New Reply
Calculating force of impact and maximum moment
Share Thread Thread Tools
May1-12, 04:14 PM   #1
We have the following problem we're trying to solve:
A helicopter is landing at 6 ft/sec, with its nose tilted up 15 degrees. We're designing a bumper that sits under the tail that has to absorb enough energy to reduce the maximum moment experienced by the tail to 350,000 in. lbs. Our bumper is sitting 338 inches behind the helicopter's center of gravity.
To absorb the energy, we have a crushable aluminum material that is a cylinder 7 inches long, with radius 3.25 in. We need to pick the exact material by finding the pressure (in psi) that the material should crush at.
We started by finding the initial KE of the helicopter, which is 1/2mv^2=1/2(26,500lb)(72 in/sec)^2 = 68,688,000 lb in^2. There must be a way to use the maximum moment to find out how much energy our bumper needs to absorb, and from there since W=Fxd, F=W/d=W/7 in. What are we missing here?
Thanks
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
New Reply
Thread Tools
Similar Threads for: Calculating force of impact and maximum moment
Thread Forum Replies
Calculating Maximum Bending Moment? Engineering, Comp Sci, & Technology Homework 1
calculating distance from force and impact Classical Physics 2
Calculating impact force General Physics 7
calculating impact force?? Introductory Physics Homework 4
Calculating Impact Force General Engineering 2
