Register to reply
Voltage and current source in superposition theorem
Share this thread:
wilsonb
#1
Mar16-12, 12:53 AM
P: 28
why we take current source as a open and voltage source as a short in superposition theorem. is this is because of its internal resistance or any other reason exist?
Phys.Org News Partner Engineering news on Phys.org
Researchers find security flaws in backscatter X-ray scanners
Virtual reality guides those whose memory is failing
Intelligent navigation system to personalise shopping trips
rbj
#2
Mar16-12, 01:21 AM
P: 2,251
An ideal voltage source is something that will deliver that specified voltage no matter how much current is required. If you set that voltage spec to 0 (which you do to remove that voltage from the linear equation that depends on it) it is the same as a short circuit. A wire.
An ideal current source is something that will deliver that specified current no matter how much voltage is required. If you set that current spec to 0 (which you do to remove that current from the linear equation that depends on it) it is the same as an open circuit. An insulator.
Register to reply
Related Discussions
Power supplied by both a Current Source and a voltage source connected in parallel Engineering, Comp Sci, & Technology Homework 1
RL circuit with dependent voltage source and indep. current source with unit step Engineering, Comp Sci, & Technology Homework 5
CIRCUITS: Current Controlled Voltage source, Indep. Voltage source, Four resistors... Introductory Physics Homework 1
CIRCUIT ANALYSIS: Use superposition - 2 Current source, 1 Voltage source, 4 resistors Advanced Physics Homework 6
