How to sort a list alphabetically but ignore numbers?
The discussion revolves around sorting a list of URLs alphabetically while ignoring numerical components. Participants explore various methods and tools for achieving this, including programming scripts and command-line utilities.
  • One participant suggests using the '/' character as a separator to extract the relevant field for sorting.
  • Another participant mentions the use of awk for parsing and sorting the URLs on a Unix-like system.
  • A different participant references the Right$ function in BASIC for extracting characters from the end of a string.
  • Several participants share a Python script link for sorting URLs, but one notes encountering an error related to file input.
  • A participant questions whether a specific URL would be sorted lexicographically when stripped of certain characters.
  • Clarification is provided regarding how to run the Python script with the necessary input file.
Participants present multiple approaches and tools for sorting URLs, but there is no consensus on a single method or solution. Some methods are challenged or require clarification, indicating ongoing exploration of the topic.
Participants express uncertainty regarding the complexity of the URLs and the specific requirements for sorting, which may affect the proposed solutions.
This discussion may be useful for individuals interested in programming, data processing, or those needing to sort URLs in a specific manner while ignoring numerical values.
rollcast
I have a list of urls I need to sort but I need to sort them only using the letters in the url?
Eg.
example.com/174353/a
example.com/3452344/c
example.com/435322/d
example.com/2342/b
example.com/23456/e
Would be sorted as:
example.com/2342/b
example.com/23456/e
Thanks
AL
Computer science news on Phys.org
if you process the file using the / as a separator then you can extract out the 3rd field to sort on.
you could probably use awk to do the parsing to write a new file containing the key then url on one line
then use the sort command to generate a sorted list.
thats if you're running on linux or some unix variant.
Most varieties of BASIC have a Right$(,) function, which would read the closing letter(s) off the target string.
I'm on Ubuntu 11.10.
The addresses aren't as simple as I thought here's one for example.
http:// www. flyforums. co.uk/fly-tying-step-step/160-beacon-beige.html
(The spaces are just there to stop it hyperlinking it.)
They all follow the same pattern with a number-couple of keywords separated by -s .html
how about this python script
http://snippets.dzone.com/posts/show/10115
It comes up with an error,
" File "sort.py", line 3, in <module>
filename = sys.argv[1]
IndexError: list index out of range"
Please clarify. Would the URL
be lexicographically sorted with the value
httpwwwflyformscoukflytryingstepstepbeaconbeigehtml
when you run it you're supposed to provide a file of your urls to be sorted.
./sorturls.py myfileofurls.lst
where sorturls.py is the name of the script and the myfileofurls.lst is your file of unsorted urls.
  • · Replies 41 ·
