Non return valve location - booster pump/accumaltor
by bellshom
Tags: booster, location, pump or accumaltor, return, valve
bellshom
bellshom is offline
#1
Apr16-12, 05:39 PM
P: 21
Hey,
Just something i wanted to confirm, in a pipe system a booster pump is used to boost the water pressure. A accumaltor is postioned after the pump, a non return valve is required at the pump outlet. I believe the non return valve should be before the accumaltor but after the pump.
Is this correct.
Cheers
Phys.Org News Partner Engineering news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
WSU innovation improves drowsy driver detection
Faster computation of electromagnetic interference on an electronic circuit board
Travis_King
Travis_King is offline
#2
Apr17-12, 07:13 AM
P: 764
Yup. To prevent the Accumulator from backflowing through the pump. Also note (I don't know what you may be using this for) you'll want a manual dump/drain/sample valve between the check (non-return) valve and the accumulator to relieve the system of energy for maintenance or repair of the circuit.
Register to reply
Related Discussions
Is there a difference between a car fuel pump and a water pump Classical Physics 3
LPG efficiency booster Product Claims 9
Peristaltic pump as control valve? Mechanical Engineering 0
Aircraft Fuel Booster Pump - Centrifugal & Immersed in Fuel Mechanical Engineering 1
Degradation in Source Location Accuracy in the Presence of Sensor Location Error Electrical Engineering 2
