| New Reply |
Electronic circuit with Op-Amp, Switch and Diodes |
Share Thread | Thread Tools |
| Feb16-12, 01:43 AM | #1 |
| Feb16-12, 04:13 AM | #2 |
Hi FP.... good old negativr feedback opamp !! It is an INVERTING opamp
You are correct to recognise how the circuit works and you get Vout = -8V when switch in position 1 and Vout = +8V when in position 2. Can you see how the diodes + lamp branches will respond to one output being -ve then being +ve? Part(B) voltage at c will not be zero |
| Feb16-12, 12:23 PM | #3 |
| Feb16-12, 12:49 PM | #4 |
Well spotted 'I like physics'
Apologies.....careless |
| Feb16-12, 01:35 PM | #5 |
Sorry 'I like physics' I think Vout =+8V when the switch is in position 2. In both switch position Va and Vb = 0
Why do you think it is +10V? |
| Feb16-12, 10:31 PM | #6 |
Good trick question though. |
| Feb17-12, 12:56 PM | #7 |
How come Vout is once positive and once negative?
The way I see it it's always the same formula Vout = -R2/R1 x Vin Therefor no matter the switch condition Vout must always be negative! |
| Feb17-12, 01:07 PM | #8 |
with the switch in position 1 can you see that the + of the battery is connected to V-
via R1 And with the switch in position 2 the - of the battery is connected to the V- via R1 PS The - in the equation tells you the amplifier is INVERTING so a + at the input produces a - at the output and a - at the input produces a + at the output |
| Feb17-12, 01:13 PM | #9 |
Say for example, you are using a multimeter to measure battery voltage. One terminal of the multimeter is reference, which you always connect to -ve terminal of the battery, the other connects to +ve terminal and you get 1.5v. What happens if you reverse the connection? |
| Feb19-12, 05:11 AM | #10 |
| Feb19-12, 05:31 AM | #11 |
No, it goes the other way. Remember Vout is -8V when Vin is +2V
When the switch is in position 2 the 2V battery is the other way round (upside down) Then the current will have the direction you have shown |
| Feb19-12, 05:31 AM | #12 |
Recognitions:
This would be correct! In S1 the battery would be as you drew it, but then the current would flow from the plus pole at +2V to the opamp at 0V. |
| Feb27-12, 12:36 AM | #13 |
| Feb27-12, 09:34 AM | #14 |
Recognitions:
Schematically you can indicate this by drawing the longer line on the bottom while not crossing the wires. |
| Feb27-12, 11:43 AM | #15 |
Ah, perfectly understood :) Though, one thing is still confusion to me. When asked "Explain the action of the circuit"-- what the hell do they expect me to write? To start explaining about op-amps and switches?
| Feb27-12, 11:55 AM | #16 |
Recognitions:
Hmm... the action of the circuit.
I'd interpret that as saying what "you" can do to the circuit (input), and how "you" would see the result of the circuit (the output). So what does the circuit do if the switch is in S1 (one possible input)? And what in S2 (the other possible input)? Can you light up both LED's simultaneously (possible output)? Or switch them both off simultaneously? Furthermore, what voltage is used for the switch (the input) and what voltage is used on the LED's (the output)? |
| Feb27-12, 12:15 PM | #17 |
Well, in that case then they should ask this question last, not first! I gotta do some calculations first!
| New Reply |
| Thread Tools | |
Similar Threads for: Electronic circuit with Op-Amp, Switch and Diodes
| Thread | Forum | Replies | ||
| Need help with a circuit with Op-amp and Diodes | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Electronic Supply sites make me cry :( (A switch-related question) | Electrical Engineering | 1 | ||
| Diodes in Electric Circuit | General Physics | 2 | ||
| Analysis of a circuit that contains two diodes | Introductory Physics Homework | 11 | ||
| Circuit analysis with diodes | Electrical Engineering | 7 | ||
