Question about PDE solution
by vibe3
Tags: solution
vibe3
vibe3 is offline
#1
Feb15-12, 12:39 PM
P: 23
I am trying to solve the following equation in spherical coordinates:
[tex]
\left( \nabla f \right) \cdot \vec{B} = g
[/tex]
where [itex]g[/itex] is a known scalar function, [itex]\vec{B}[/itex] is a known vector field, and [itex]f[/itex] is the unknown function.
I think the best way to approach this is to expand everything into a spherical harmonic basis:
[tex]
f(r,\theta,\phi) = \sum_{lm} f_{lm}(r) Y_{lm}(\theta,\phi)
[/tex]
[tex]
g(r,\theta,\phi) = \sum_{lm} g_{lm}(r) Y_{lm}(\theta,\phi)
[/tex]
[tex]
\vec{B}(r,\theta,\phi) = \sum_{lm} \left[ B_{lm}^r(r) \vec{Y}_{lm} + B_{lm}^{(1)} \vec{\Psi}_{lm} + B_{lm}^{(2)} \vec{\Phi}_{lm} \right]
[/tex]
where [itex]\vec{Y}_{lm}, \vec{\Psi}_{lm}, \vec{\Phi}_{lm}[/itex] are the vector spherical harmonics (VSH) defined here:
http://en.wikipedia.org/wiki/Vector_spherical_harmonics
Then, to evaluate the dot product between [itex]\nabla f[/itex] and [itex]\vec{B}[/itex], it is necessary to integrate over the unit sphere since the VSH orthogonality relations are defined in terms of integrals over [itex]d\Omega[/itex].
So, integrating the original equation over [itex]d\Omega[/itex] will yield the following ODE equation for the unknown [itex]f_{lm}(r)[/itex]:
[tex]
B_{lm}^r(r) \frac{d}{dr} f_{lm}(r) + \frac{l(l+1)}{r} B_{lm}^{(1)}(r) f_{lm}(r) = c_{lm} g_{lm}(r)
[/tex]
with
[tex]
c_{lm} = \int d\Omega Y_{lm} e^{-im\phi}
[/tex]
This ODE should be straightforward to solve numerically. However, my question is the ODE equation will determine [itex]f_{lm}[/itex] values which satisfy the equation:
[tex]
\int d\Omega \left( \nabla f \right) \cdot \vec{B} = \int d\Omega g
[/tex]
Is it true that these [itex]f_{lm}[/itex] will also satisfy the original equation?
Phys.Org News Partner Science news on Phys.org
Cougars' diverse diet helped them survive the Pleistocene mass extinction
Cyber risks can cause disruption on scale of 2008 crisis, study says
Mantis shrimp stronger than airplanes
hunt_mat
hunt_mat is offline
#2
Feb16-12, 04:52 PM
HW Helper
P: 1,585
My first choice of solution method would be method of characteristics, take a 2D case and you can easily see how this works and you can generalise to 3D case.
vibe3
vibe3 is offline
#3
Feb16-12, 04:58 PM
P: 23
Yes its true that the method of characteristics could work, however I am solving this equation numerically on a 3D grid in spherical coordinates. Integrating along characteristic curves would add complexity in that I'd have to pick lots of different starting points for the integration to get a decent grid of solutions, and then interpolate those solutions back to a spherical grid.
I think the spherical harmonic approach is more elegant and natural for this problem....if only the method I've described above is sound.
meldraft
meldraft is offline
#4
Feb16-12, 05:46 PM
P: 280
Every time you separate your variables, the resulting functions satisfy the original equations on their own only under special conditions (the obvious one being the other function being equal to 1). As far as I know, it is not something you can generalise.
Register to reply
Related Discussions
question Ax = 0 has only trivial solution and Ax = b has 1+ solution for every b Linear & Abstract Algebra 2
Please I want a solution to this question?? Introductory Physics Homework 2
Question about solution Calculus & Beyond Homework 1
a question regarding a new solution .. Calculus & Beyond Homework 6
