Lateral force of water on the walls of a tank
  • Context: Undergrad
  • Thread starter Thread starter jimhebert
    Force Tank Water
The discussion centers around calculating the lateral force exerted by water on the walls of a plywood fish tank, specifically focusing on the methodology for determining pressure at various depths and how that translates into force on the tank walls. Participants explore theoretical and practical aspects of fluid statics as they relate to the construction of the tank.
  • One participant seeks to calculate the lateral force at any point on the tank walls, noting the need for strong materials to support both lateral pressure and weight.
  • Another participant clarifies that pressure, not force, acts at a point, and provides a formula for calculating average pressure based on depth, gravitational acceleration, and water density.
  • Some participants argue that pressure decreases as one moves up the wall, while others emphasize that pressure at a specific depth can be calculated using the formula for hydrostatic pressure.
  • A participant calculates the pressure at a point 3 feet below the top of the wall, questioning the units of the resulting pressure value.
  • Discussions include the integration of pressure over an area to find total force, with various participants providing different formulations and interpretations of the equations involved.
  • Some participants emphasize the importance of unit consistency, particularly when using Imperial units, and provide examples of how to calculate total force on the walls and base of the tank.
  • There are corrections regarding the calculation of total weight on the floor of the aquarium and how it relates to pressure on the walls.
  • Multiple participants provide formulas for calculating total force on the walls, but there is no consensus on the best approach or the interpretation of the results.
Participants do not reach a consensus on the best method for calculating lateral force, with multiple competing views and interpretations of the formulas presented. There is ongoing debate about the correct application of pressure and force calculations, particularly regarding unit consistency and the distribution of pressure along the walls.
Limitations include potential misunderstandings of unit conversions, the integration process for calculating total force, and the assumptions made regarding the distribution of pressure across the tank walls. Some participants also highlight the need for clarity in defining terms like density in the context of the calculations.
jimhebert
I want to build a plywood fish tank 16' long x 4' wide x 3.5' high. I need to know how to calculate the lateral force at any point on the walls in order to build with strong enough lumber to support the lateral pressure and also the weight pushing down. I know that one gallon weighs 8.345 lbs. and one cubic foot has 7.48 gallons, so it's not too difficult to calculate the weight pushing down. The lateral force is where comes the problem.
jimhebert said:
I need to know how to calculate the lateral force at any point on the walls.
You don't have a force acting at a point, you have a pressure:
http://en.wikipedia.org/wiki/Fluid_statics#Hydrostatic_pressure
pressure = depth * gravitational_acceleration * water_densityThe force is the integral of pressure over an area of the wall. To get the total force, you can take the average pressure. Assuming a rectangle:
pressure_avg = 0.5 * total_depth * gravitational_acceleration * water_density
force_total = wall_area * pressure_avg
But the force is not evenly distributed. The wall must be stronger at the bottom.
I think that the formula is to calculate the average pressure pushing down on the floor, not any point on the wall which will decrease as you go up the wall.
This applies to any point at the wall (depth = depth of the point):
So let me see if I got this correctly. If I have a tank that is 16’ x 4’ x 3.5 ‘ and I want to know the pressure at a point that is at 3’ below the top of any of the four walls, then I would calculate the following: 3’ x 32 ft/sec/sec x 62.22 lb/cubic foot = 5973 pounds.
Is that correct? Is it 5973 lb/square foot or per square inch or is it on an area the size of a pencil point?
Pressure = height times density
Pressure = 3 feet x 62 lb/cu ft = 186lbs/sq ft
So it's like, roughly, somebody standing on a patch 1 ftx 1ft
[the formula in the previous posts above has the wrong units...]
The formula in the previous posts is correct if we are using the usual definition of density, which is mass per unit volume. It will give correct results if we are using SI units, or any other absolute system of units.
Your formula is only correct if we define density as weight per unit volume. It will work in a system where "pound" is used both as a unit of mass and of force, so it's better suited to jimhebert's needs.
To jimhebert: you have worked out how to calculate the total weight on the floor of the aquarium. Divide this by the area of the floor in feet and you will get the pressure, in pounds per square foot. The pressure at a point on the wall just near the floor will be almost the same as this. The pressure on a point halfway up the wall will be half this pressure and the pressure at the very top will be zero.
No, I haven’t calculated the total weight on the floor. The way to do that would have been 16x4x3.5 = 224 cu.ft.
Then 224x62.22 lb/cu.ft = 13,937 lbs. Total
Therefore, 13937 divided by the area of the floor (64) =218 lb/sq ft.
So based on the last part of your explanation, the lateral force pushing out from a point 2 feet deep 2/3.5 x 218 = 125 pounds/sq ft.
Those are the correct units as far as the math is concerned, but not the correct units for for the answer to the problem. The answer has to be in pounds.
The pressure in a fluid at depth [itex]z[/itex] from the surface is [itex]P(z) = \rho g z[/itex], where [itex]\rho[/itex] is the density of the fluid, and [itex]g[/itex] is the acceleration due to gravity.
The get the total force on a surface, the pressure would need to be integrated across the surface.
[tex]F = \int \limits_S P da[/tex]
For a vertical surface (like a wall of the tank) the force is:
[tex]F_{wall} = \int \limits_S P da =\rho g \int_0^w \int_0^h z dz dx[/tex]
[tex]F_{wall} = \frac{1}{2} \rho g w h^2[/tex]
where [itex]w[/itex] is the width of the wall and [itex]h[/itex] is the height of the wall. For the base:
[tex]F_{base} = \int \limits_S P da =\rho g h \int_0^w \int_0^l dy dxl[/tex]
[tex]F_{base} = m g[/tex]
where [itex]m[/itex] is the total mass of the fluid.
To get from mass to weight, replace [itex]m g[/itex] with the weight (i.e. pounds) and replace [itex]\rho g[/itex] with the weight density (i.e. pounds/foot^3).
You have the total weight right, but you still aren't getting the lateral force right. At a given depth, the pressure on the wall at that point is:
[tex]P = \rho g h[/tex]
Where:
[itex]P[/itex] is pressure (force per area)
[itex]\rho[/itex] is density (mass per volume)
[itex]g[/itex] is the acceleration due to gravity (length per time per time)
[itex]h[/itex] is depth (length)
You have to make sure that since you insist on using Imperial units, that your units remain consistent. If you are taking your density in pounds per cubic foot, that is essentially the [itex]\rho g[/itex] term.
Now, that gives you the pressure at a given depth. Force is pressure times area, but you know that the pressure varies with depth, so you have to integrate through the depth to get the total force.
[tex]dF = P\;dA = P\;dx\;dh[/tex]
Where:
[itex]dA[/itex] is a differential area
[itex]dx[/itex] and [itex]dh[/itex] are differential lengths that describe the area [itex]dA[/itex]
Now let's say the x-direction just the other coordinate for a given wall. You need to integrate the pressure over the area of the wall to get the force.
[tex]F = \int\limits_0^D \int\limits_0^W \rho g h\;dx\;dh[/tex]
Where:
[itex]F[/itex] is force
[itex]D[/itex] is the total depth
[itex]W[/itex] is the width of the side
and the rest have already been defined.
For vertical, rectangular walls, this simplifies to:
[tex]F = \rho g W \int\limits_0^D h\;dh[/tex]
[tex]F = \rho g W \left[\frac{h^2}{2}\right]_0^D[/tex]
So, that leaves you with:
[tex]F = \frac{\rho g W D^2}{2}[/tex]
Just make sure your units are consistent.
Looks like Jasso beat me to it. Just see whose description makes more sense to you, haha.
Jasso and boneh3ad have given the formula for calculating the total force on one side. In your case, since you're using imperial units (pounds for both mass and force), the [itex]\rho g[/itex] term is 62.42 lb per cubic foot. So, for example, the total force on one of the longer walls would be:
62.42 x 16 x 3.52/2 lb ≈ 6117 lb
But remember that that force is spread over the whole side, and not evenly spread: there is more pressure at the bottom than at the top.
Is it correct to say that the total force acting on the upper rectangular section of one of the 16' walls that is 2' from the top would be 62.42 x 16 x 2 squared divided by 2 = 1997 lb ?
Yes, that's correct. By subtracting this result from the previous one that gives the total force on the whole of that wall, you can also calculate that the total force on the rest of the wall is 6117 lb - 1997 lb = 4120 lb.
We know that the force per square inch on the wall will increase as we go from top to bottom. Also, if my logic is correct, the force per square inch should be the same along a horizontal line drawn across the wall. With this information that we have previously calculated, how do we now calculate the force per square inch at any given point on that wall. Let's say, what would be the force per square inch at any point on a horizontal line 2 feet below the top edge of the wall?
I think I figured it out. The force per square inch would be the same or very near the force or weight pushing down. I figured .8 lb. but doesn't sound reasonable.
That sounds reasonable enough to me.
OK, now I've got to find the supports that will keep the tank from rupturing due to pressure. Thanks for the help.
http://www.fnzas.org.nz/?p=1732: it gives a detailed method for calculating the glass thickness for aquarium walls.
Appreciate it, Michael. We'll give a try.
  • · Replies 31 ·
  • · Replies 37 ·
10K
  • · Replies 21 ·
9K
