Register to reply
What happens when net torque is zero?
by jayadds
Tags: torque
Share this thread:
jayadds
#1
Apr13-12, 09:48 PM
P: 42
I know that net torque is the sum of torques in a given situation. So take this as an example: If I used a wrench to turn a nut counterclockwise and it succesfully moves, is the net torque going to be non-zero? If so, then can someone please give me an example where the net torque can be zero.
Furthermore, if net torque is zero, does that mean the object doesn't rotate?
Phys.Org News Partner Physics news on Phys.org
Engineers develop new sensor to detect tiny individual nanoparticles
Tiny particles have big potential in debate over nuclear proliferation
Ray tracing and beyond
haruspex
#2
Apr13-12, 10:31 PM
Homework
Sci Advisor
HW Helper
Thanks
P: 9,873
It's no different in this regard from the linear case.
A nonzero net torque will result in an angular acceleration.
When the nut starts to rotate, from stationary, it is being accelerated, so there is a net torque. But very soon it's rotating at a steady rate, so the net torque is back to zero. The torque you continue to apply is equal to the dynamic friction.
In the period during which you were building up the torque, but the nut was still not yielding, your applied torque was exactly balanced by static friction.
Register to reply
Related Discussions
Motor Torque, Starting Torque, Stall Torque, Load Torque Mechanical Engineering 3
Solve for torque? Torque = Moment of Inertia * Angular Acceleration? Introductory Physics Homework 6
Mechanival torque and load torque caluculation of induction motor driven submersible Electrical Engineering 0
Wheel torque > contact patch friction > torque Classical Physics 1
I'm confused with the output torque, torque developed in the armature Engineering, Comp Sci, & Technology Homework 0
