Register to reply
Elastic modulus or Young's modulus
by iliad
Tags: elastic, modulus, young
Share this thread:
iliad
#1
Apr12-12, 11:42 AM
P: 1
I have a question
Elastic modulus in Tensile test
E = L*F / A*△L
Elastic modulus in bending test
E = F*L^3 / 4*w*t^3*D
I think Elastic modulus is changed by size of specimen.
I don't know why Elastic modulus is inherent propertie of metal??
Phys.Org News Partner Engineering news on Phys.org
Printing the metals of the future
New gadget helps the vision-impaired to read graphs
3D printing helps designers build a better brick
MalliCk
#2
Apr14-12, 04:22 AM
P: 33
Elastic modulus is actually the elastic strain borne the atomic bonds. Since bonds in metals (metallic bonds) are isotropic (uniform) therefore elastic modulus remains the same regardless of the size of the object. Properties beyond the elastic limit however are transitive depending on different factors like grain size, microstructure constituents etc.
afreiden
#3
Apr15-12, 08:10 PM
P: 105
If you were to actually do a tension test for a particular material that obeys Hooke's Law, and then plug in the ΔL measured, experimentally, into your first formula -- you would find that "E" is constant. In other words, "E" is independent of your applied force, F, as well as the dimensions of your specimen: L and A. "E" can therefore be said to be a property of material only (not geometry!).
Similarly, if you were to do a three point bend test for that same material, and then plug in the deflection (D) measured, experimentally, into your second formula -- you would find that "E" is the same as before. "E" is again independent of the applied force, F, as well as the dimensions of your beam specimen: L, w, and t.
Quote Quote by iliad View Post
Nope.
I don't know why Elastic modulus is inherent property of metal??
What MalliCk said.
Hope that helps..
Register to reply
Related Discussions
Young's Modulus - estimate elastic limit Introductory Physics Homework 7
Derive relationship between Young modulus and Shear modulus Introductory Physics Homework 0
Young's modulus and bulk modulus of cooked pasta Classical Physics 4
Young's Modulus help. Introductory Physics Homework 6
Youngs Modulus and Elastic Modulus Introductory Physics Homework 6
