Momentum & Kinetic Energy MC *quick*
The problem involves two objects, X and Y, on a frictionless surface with a spring compressed between them. The mass of X is 2/5 that of Y, and after the spring is released, X has a kinetic energy of 50 J. Participants are tasked with determining the kinetic energy of Y from multiple choice options.
  • Participants discuss using conservation of momentum and kinetic energy equations to find the kinetic energy of Y. Some question the validity of assuming kinetic energy conservation due to the spring's involvement.
There is ongoing debate regarding the correctness of the initial answer of 20 J, with some participants suggesting that the answer should be 125 J based on different interpretations of the problem. Multiple viewpoints are being explored without a clear consensus.
Participants note that the spring's role complicates the conservation of energy and momentum, leading to confusion about the assumptions made in the calculations. The problem's constraints and the nature of the interaction between the objects are under scrutiny.
mhz
Two objects, X and Y, are held at rest on a horizontal frictionless surface and a spring is
compressed between them. The mass of X is 2/5 times the mass of Y. Immediately after the
spring is released, X has a kinetic energy of 50 J and Y has a kinetic energy of:
A. 20 J
B. 8 J
C. 310 J
D. 125 J
E. 50 J
p = p'
E_kinetic = 1/2 mv^2
Alright, if I use p = p' to set up an explosion/recoil equation where we have two variables v1' and v2' then I can use the kinetic energy equation to find v1' (50 = 1/2 (2/5) v1^2) and then plug this value into the p = p' equation, finding v2'. I then use v2' to find it's kinetic energy which should be the answer to the question and I get 20 J.
Apparently this is incorrect. How?
Please provide proof as to how I could possibly be wrong. Thanks :)
Taking your answer of 20J, work the problem backwards to see if you come up with 50J for the KE of mass x.
.5M1V1^2 + .5M2V2^2 = 70
From momentum you can relate V1 and V2. Solve for KE1 which is quantity .5M1V1^2. If you get 50, your answer must be correct.
Kinetic energy of the two blocks is not conserved, because of the compressed spring. Only conservation of momentum is legitimate to use to solve this problem.
I'd say that your answer is correct. Why do you think it's wrong?
This PDF file has the question on it, #77. It says the answer is D, 125 J.
http://myfizika.ucoz.com/_ld/0/43_Test_Bank_9.pdf
@ Steely Dan: However it says immediately after the spring is released, the kinetic energy is 50 J so wouldn't the spring energy be entirely transferred at this point? I don't think that's relevant. If it is, how could it affect the answer?
@ Lawrence: All the Math works out correctly forward and backward.
I'd say that that answer is wrong. After all, X is the lighter and thus faster mass so it must have greater KE.
It looks like they mixed up X and Y. :wink: (Try solving it assuming: The mass of Y is 2/5 times the mass of X.)
i would say that they mean that beacuse of the frictionless surface both gain the same velocity. if they both have the same velocity but different mass , the one with the higher mass will have more kinectic energy.
and the answer 125 sounds then logical. if the velocity is a constant then the differense in kinectic energy is direclty proportional to the mass.
if the kinectic energy of X with mass 2/5 is 50 j , then 1/5 of the mass is 25 j, 25 j times 5 is 125 giving the kinectic energy of Y with "5/5" mass
That would contradict momentum conservation.
The above is wrong. The spring pushes on each with the same force because the ma of one is equal and opposite the ma of the other. Therefore the heavier mass will not attain as high a velocity due to a lower acceleration rate.
Im just saying that this is the only way the answer makes sence.
besides the way i understand it the conservation rule of mommentum applies when two objects collide , but here there is a third object , the spring , that is resposible for the eenergy provided.
( i just resently got aquinted with the momentum , so i may have understood it wrong , I am just saying that it makes sense and seems to be right according to the answer given )
Well, the assumption you must make here to use momentum conservation is that the spring comes to rest after the blocks are released (or that the momentum of both sides of the spring is equal and opposite, or that the momentum is negligible). If you do that, then since the spring was also at rest to begin with, you can use the approach of equal and opposite momenta to work out the final energy of block Y.
Edit: Actually, now that I've thought about it more, I guess the only valid assumption, if you want to get an answer, is that the momentum of the spring is negligible.
well , i think that this cannot be the case here. If you think about the objects as two fallen objects in vacuum ( as the surface is frictionless ) , the force acting on them is the same , gravitational pull ( anloguos to the energy given from the spring ) . The way you put it, it seems to me that you mean that two fallen objects will gain speed at different levels in vacuum , which is not the case. following from this order of ideas the two objects will accelerate at the same rate
It is possible for two objects to have different forces on them and to still accelerate at the same rate. This is the essence of the equivalence principle, after all. The object with more mass will have a larger gravitational force on it, but in its motion this is exactly compensated by the lesser propensity to be accelerated.
I agree , i just used the simplified version of Newtons law of motion. but from this it will still follow that both balls will gain the same velocity
It looks like they mixed up X and Y. :wink: (*Try solving it assuming: The mass of Y is 2/5 times the mass of X.)
That's what I was thinking happened, I noticed that* too.
But your answer violates the laws of physics! So what does it matter that it gives you 'the answer'?
You didn't use any version of Newton's laws of motion. You just assumed that the velocities would be the same.
That is only true for the special case of gravity, where the force happens to be proportional to the mass (so [itex]mg = ma[/itex] simplifies to [itex]g = a[/itex]). Spring forces are independent of the mass of the object ([itex]0.5 k x^2 = m a[/itex]), and are only dependent on the compression of the spring, so the resulting acceleration is indeed smaller, for the more massive object.
The problem clearly asked for the kinectic energy " immediatly after the spring is relesed " . which means that we are not talking about any acceleration process. The ball with higher mass has a higher inertia ,it resist the "push" from the string with a greater force , from this follows that the spring will have to "provide " more energy to this ball in order to go to its normal "resting" state " .Immediatly after the spring is released , both balls will have been "pushed" with the same velocity , but the one with more mass will have "gained" more energy.
The 'push' is the force from the spring, and force implies acceleration.
A ball cannot be 'pushed' with a velocity. It needs an initial force to induce that velocity.
These forces can be different for different bodies and still induce the same acceleration(without which there is no velocity as the ball starts from rest)
  • · Replies 22 ·
