the upper half of the plane. Then I'd make two little half circles that jump over z=-1 and z=0. Then I'd look at ∫C f(z)dz as the sum of several integrals, one of which can written as a real-valued integral and see what happens as R→∞ and the radii of the little half circles go to zero. Right?
Feb6-12, 12:36 PM   #10
Recognitions:
No, that's too complicated. Take a look at http://en.wikipedia.org/wiki/Methods...93_branch_cuts.
Also, rewrite the integrand as
$$\frac{z^{1/3}}{z(z+1)}$$to make it clear how to calculate the residue at z=0.
Feb6-12, 12:42 PM   #11
So in my case the path should resemble a backwards Pacman?
Feb6-12, 02:16 PM   #12
Recognitions:
Doesn't the answer to that question depend on which way Pacman is moving?
Feb6-12, 05:21 PM   #13
I forgot that PacMan is in perpetual motion.
But yeah, how am I gonna do this? I need C to be formed from a series of paths, each of which will have a line integral that approaches a real value after I take some limit.
Feb6-12, 06:04 PM   #14
Recognitions:
Start by taking the keyhole contour and break it into four pieces and evaluate the line integral for each piece.
Feb6-12, 06:24 PM   #15
How would that work? I want ∫f(x)dx (integrated on [0, R]) to be one of the four line integrals.
Feb8-12, 02:47 PM   #16
Recognitions:
That's what you're supposed to figure out. Did you understand the example on Wikipedia? That's pretty much the recipe you want to follow.
New Reply
Thread Tools
Similar Threads for: ∫dx/((x^(2/3)(x+1)), integrated over [0,∞]
Thread Forum Replies
Estimate ∫γ dz/(1 + z^4) as R→∞. Calculus & Beyond Homework 1
∫∫ x^2 dA ; bounded by ellipse Calculus & Beyond Homework 6
[math analysis] sup f< sup g==>∫f^n<∫g^n Calculus & Beyond Homework 3
E(X) < ∞ ? What does it mean? Set Theory, Logic, Probability, Statistics 19
[SOLVED] Does 0/0 and ∞/∞ = 1 ? Precalculus Mathematics Homework 23
