Register to reply
E field
by sasuke07
Tags: field
Share this thread:
sasuke07
#1
Mar8-12, 05:02 AM
P: 54
1. The problem statement, all variables and given/known data
What is the magnitude of the collective contribution to the E field at the origin from both the + and - charges located 5 cm above the horizontal axis?
2. Relevant equations
kQ/d^2
3. The attempt at a solution
Im just having a problem setting up this problem. Could someone help me on getting started
Phys.Org News Partner Science news on Phys.org
Climate change increases risk of crop slowdown in next 20 years
Researcher part of team studying ways to better predict intensity of hurricanes
New molecule puts scientists a step closer to understanding hydrogen storage
tiny-tim
#2
Mar8-12, 06:33 AM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,160
hi sasuke07!
(try using the X2 button just above the Reply box )
first, find the magnitude of each contribution,
from that, find the x and y components
what do you get?
sasuke07
#3
Mar8-12, 06:47 AM
P: 54
I already figured out the magnitued of the the positive charge 5 cm above the axis and got 5.4X10^4. What do you mean by the x and y components. WOuldn't the negative charge have the same magnitude of the positive charge.
tiny-tim
#4
Mar8-12, 06:56 AM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,160
E field
Quote Quote by sasuke07 View Post
yes
draw an arrow at the origin showing the direction of the field from the positive charge
then find the x and y components of that arrow
(and finally you'll add them to the x and y components of the arrow from the negative charge )
sasuke07
#5
Mar8-12, 07:02 AM
P: 54
so to figure out the x component wouldn't it be Kq/d^2 where k=9X10^9, q is 30X10^9= charge and d would be .05m^2. Or would i have to use cosine and sine to figure out the x and y components and if so could you show me how to set it up.
tiny-tim
#6
Mar8-12, 07:09 AM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,160
no, you must use cos and sin, of the angle the arrow makes
sasuke07
#7
Mar8-12, 07:11 AM
P: 54
so would it be Kq/r^2sintheta
and Kq/r^2Costheta. Where theta would be 90 degrees?
sasuke07
#8
Mar8-12, 07:14 AM
P: 54
or would theta be 45
tiny-tim
#9
Mar8-12, 07:18 AM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,160
θ is the angle of the line from the charge to the origin
sasuke07
#10
Mar8-12, 07:19 AM
P: 54
awesome so 45 degrees.
sasuke07
#11
Mar8-12, 07:19 AM
P: 54
So were the equations correct though?
tiny-tim
#12
Mar8-12, 07:30 AM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,160
looks ok
so what is the total field from both the positive and the negative charge?
sasuke07
#13
Mar8-12, 07:32 AM
P: 54
i got 7.6X10^4 by doing KQ/r^2sin45 and the answer is the same for cos45. BUt i checked the answer and its supposed to be 7.1X10^4. Any suggestions
tiny-tim
#14
Mar8-12, 07:48 AM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,160
your answer looks right to me
(are you sure it's 5 cm that they're asking about?)
sasuke07
#15
Mar8-12, 07:52 AM
P: 54
i think its 5cm because the length of the x and y components is 5cm.
Register to reply
Related Discussions
Find induced E field inside a disk in an uniform magnetic field. Advanced Physics Homework 5
Can a time-varying magnetic field emulate the electric field of a point charge? Classical Physics 3
Similarities and differences between B-field, E-field and G-field Introductory Physics Homework 0
Parallel Plate Capacitor: Electric field strength, flux & magnetic field Introductory Physics Homework 0
Total field, scatt field, incident field... Classical Physics 0
