Register to reply
Arrhenius equation plot
by Pranav-Arora
Tags: arrhenius, equation, plot
Share this thread:
Pranav-Arora
#1
Apr2-12, 12:36 PM
P: 3,806
1. The problem statement, all variables and given/known data
This isn't a homework question but this thing is disturbing from a long time.
I attended a class on Arrhenius equation and its plots. One of the plots is disturbing me from long which is the plot between k vs T.
Arrhenius equation:-
[tex]k=Ae^{-\frac{E_a}{RT}}[/tex]
k->Rate constant
Ea->Activation Energy
R->Gas constant
T->Temperature
2. Relevant equations
3. The attempt at a solution
Since the equation is of the form y=e-1/x, the graph should be like this one:-
Click Here
But my teacher made a completely different plot. I constantly said that it shouldn't be like that. Finally, when i checked wikipedia, to my surprise, the teacher was right. Here's the wiki article:- http://en.wikipedia.org/wiki/Arrhenius_plot
I don't understand why the graph is different from that of y=e-1/x? Can somebody tell me where i am going wrong?
Thanks!
Phys.Org News Partner Science news on Phys.org
Wildfires and other burns play bigger role in climate change, professor finds
SR Labs research to expose BadUSB next week in Vegas
New study advances 'DNA revolution,' tells butterflies' evolutionary history
jedishrfu
#2
Apr2-12, 12:43 PM
P: 2,812
arent the wiki graphs log based?
Pranav-Arora
#3
Apr2-12, 12:59 PM
P: 3,806
I am talking about this graph from the wiki page:-
No, i don't think this one is log based.
jedishrfu
#4
Apr2-12, 01:41 PM
P: 2,812
okay so the bottom chart is an arrhenius plot plotting 1/T vs ln(k) as defined in the wiki page and the upper chart is the same data but plotting T vs k.
The only thing I can think of is that Ea changes with the square of T causing it to curve upward.
I like Serena
#5
Apr2-12, 01:50 PM
HW Helper
I like Serena's Avatar
P: 6,187
Hey Pranav-Arora! ;)
Here's another one from WolframAlpha.
plot[ y=e^(-1/x), {x,0.2,0.5} ]
Doesn't it kind of look like your graph?
Pranav-Arora
#6
Apr2-12, 02:04 PM
P: 3,806
Quote Quote by I like Serena View Post
Hello ILS! :)
Oh yeah, that's look like something which i am looking for. You made the graph for very small values of x but i don't think that this is correct because in the wiki graph, temperature is increasing to high numbers but it isn't turning like to be that of y=e^(-1/x).
Quote Quote by jedishrfu View Post
Ea changes with the square of T? I will have to check that out.
I like Serena
#7
Apr2-12, 02:22 PM
HW Helper
P: 6,187
Well, the formula is undoubtedly based on the shape of the graph when plotting ln k versus 1/T.
Then you apparently get the graph:
This is approximated by a straight line.
With the relationship ##\ln k = c_1 - c_2 \cdot \frac 1 T##, you can deduce that ##k=A e^{-\frac B T}##.
When I make an approximation of this, I get the following graph:
plot[ k=18e9 * e^(-13000/t), {t,590,660} ]
Doesn't this kind of fit the expected graph?
Pranav-Arora
#8
Apr3-12, 09:22 AM
P: 3,806
With the relationship ##\ln k = c_1 - c_2 \cdot \frac 1 T##...
How did you get this relation?
I like Serena
#9
Apr3-12, 09:32 AM
HW Helper
P: 6,187
Quote Quote by Pranav-Arora View Post
A straight line is defined by the equation:
$$y = a x + b \qquad\qquad (1)$$
where ##a## is the slope of the line, and ##b## is the y-coordinate where the line intersects the y-axis (the y-intercept).
When we fit a straight line to a set of points, we try to find out what ##a## and ##b## have to be.
In this case we have ##\ln k## on the y-axis, and ##\frac 1 T## on the x-axis.
So we replace ##y## in equation (1) by ##\ln k##, and we replace ##x## by ##\frac 1 T##.
The result is:
$$\ln k = a \cdot \frac 1 T + b$$
Since we already know that the line slopes down, I have taken the liberty of putting in a minus sign, and rewriting the equation with different constants ##c_1## and ##c_2## as:
$$\ln k = c_1 - c_2 \cdot \frac 1 T$$
Pranav-Arora
#10
Apr3-12, 10:31 AM
P: 3,806
The result is:
I already knew about the straight line stuff, i was getting confused with those constant c1 and c2.
Thank you for the help!
Register to reply
Related Discussions
Using an Arrhenius plot Chemistry 3
Arrhenius Equation problem Biology, Chemistry & Other Homework 5
Arrhenius equation (chemistry) Biology, Chemistry & Other Homework 4
Finding Activation Energy From Arrhenius Plot Biology, Chemistry & Other Homework 3
Arrhenius equation Biology, Chemistry & Other Homework 5
