New Reply
Speed of waves in a nonuniform wire
Share Thread Thread Tools
Mar7-12, 12:22 AM   #1
1. The problem statement, all variables and given/known data
A wire that is 7.75 m long and has a uniform density of 10.0 g/cm^3 is pulled to a tension of Ft=376 N. The wire, however, does not have a uniform thickness; rather, it varies uniformly from an initial radius of 1.0 mm to a final radius of 3.3 mm where is it attached to a wall. If you send a wave pulse down the length of the string, how long does it take to reach the wall?
2. Relevant equations
Volume=∫∏(0.001 + 2.97e-4 X)^2 dx
Alternately, Volume= (∏h/3)*(a^2 +ab + b^2) where a= 3.3 mm, b= 1 mm, h=7.75 m (This is the volume of a conical frustrum)
Velocity= √(Ft/μ)
μ=mass/length
3. The attempt at a solution
Using the equations for volume, I found that Vol=1.234*10^-4 m^3. Then I multiplied by 10,000 kg/m^3 to get the mass of the wire. I divided that number by 7.75 and then divided 376 by that number, then took the square root. (Using the velocity function). I found the velocity to be 48.62 m/s. Then I divided 7.75 m by 48.62 m/s to get the time, 0.159 seconds.
My question is- is it really that simple? I couldn't find much information on nonuniform wires. Does the velocity of the wave stay constant throughout the whole wire?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
New Reply
Tags
nonuniform, tension, velocity, waves
Thread Tools
Similar Threads for: Speed of waves in a nonuniform wire
Thread Forum Replies
waves and sounds, finding the speed of a jet using the speed of sound Introductory Physics Homework 2
Calculate the ratio of the speed of electromagnetic waves in vacuum to their speed in Introductory Physics Homework 2
Speed of a transverse wave along a wire? Introductory Physics Homework 6
Electron Group Waves & Electromagnetic Waves, energy delivery in a wire Classical Physics 10
Speed of Wire faster than Speed of Light??? General Physics 2
