velocity from acceleration if acceleration is a function of space...
by fisico30
Tags: acceleration, function, space, velocity
fisico30
fisico30 is offline
#1
Feb22-12, 03:26 PM
P: 374
Hello Forum,
usually the acceleration a is a function of time: a(t)= d v(t) /dt
to find v(t) se simply integrate v(t)= integral a(t) dt
What if the acceleration was a function of space, i.e. a(x)?
what would we get by doing integral a(x) dx? The velocity as a function of space, v(x)?
but a(x) is not defined to be v(x)/dx or is it? maybe some chain rule is involved..
thanks,
fisico30
Phys.Org News Partner Physics news on Phys.org
Physicists consider implications of recent revelations about the universe's first light
Vacuum ultraviolet lamp of the future created in Japan
Grasp of SQUIDs dynamics facilitates eavesdropping
rcgldr
rcgldr is offline
#2
Feb22-12, 07:17 PM
HW Helper
P: 6,930
Quote Quote by fisico30 View Post
What would we get by doing integral a(x) dx? ... chain rule ...
You use chain rule
a(x) = dv/dt = f(x)
multiply dv/dt by dx/dx:
(dv/dt)(dx/dx) = (dx/dt)(dv/dx) = v dv/dx = f(x)
multiply both sides by dx
v dv = f(x) dx
If f(x) can be integrated and the integral of f(x) = g(x), then
1/2 v2 = g(x) + c
This results in an equation that relates velocity and position.
v = sqrt(2 (g(x) + c))
To get time versus position, you start with
v = dx/dt = sqrt(2 (g(x) + c))
and then integrate
dx/(sqrt(2 (g(x) + c))) = dt
assuming h(x) is the integral of dx/(sqrt(2 (g(x) + c))), you get
t = h(x) + d
where d is constant of integration. It may be possible to solve this equation to get x = some function of t.
One simple case is a(x) = -x, which results in x(t) = e(sin(t+f)), where e and f are constants.
fisico30
fisico30 is offline
#3
Feb23-12, 07:42 AM
P: 374
Thanks rgcldr!
great explanation and example!
fisico30
fisico30
fisico30 is offline
#4
Mar2-12, 10:03 AM
P: 374
Hi rcgldr,
one question:
when you get v dv = f(x) dx, is v a function of t or of x, i.e. is v equal to v(t) or v(x)?
It looks like it would be a function of x, v(x), since 1/2 v^2 = g(x) + c results in v(x) = sqrt(2 (g(x) + c)).
I am confused because when we write v=dx/dt I always assume that v must be a function of time t, i.e. v(t).
When in your first step you write a(x) = dv/dt I tend to think that the v must be function of t since dv/dt is a derivative with respect to time.
So which one is correct? a(x)= dv(x)/dt or a(t)=dv(t)/dt. Acceleration is always the time derivative of the velocity vector but the velocity vector can be a function of any dependent variable: v(t), v(x), v(F), where F is force, etc....
Thanks,
fisico30
fisico30
fisico30 is offline
#5
Mar2-12, 10:12 AM
P: 374
I guess my point is: if a function, like a, is defined as a time derivative of another function, dv/dt, does the differentiated function need to be a function if time?
rcgldr
rcgldr is offline
#6
Mar2-12, 11:03 AM
HW Helper
P: 6,930
when you get v dv = f(x) dx, is v a function of t or of x, i.e. is v equal to v(t) or v(x)? It looks like it would be a function of x, v(x), since 1/2 v^2 = g(x) + c results in v(x) = sqrt(2 (g(x) + c)).
At this point, it's just a relationship betwen v and x.
It is, but I was only able to take advantage of that in the last step where I find t as a function of x.
True, but I used chain rule to get rid of the dt and end up with v dv = f(x) dx.
Both are correct, but if acceleration is defined as a function of x, then it may not be possible to find an equation for acceleration as a function of time. In the simple example I gave, a(x) = -x, you will be able to find both a(x) and a(t). I ended up finding x(t) = e sin(t + f). You can take the derivative of this to find v(t), and the derivative of v(t) to find a(t), so a(x) = -x, and a(t) = -e sin(t+f). For other situations, you may not be able to solve for x(t), v(t), or a(t), in which case numerical integration will be required.
fisico30
fisico30 is offline
#7
Mar3-12, 08:03 AM
P: 374
So it is mathematically legal and ok to write a derivative of a function even if
the independent variable a of the function and the differentiation variable b are not the same: f(a) and db to create df(a)/db...
I guess that is all the chain rule is about....
Register to reply
Related Discussions
Acceleration as a function of position, and velocity. Classical Physics 2
Acceleration as a function of velocity - HW problem help Introductory Physics Homework 6
Acceleration as a Function of Velocity Introductory Physics Homework 4
motion in space: velocity and acceleration Calculus & Beyond Homework 7
Acceleration when velocity is a function of distance Introductory Physics Homework 7
