New Reply
Distance spring decompresses when friction is involved
Share Thread Thread Tools
Feb9-12, 02:52 PM   #1
1. The problem statement, all variables and given/known data
A block of mass m = 4.30 kg slides along a horizontal table with speed v0 = 8.50 m/s. At x = 0 it hits a spring with spring constant k = 68.00 N/m and it also begins to experience a friction force. The coefficient of friction is given by μ = 0.200. How far did the spring compress when the block first momentarily comes to rest?
m=4.30 kg
vo=8.50m/s
k=68.00N/m
μ=.200
x=?
2. Relevant equations
Kf-Ki=W
K=1/2mv2
Fs=-kx
Ffric=μNf
W=Fd
3. The attempt at a solution
First I found the work of the whole system (friction and spring forces) by using
Kf-Ki=W.
For the initial kinetic energy, I used
K=1/2mv2=155J.
For the final kinetic energy, I used 0, because I'm measuring the distance after the mass came to a stop. So, plugging the numbers into the Work equation, I simply get
W=-155J
I'm pretty sure I'm on the right track so far?
Then, using
W=Fd (just multiplying the forcexdistance because both vectors are in the same direction)
I plugged in:
W=(-kx+μNf)x
I work it out to a quadratic by plugging the numbers in...
-68x2+8.44366x+155=0
I solve then for x (using the quadratic root finder on my calculator, so I'm not screwing up the quadratic..), but both of the answers it gives me are incorrect..
What am I doing wrong? Help please!!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Feb9-12, 02:59 PM   #2
Mentor
Quote by becky_marie11 View Post
Then, using
Careful: That only works when the force is constant. The spring force is not constant.
Hint: What's the energy stored in a compressed spring?
Also: Careful with signs. The work done on the mass by both the spring and the friction force is negative.
Feb9-12, 03:03 PM   #3
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
hi becky! welcome to pf!
isn't it 1/2 kx2 ?
Feb9-12, 03:20 PM   #4
Quote by tiny-tim View Post
isn't it 1/2 kx2 ?
W = ∫Fdx (F dot dx, technically)
Fspring = kx
W = ∫kxdx
Wspring = kx2/2
Just to show where it came from, since W does NOT equal Fx, that is not a definition, it is a derivation of work for a constant force.
Feb12-12, 12:23 AM   #5
Thank you guys! I finally figured out the right answer! But when I solve for the quadratic equation, why is the distance vector only distributed to the friction force? This is what I tried to do...
W=(-1/2kx^2+friction force)*x
and this is what is right...
W=-1/2kx^2+friction force*x
Is it because the work of the spring is already in terms of "work" and the friction force isn't?
Feb12-12, 02:49 AM   #6
Recognitions:
hi becky!
yes!!
work done is force "dot" distance, and 1/2 kx2 is 1/2 kx (average force) times x (distance)!
Feb13-12, 05:25 PM   #7
Thank you!!!
New Reply
Tags
force, friction, kinetic energy, spring, work
Thread Tools
Similar Threads for: Distance spring decompresses when friction is involved
Thread Forum Replies
Conservation of Energy involved with a spring and two blocks and a pulley. Introductory Physics Homework 2
What gas's temperature increases as it decompresses? General Physics 7
Power as a function of height (gravity and spring involved) Introductory Physics Homework 0
Finding kinetic coefficient of friction (pulley involved) Introductory Physics Homework 1
Forces involved in spring-pulley system Introductory Physics Homework 6
