| New Reply |
Quartiles of ungrouped data |
Share Thread | Thread Tools |
| Feb25-12, 09:46 AM | #1 |
From the question, is the way to find Lower Quartiles and Upper Quartiles correct? I have seen books taking the 3rd and 8th (from the question) as Lower Quartiles and Upper Quartiles respectively. Which should be the correct Quartiles?
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Feb25-12, 05:02 PM | #2 |
[itex]P[X < x] \leq k/n; P[X\geq x] \geq 1 - (k/n)[/itex] So by the first inequality if x is ranked 5th highest point out of 100 data points, then k=95 and P=0.95 which is the 95th percentile. It seems you want the upper quartile (top 25%), and lower quartile (bottom 25%) . The meaning of the term 75th percentile is that 75% of all data points are less than the lowest data point of the upper quartile. |
| Feb25-12, 07:19 PM | #3 |
Based on the attachment http://www.physicsforums.com/attachm...5&d=1330184818, is this the correct way to interpret quartile?
| Feb25-12, 08:51 PM | #4 |
Quartiles of ungrouped dataIf you type out what you're doing, I can tell you more, You seem to be doing it correctly. For an even number of values, some people use k+1, as you have, so quantile boundaries do not fall on data points. The value of your median is then 5.5 and the quartile boundaries would be calculated using 2.75. So 5.5 - 2.75 = 2.75. Your answer could be this or 2,25. I'm not sure which. |
| Feb25-12, 09:33 PM | #5 |
There are 10 data values in my attached example.
{51, 55, 57, 61, 62, 67, 70, 72, 73, 74} Q1 = 56.5 Q3 = 72.25 But Q3 = 72 instead |
| Feb25-12, 10:08 PM | #6 |
| Feb27-12, 01:39 PM | #7 |
| New Reply |
| Thread Tools | |
Similar Threads for: Quartiles of ungrouped data
| Thread | Forum | Replies | ||
| Integration of acceleration signal response data to obtain displacement rseponse data | Differential Geometry | 0 | ||
| Statistic Problems With Quartiles and Standard Deviations | Calculus & Beyond Homework | 1 | ||
| Quartiles | General Math | 1 | ||
| Realize professional data management with TechRepublic's Guide to Data Storage Design | Computing & Technology | 0 | ||
| Quartiles | General Math | 3 | ||
