| Thread Closed |
zeroes at the end of a FACTORIAL |
Share Thread |
| Aug4-05, 02:26 AM | #1 |
how can i find the number of zeroes at the end of 100!
how can i find the number of zeroes at the end of n! thanks in advance. |
| Aug4-05, 06:44 AM | #2 |
So I am guessing that 100! has 20 zeros, because in counting by fives, we get to 100 after 20 steps. |
| Aug4-05, 07:02 AM | #3 |
Recognitions:
24 zeros is the answer. (*)You will have a number which is divisible by 5 for every 5 successive integer. (*)You will have a number which is divisible by 25 (ie 5.5) for every 25 successive integer. (*)You will have a number which is divisible by 125 (ie 5.5.5) for every 125 successive integer, and so on... So you will have 20 numbers which is divisible by 5 (included numbers that is divisible by 25). And you will have 4 numbers which is divisible by 25. So you will have: 20 + 4 = 24 zeros in 100! In general, you will have: n! has: [tex]C = \left[ \frac{n}{5} \right] + \left[ \frac{n}{5 ^ 2} \right] + \left[ \frac{n}{5 ^ 3} \right] + ... + \left[ \frac{n}{5 ^ q} \right][/tex] zeros at the end. You can stop the sum at any q such that: [tex]\left[ \frac{n}{5 ^ q} \right] = 0[/tex] Where [...] denotes the integer part of a number. For example : [1.55] = 1, [0.77] = 0, [14.333333] = 14. Viet Dao, |
| Aug4-05, 08:07 AM | #4 |
Yes, I just realized that we have to add four more! Why? Because in 20 steps, there are four times that five is reduplicated.
Finding the number of times 5 is a prime factor is right, but, for example, when we get to 25 it is in there twice. And so 20 / 5 is 4. There are four times that happens. Add that back into the 20 and we get 24. |
| Oct9-10, 01:56 PM | #5 |
The formula given in this thread is inaccurate. It's not the rounding function, but the floor function that should be used.
floor(n/5)+floor(n/(52))+floor(n/(53))+... This is because rounding each quotient may occasionally result in counts that are too high. For example: 999! 999/5=199.8~200 (correct value: 199) 999/25=39.96~40 (correct value: 39) 999/125=7.992~8 (correct value: 7) 999/625=1.5984~2 (correct value: 1) Total: 250 (correct value: 246) As you can see, there's an error of 4 zeros! Edit: Never mind. I misinterpreted his symbols. The Rounding function is usually indicated by square brackets. The Floor, or the integer part of the number, is indicated by L-shaped brackets. So naturally without reading the entire post, I jumped to a conclusion. |
| Mar29-12, 05:19 AM | #6 |
for writing a program it may be useful to get the number of zeros at the end of a factorial without usage of floor function:
n = p(1)*5 + q(1) p(1) = p(2)*5 + q(2) p(2) = p(3)*5 + q(3) etc p(n-1) = p(n)*5 + q(n) so, p(n) = (p(n-1) - q(n))/5 p(n-1) = (p(n-2) - q(n-1))/5 etc where q(i) is actually p(i-1) mod 5 , or q(i) = p(i-1)%5 |
| Apr7-12, 12:55 PM | #7 |
You provided the easiest solution.
One 5 each from 5,10,15,20,30,35,40,45,55.......70,80,85… (excluded 25,50,75,100) so that's 15x1=15 Two 5s each from 25,50,100 Three 5s from 75 15+2x3+3x1=24 It was an easy problem. Why did I think its tough :/ Thanks for answering, everyone. |
| Thread Closed |
Similar discussions for: zeroes at the end of a FACTORIAL
| Thread | Forum | Replies | ||
| Locus of zeroes | Calculus | 3 | ||
| multiplicities of zeroes | Calculus & Beyond Homework | 1 | ||
| rooted zeroes | Calculus | 4 | ||
| Proof of function zeroes. | Calculus & Beyond Homework | 1 | ||
| Zeroes | Linear & Abstract Algebra | 15 | ||
