| New Reply |
What is the strongest known bendable material? |
Share Thread | Thread Tools |
| Apr5-12, 08:15 PM | #1 |
By "bendable" I mean "you can run it through a pulley and it retains tension", and by "strong" I refer to tensile yield strength.
Thanks in advance. |
| Apr5-12, 09:36 PM | #2 |
Mentor
Carbon nano-tubes I suppose - could you provide some context, though?
| Apr6-12, 06:44 AM | #3 |
| Apr6-12, 07:20 AM | #4 |
I would have said a chain, but for a crossbow that might not be the best choice.
There are very strong fibers like Zylon. http://en.wikipedia.org/wiki/Zylon |
| Apr6-12, 07:52 AM | #5 |
So is Zylon usable as rope/flexible string?
| Apr6-12, 08:02 AM | #6 |
Don't know. I have only seen it used soaked with epoxy to reinforce high-field magnets. Off the spool the stuff is a bit ... hairy, so for a string you'd have to insert it into some kind of shell, the way climbing ropes are built.
| Apr7-12, 09:00 PM | #7 |
Mentor
The question seems odd - a crossbow isn't that demanding of an application, so you really don't need anything close to the strongest.
| Apr8-12, 07:51 AM | #8 |
| Apr14-12, 06:48 PM | #9 |
Ive seen this done, some guys I worked with years ago built a crossbow based on plans for a trigger they found online. They used a leaf spring from an old van and a 10t cable as the string. The arrow was 20mm dia stainless rod, with a ground tungsten carbide tip brazed on the end. Long story short, it needed to be cocked with the overhead crane and fired from a vice, it shot straight through a solid brick wall, then it was declared evil and promptly dismantled.
| Apr19-12, 01:25 AM | #10 |
Carbon nanotubes
| New Reply |
| Thread Tools | |
Similar Threads for: What is the strongest known bendable material?
| Thread | Forum | Replies | ||
| Strongest material conformation | Materials & Chemical Engineering | 2 | ||
| Material that is bendable in certain conditions | Materials & Chemical Engineering | 2 | ||
| Which is strongest base? | Biology, Chemistry & Other Homework | 1 | ||
| What's the best/strongest material for RC car models? | Mechanical Engineering | 10 | ||
| What is the strongest electrolyte? | Materials & Chemical Engineering | 0 | ||
