| New Reply |
Random Variables: Calculating E[X|Y] |
Share Thread | Thread Tools |
| Apr13-12, 03:49 PM | #1 |
1. The problem statement, all variables and given/known data
This is an example in a textbook; it already has the solution. I don't understand how E[X|Y] was obtained though. So my question is how do I calculate E[X|Y] from the information given? ![]() ![]() This last part is probably not needed to solve the problem, I think. But I am adding it for completeness and context. ![]() E[X] is the expected value, or mean, of X. 2. Relevant equations [tex] E[X|Y] = \int_{-\infty}^{\infty} x f_{X|Y}(x|y)dx [/tex] Law of Total Variance: var(X) = E[var(X|Y)] + var(E[X|Y]) 3. The attempt at a solution I don't really understand how X is dependent on Y. It seems to me that Y is dependent on X! I'm really lost with this material, though. I don't have fX|Y(x|y) and I think that E[X|Y] is independent of Y, which would imply that E[X|Y] = E[X]. [tex]E[X] = 1/2\int_{0}^{1} x dx + 1/4\int_{1}^{3} x dx = 1/2*1 + 1/4*2 = 1?[/tex] E[X|Y] is supposed to be a random variable that is a function of Y though. I just don't see how Y plays any part in the computation. |
| Apr13-12, 04:05 PM | #2 |
Just forget about the integrals and junk and just think about what that is telling you to do.
E[X|Y=y] says what is the expected value of the variable X given we know Y is a certain value. So, Y can take on 2 values -- 1 and 2. Let's write these out: E[X|Y = 1] and E[X|Y = 2] So what do we know about X if we know Y = 1? We know, by the definition of Y, that X < 1. So the conditional pdf of X is the region between 0 and 1 normalized such that the area from 0 to 1 equals 1.Like this: [tex]f_{X|Y=1}(x) = \frac{f_X(x)}{p[Y=1]}[/tex] where f_x(x) is only nonzero where y = 1 (meaning x < 1) [tex]f_{X|Y=1}(x) = \frac{f_X(x)}{\int\limits_{0}^{1} f_X(x)dx}=\frac{f_X(x)}{\frac{1}{2}}=2f_X(x)[/tex] Once we have this conditional pdf, just plug it into the integral definition of expectation [tex]\int\limits_{0}^{1} 2xf_X(x) dx [/tex] Note, again, the limits here are because this f_X(x) (it is bad notation, I know) is actually nonzero only where x < 1 since it comes from finding the P[X <= x AND Y = y] in the equation [tex] P[X \le x | Y = y] = \frac{P[X \le x \cap Y = y]}{P[Y=y]}[/tex] For the other one, it's the exact same except we know x is greater than or equal to 1. |
| Apr13-12, 09:16 PM | #3 |
Thanks for answering.
Can we always assume the if is biconditional (if and only if)? It seems that you interpret IF x <1, then Y=1 to also mean, IF Y =1, then x <1. I'm also not sure why [tex]f_{X|Y=1}(x) = 2*f_X(x) = 1[/tex] I think this is the probability for E[X|Y=1], isn't it supposed to be 1/2? I assumed that f_X(x) = 1/2, since that's its value between 0 and 1. |
| Apr13-12, 10:00 PM | #4 |
Random Variables: Calculating E[X|Y]I derived for you the conditional pdf. The conditional expectation is found through weighted integration of the conditional pdf: [tex]E\{X|Y=1\}=\int\limits_{0}^{1} 2xf_X(x) dx =\int\limits_{0}^{1} 2x\frac{1}{2} dx=\int\limits_{0}^{1} x dx=\frac{1}{2}[/tex] But of course, you can just use the common sense notion of expectation to figure it out. The first one is uniform from 0 to 1, so its average value is 1/2. The second is uniform from 1 to 3, so its average value is 2. |
| Apr14-12, 12:29 AM | #5 |
I really appreciate your clarification. The problem that I was having was rationalizing how the probability of E[X|Y=1] and E[X|Y=2] is 1/2, but I think I understand now.
Thank you! |
| New Reply |
| Tags |
| conditional, probability, random variables |
| Thread Tools | |
Similar Threads for: Random Variables: Calculating E[X|Y]
| Thread | Forum | Replies | ||
| A question in random variables and random processes | Set Theory, Logic, Probability, Statistics | 1 | ||
| Proof of the statement: sum of two random variables is also a random variable | Set Theory, Logic, Probability, Statistics | 8 | ||
| Sum of random number of random variables | Set Theory, Logic, Probability, Statistics | 8 | ||
| Expectation and variance of a random number of random variables | Calculus & Beyond Homework | 3 | ||
| random variables | Set Theory, Logic, Probability, Statistics | 2 | ||
