| New Reply |
Calculating Steady State Heat Transfer |
Share Thread |
| Apr7-12, 11:12 PM | #1 |
A straight, uniform circular pipe of internal diameter of 88.43 mm and external diameter of 118.38 mm carries hot water at 63.67 deg cel. The pipe has a thermal conductivity of 247 Wm^-1 K^-1.
how to calculate the steady-state rate of heat transfer per unit length, in W m^-1, when the outside temperature is 30.59 deg cel. What I have done so far:- Temperature Gradient = (T1-T2)/d, where d is the diff in radius of cylinder = (63.67-30.59)/(0.5*(118-88.43)*0.001) = 2209.015025 So,heat transfer = 247*3.142*0.08843*2209.015025 = 151581 Wm^-1 Is the method right? |
| Apr8-12, 01:04 AM | #2 |
Recognitions:
You'll need to use the formula for a hollow cylinder (which is what a pipe is)
http://en.wikibooks.org/wiki/Heat_Tr...ollow_cylinder |
| New Reply |
| Tags |
| calculus, homework help, phyiscs |
Similar discussions for: Calculating Steady State Heat Transfer
| Thread | Forum | Replies | ||
| Conceptual question on heat transfer (Steady-state) | Engineering, Comp Sci, & Technology Homework | 5 | ||
| Steady-State to Transfer Function Using MATLAB | Engineering Systems & Design | 2 | ||
| heat transfer (steady state, one dimensional) | Engineering, Comp Sci, & Technology Homework | 1 | ||
| steady state heat conduction | Classical Physics | 1 | ||
