| New Reply |
Steel Frame vs RC Frame |
Share Thread | Thread Tools |
| Mar31-12, 05:42 PM | #1 |
Is it true that in busy streets. Steel frame building is not recommended because there would be lots of vibration that can dislodge the concrete wall binding with the steel i-beam? But how about in RC (Reinforced Concrete) frames. Would there be significantly less vibration that it is more recommended in busy streets?
If you know of other pro and con of steel vs RC frame. Please share it. Thanks. |
| New Reply |
| Thread Tools | |
Similar Threads for: Steel Frame vs RC Frame
| Thread | Forum | Replies | ||
| Rotating cylinder on x'-axis in S' frame. Find twist per unit length in S frame | Advanced Physics Homework | 1 | ||
| Structural steel frame | Engineering, Comp Sci, & Technology Homework | 1 | ||
| thermal conductivity, pressed steel frame, insulated wall. | Mechanical Engineering | 1 | ||
| Steel Frame Analysis (suffer torsion) | Mechanical Engineering | 2 | ||
| Transformation of EM fields from rest frame to rotational frame | Classical Physics | 0 | ||
