Fukushima: Unit 2 Discharge - Why Differs from Units 1 & 3?
The discussion focuses on the differences in the discharge and containment failures of Fukushima's Unit 2 compared to Units 1 and 3, particularly in the context of the meltdowns and subsequent explosions. Participants explore the technical aspects of containment integrity, pressure dynamics, and the potential causes of emissions from Unit 2.
  • Meta-discussion
  • One participant notes that Unit 2 is responsible for over 90% of emissions and questions what was different about its failure compared to Units 1 and 3.
  • There is speculation that the corium from Unit 2 penetrated the reactor pressure vessel (RPV) and caused a blowdown to the torus room or the second floor, potentially leading to a direct connection to the outside environment.
  • Another participant suggests that the explosions at all three units are closely associated with the actions taken to vent the primary containment (PC) and raises concerns about the reliability of pressure readings after the explosions.
  • Questions are raised about whether an actual explosion inside the containment caused its failure, with some uncertainty about the mechanisms involved.
  • There is a discussion about the operation of vacuum breakers in a Mark I system and their role in pressure equalization between the torus and containment building.
  • Some participants express frustration over the proliferation of threads on similar topics, suggesting that it complicates following specific discussions.
Participants express differing views on the necessity of separate threads for specific discussions, with some advocating for more focused threads while others believe it complicates the discourse. There is no consensus on the exact causes of the explosions or the mechanisms of containment failure.
Participants acknowledge the complexity of the Fukushima incident and the challenges in unraveling its technical dimensions, indicating that definitive conclusions about the events may be difficult to establish.
This discussion may be of interest to those studying nuclear engineering, safety protocols in reactor design, and the historical context of the Fukushima disaster.
  • #151
SteveElbows said:
OK well they used CAMS data to estimate fuel damage ratio and only time will tell if these estimates are any good. At this stage all we can say is that some people will accuse these estimates of being part of the 'much too positive' spin from the company, but I cannot judge what the reality is. The damage ratios sound a bit low given the estimates about meltdown we have seen since. Obviously this is old data and I mention it now only in connection with the way this particular discussion has evolved.
http://www.tepco.co.jp/en/press/corp-com/release/betu11_e/images/110427e19.pdf
The graphs in that document are another good visualisation of what I was saying about reactor 3 S/C CAMS being low too. And reactor 1 isn't exactly seeing huge numbers in the S/C.
I am left assuming that the analysis I questioned is using only the differing trends of D/W and S/C CAMS at a key moment to make a point, rather than the difference in magnitude of D/W and SC measured levels, and that it is to be expected that S/C levels will be lower than D/W ones? In this case the lack of measurements during crucial times for reactors 1 & 3 make it impossible to look for similar or dissimilar patterns at the other reactors, making it harder for me to evaluate the plausibility of his argument.
Well, I don't accept his argument at all. It is a double non sequitur: One cannot conclude from the observation of a decreasing trend of radioactivity in the suppression chamber that it must be leaking. And even if one could, as you have pointed out, one cannot conclude from observing a current leak in the S/C , that it was also leaking at some time well before that observation.
  • #152
Yeah. Mind you I am still interested in possible earlier leaks at reactor 2, but for different reasons.
Firstly there is that stuff I already went on about to do with them having to assume a leak to make their disaster modelling give pressure results that are in line with measured pressures.
And then there is the question of the reactor pressure in the period before fuel melting. How come reactor 3's RPV pressure was above 7 MPa for large periods of time, but reactor 2's was only 7.0 MPa the first time they measured it at 20:07 on the 11th, and was then only 6.3 or lower until the time that water level dropped and melting started?
  • #153
Yes. unit 2 and 3 seem to be very much twin sisters as regards size and equipment. Comparable periods for your question on pressure developments could be, say, from the earthquake until noon on March 14 in the case of unit 2, and from the earthquake until noon on March 12 in the case of unit 3. Overall it seems to me that somehow reactor 2 utilised its limited heat sinks more efficiently than reactor 3 during these first periods after the earthquake, and therefore was able to be held at a somewhat lower pressure. (Either that, or unit 2 had 'extra' sinks for the decay heat at its disposal)
  • #154
Thanks to tsutsuji for providing this paper:
http://sciences.blogs.liberation.fr/files/irsn_rapport_complet-fukushima-1-an-.pdf
On page 46, there's a table where IRSN lists its release estimates. For Cs-137: Unit 1 1 PBq, Unit 2 6 PBq, Unit 3 14 PBq. The NISA estimate which makes Unit 2 responsible for 90% of the release is right below it, so IRSN has to be aware that the japanese think otherwise. Perhaps they are explaining why somewhere in the text...?
Unfortunately, I don't understand a single word french...
  • #155
The study does not give a specific explanation of the differences, but blandly notes it and moves on to note that the overall results are comparable.
However, it is possible to infer that because the winds were onshore while #2 was emitting, shifting to offshore when #3 was the focus ( discussion on p50), reactor 2 was responsible for most of the land pollution damage.
The estimates given in Science were for the total site emission, yet even those cover a factor of 3 range, so much better estimates will be laborious to obtain.
  • #156
From the recent torus room survey, the radioactivity of the room is very high everywhere, but particularly so in two of the surveyed areas, one area at the door entry level to the NE corner of the torus room, and another at the inspection level at the NW corner.
The simplest explanations I can think of are, respectively, that the door entry level is just closer to the surface of the accumulated highly radioactive water below, while the hotspot in the NW corner could be because there's a leak to the torus room from the PCV, somewhere above the waterline of the torus room, either a leak from the torus, or directly from the PCV.
Also interesting is that we see some damage to insulation around pipes several places, the shape of which seems to indicate they've been exposed to some low key event of internal overpressure, or external vacuum, relative to the insulation capping of those pipes. But really nothing serious of an explosive nature seems to have happened in the room.
  • #157
Unless interesting new information emerges, for now I am going to stick with the conclusion that reactor 2 released more radioactive substances because of a failure to wet-vent.
On page 152 of Tepco's interim report, they manage to make this point without actually drawing attention to high releases from reactor 2:
http://www.tepco.co.jp/en/press/corp-com/release/betu11_e/images/111202e14.pdf
[Action plan 3: Impact mitigation measures after core damage]
A large amount of radioactive materials will not be released if during PCV venting is conducted before core damage. In Fukushima Daiichi Units 1 and 3, the release of radioactive materials was reduced by releasing radioactive materials by wet well (S/C) venting through a water filter after core damage occurred.
It can be said that taking measures to enhance the certainty of venting in strategy 2 will also be effective after core damage has occurred.
Also, in order to cool the PCV, procedures that enable water injection to the PCV will need to be prepared in addition to water injection to the reactor through fire engines, etc.
  • #158
SteveElbows said:
Unless interesting new information emerges, for now I am going to stick with the conclusion that reactor 2 released more radioactive substances because of a failure to wet-vent.<..>
Can you sketch out, please, the main pieces of evidence and the thoughts that gave them order, which made you come to the conclusion that Unit 2 released more radioactive substances than Unit 3?
  • #159
I won't be repeating all of that since I posted so much in this thread already. I have acknowledged that it is possible to underestimate the release from reactor 3 due initially to wind direction, and then because it could have got mixed up with events occurring at reactor 2.
So no, I cannot be absolutely sure that reactor 2 released much more than reactor 3. We have a range of reasons why it might of, some of which I found quite compelling. Given the timing of the melt, failure to vent, pressure the containment was under and likely contents of its atmosphere when it started to leak in a vigorous fashion, I have no trouble with this conclusion, although I am always ready to change it or learn more if the chance presents itself.
One way which we may further explore the differences between reactor 2 & 3 is by looking at the timing of the release of substances from the fuel, and the timing of vents. If we would expect the bulk of the substances to enter the atmosphere of containment during the main initial fuel melting, then scrubbing that via a wet vent before containment leaks in a major way should make quite a large difference to how much stuff enters the environment. This is not a subject I have expert knowledge in so I would like to know more about the timing of releases from fuel.
  • #160
Yes, it would seem unfair to neglect giving unit3 some credit from the observed significant higher on-site deposition in the track of the unit 3 explosion cloud, towards the ocean. It is difficult to imagine that deposition stopped at the waterfront, but it is difficult to quantify that emission, to come at same terms as the measurements from the on site monitoring points. However, no unit would be a serious contender to the title if it could not bid in on the large contamination events that followed and showed up in those measurements. As you indicate, unit 3 as well as unit 2 could do that.
I understand your point, but how can we be certain, that melting of the fuel did not proceed in stages in either or both of the reactors, and continued after the point when both reactors had more or less free exhaust from the PCV to the atmosphere. (Unit 3 will of course claim to have had the freeest and most vigorous exhaust, and to have colored it in all nuances from white to black :-)
It would seem to me that the 5th floor of unit 2 should have functioned as a condenser and retained a significant fraction of radioactive material within its walls, on the assumption that the route of the assumed bulk of the total radioactive material emitted from the plant did pass though that space.
  • #161
Well I believe that this and numerous other details that are of interest to this thread, have been at least briefly mentioned by TEPCO in their new report of release estimates.
However at the time of writing it is only available in Japanese, and computer translation of this document in particular gave quite horrible results in many places. So I really need to wait for better translation before discussing any of these details further.
http://www.tepco.co.jp/cc/press/betu12_j/images/120524j0105.pdf
  • #162
OK I've had to make do with machine translation because it doesn't sound very likely that TEPCO will be translating the full document, only the shorter ones.
I will talk on the main thread about the report as a whole as it obviously deals with all reactors, but from what I think I've been able to make sense of in relation to reactor 2:
Even though they are unsure whether the vent took place, they seem to be focussing far more on the March 14th wet vent attempt, rather than the very brief dry vent attempt just after midnight on the 15th. Probably because of ability to speculate a link between increased site dose rates and the wet vent attempt, quite a large amount of emissions are pencilled in as occurring during this time and coming from reactor 2 (see table on page 9). That table is interesting for many other reasons also, including the fact that these figures are probably more in line with some peoples expectations in terms of which reactors are to blame for radioactive release - reactor 3 (and to a lesser degree reactor 1) gets a much larger share of the blame in this table, reactor 2 totals are still rather large but don't make other reactors irrelevant by comparison.
When they talk of soil contamination, March 15th reactor 2 emissions are the main focus for reasons we already discussed before. They have various diagrams showing wind direction and presumed plume path during variety of different venting operations, and they have the rain radar images from late on the 15th to the north west.
In regards to non-vent leaks, they talk about such matter quite a bit. They acknowledge steam escape from top of containment. Here is the original Japanese for a key part of the detail on this as it pertains to reactor 2:
1.3.2 2 号機原子炉直上部からの蒸気確認
平成 23 年 9 月 17 日に、2 号機 R/B のブローアウトパネル開口部からダストサ
ンプリングを実施した際に動画を撮影したところ、原子炉直上部から蒸気発生が 確認された(別図 3)。具体的に蒸気がどこから漏えいしているのか現時点では確 認出来ていないが、動画映像から蒸気の漏えい箇所としては原子炉の上部に位置 する PCV トップヘッドフランジ上部の原子炉ウェル上蓋付近からであると推定さ れる。また、使用済燃料プールの温度が高くない(平成 23 年 9 月 17 日時点で約 34°C)ことから、確認された蒸気は PCV から漏えいしてきたものであると考えら れる。PCV トップヘッドフランジ(及び原子炉ウェル上蓋)の構造は 1 号機、3 号機とも 2 号機と同様であり、1・3 号機でも 2 号機と同じ PCV 漏えいパスが存 在している可能性が考えられる。
さらに、現在判明しているR/B内の空間線量測定結果によると、R/B5階で確認 された高線量(約200mSv/h)は、4階以下では確認されていない(別図4)。2号機 はR/B構造が維持されており、線量の分布と漏えい経路には相関性があると考えら れることを踏まえると、5階からの漏えいが主たるものであったことを示唆してい る。
  • #163
I think the reason is much simpler: there's a measured peak in dose rate at the main gate MP in the evening on March 14th, but none after midnight. When there is no peak in published MP data Tepco can freely assume there is no emission. Otherwise of course, when there is a published peak.
As regards the peak in the evening of March 14th, using Google Translate, I glean from the note that Tepco is assuming it came from exhaust stack 1+2, because the emission point is unknown.
If that is the evidential standard, I am pretty sure I can mount better evidence for the proposition. that the March 14th evening peak was due to emissions from unit 3.
  • #164
I am pretty sure I can mount better evidence for the proposition...
Why Doc - surely you don't think attention was ever directed away from unit 3 !
old jim
  • #165
Lot of discussion is going on why maximaum radioactive material was released from unit 2 of Fukushima. Pirma facie it looks surprising even unbelivable as unit 2 building is least damaged, no hydrogen explosion took place in unit 2, its cooling system (RCIC) lasted for 70 hrs after the earthquake, core damage started later as compared to other units and no venting was done from unit 2 containment. Then why more radioactive material got released from unit 2 than oter units. Answer of this is very simple, that is, because no venting was done or could not be done from unit 2 containment.
As no venting could be done from unit 2, its containment got pressurised and it failed due to overpressure. Venting could not be done as rupture disc in hardened vent header did not rupture. Containment failure took place at weakest links such as penetrations, seals and gaskets. Activity released from drywell through these leaky points and came into reactor building. From reactor building it came into atmosphere through blowout panel of reactor building which had got opened during unit 1 hydrogen explosion on 12th March. Since release was from drywell, it was unfiltered release and that too it was ground level release. It is a case of 'suppression pool bypass'.Because of failure of containment penetrations, water injected for core cooling came into turbine building through pipe trenches/cable trenches and it contributed in release through water route. In contrast, containment venting could be done in unit 1 and unit 3. This venting was done from suppression pool air space. Radioactive material coming to suppression air space has to pass through suppression pool water. During this passage much of the radioactivity (around 99%) is filtered out. Water acts as filter in this case, since most of the volatile fission products like cesium, iodine, telerrium get dissolved in it and particulates get suspended in it. Remaing 1% contains mostly noble gases which get dispersed in atmosphere, do not dissolve in water/rain and thus do not fall out on the ground.
One line answer to the question why maximum radioactivity was released in atmosphere from unit 2 is that "Activity released from unit 2 was mostly unfiltered while from unit 1 &3 it was mostly filtered."
  • #166
Too bad we have no evidence for this most parsimonious and elegant hypothesis which has been discussed. Or do we?
  • #167
Pl give rationale for your comments. If you want to prove someone wrong then prove it by logic not by nasty comments.
Sharma sk
  • #168
It does not seem to me to follow from the fact that there were filtered vents from e.g. unit 3, that the majority of activity released from that unit was filtered. Looking at things from the plant monitoring posts, any contender to the title of most polluting unit would need to claim the lions share of the major emission observed during the morning of March 15th. Photos show Unit 2 as well as Unit 3 steaming at that time presumably directly from their leaking containments. I can see no good reason to think that the steam from unit 3 was at that stage particularly more 'clean' just because successful filtered vents were done in that unit on March 13th. This would seem to me to be like assuming that most of the core damage in Unit 3 should have preceded those vents.
  • #169
Sharma sk
MadderDoc is much more polite and well-spoken than me and he has spelled it out. I will point out also that, although it does not appear to have done anything spectacular on the 15th, Unit 1 is the only one which had to be covered with a tent. Might the most contaminated unit have been also the most polluting, overall?
Point is, without extensive information that would allow us to piece together something close to the real accident sequence, we can't really tell. Speculation is (VERY uncharacteristically for this forum) allowed by the mods in the Fukushima technical threads. But, it should be clearly understood as such.
  • #170
I think this particular stuff goes beyond the usual unsubstantiated speculation though. Yes there are many questions remaining, but those who are not very keen on the idea that reactor 2 released more into the environment than the others might want to investigate the following sort of thing further:
Given that the failure to wet-vent at an important moment is key to this theory, can't someone look into details about when the most significant amounts of radioactive material is expected to be present in the atmosphere and steam from containment?
Because left to a common-sense rather than proper scientific view of this issue, I certainly don't have any trouble believing that the time during and immediately after the core is completely exposed is a rather crucial one. And at reactors 1 & 3 we had wet-venting operations conducted in the aftermath of the core uncovering, and before we saw evidence of steam rising from upper containment failures.
The other factor is the pressure of containment at the time of failure & mass ejection of steam etc.
These are the reasons I am not going to reject the hypothesis that reactor 2 had far more significant environmental implications, although as discussed in the past this is complicated by the fact that weather factors meant any releases from reactor 2 were far more likely to have an impact on Japanese land.
  • #171
http://www3.nhk.or.jp/news/genpatsu-fukushima/20120724/2000_roatsu.html Shinichiro Kado of Tokyo university and Masamichi Chino of JAEA studied accident response records and radiation doses in the surroundings and concluded there is a high probability that radiations were released from unit 2 while the operators decreased reactor pressure by opening the S/R valve. 3 radiation peaks were observed at the Fukushima Daini plant, located 10 km away in the South, during the 5 hour lapse of time after 10:00 PM on 14 March 2011. Each peak happens about one hour after the S/R valve was operated. According to the specialists, there is a high probability that radiation was released through damaged parts of the PCV and reached Fukushima Daini by being carried by northerly winds. According to simulation results, the release from unit 2 is about 10 to 20 times greater than that after unit 1's hydrogen explosion and it was carried to the Kanto region in the morning of March 15.
http://enformable.com/2012/07/tepcos-do-or-die-mission-to-save-a-nuclear-reactor-may-have-caused-largest-radiation-leaks-during-fukushima-disaster/ An English article about this same Masamichi Chino study.
  • #172
Thanks for the info, that study does seem to match some of the speculation we engaged in, in regards to venting and radiation levels further south over that crucial time period. I wish I could find more reports about this study, or even the study itself, any ideas where to look?
  • #173
As Masamichi Chino made a presentation at the workshop of 23/24 July ( http://www.nisa.meti.go.jp/shingikai/700/14/240723/AM-3-3.pdf ), I was hoping there would be more details in the workshop papers, but it seems to be something different. I tried to google both names (Shinichiro Kado and Masamichi Chino) in Japanese writing, but google did not provide helpful answers.
  • #174
There is a bit more here:
http://genpatsu-watch.blogspot.com/2012/07/20127241800.html Transcript of Tepco's press conference on 24 July 2012:
NHK's Gotoh:
Concerning unit 2 it is said that the greatest amount of radioactive releases took place 4 days after the accident on 15 March. A variety of reports have been compiled, but specialists say that when they check the records of the response and Tepco's records, exactly from 3 days after the accident in the night of 14 March to the next day 15 March where large quantities are supposed to have been released, it is recorded in Tepco's documents that the SR valve was pretty repeatedly operated. Also, at that time, in the SPEEDI records, winds are found to be blowing toward the south, and when one checks the radiation doses at Fukushima Daini nuclear plant at that time, in the night of 14 March, against the normal 0.03 μSv/h, at around 10:00 PM it was 7.95μSv/h, then at 00:00 on 15 March it became 95μSv/h. After that, the radiation never stopped step by step sharply rising, and it is pointed out that radiations rose one hour after SR valve changing operations, and when one checks the wind directions after that, by looking at the accident response records and so on, the people who make that remark suggest that there is a high probability that due to the operation of unit 2's SR valve, the radiations blew toward the south and this raised unit 2's monitoring post values. Are you grasping this point?
Matsumoto:
I am not aware that the point that you said etc. was raised, but if we look at the time series of radiation releases in our previous reports, we infer that the releases from unit 2 became greater on 14 March at 21:20, well, from late in the night.
From a little after 21:00 on 14 March to 15 March, basically on 15 March over nearly one full day, we suspect that it was a release from unit 2. From the perspective of the accident situation at unit 2 at that time, core damage was quickly progressing, large volumes of radioactive substances were inside the RPV... well, it is a situation where they come out of the so-called cladding tubes. As a result, when the safety relief valve was opened, at that time, gas substances were released into the PCV. As the PCV has high temperature and high pressure, for example the flange, the seal parts suffer damage, and we think the radioactive substances have probably rapidly come out into the building. Then, at that time, the blow-out panel was already open, and the route is from there toward the reactor building eastern side, so it was probably released that way into the atmosphere.
NHK's Gotoh:
At present it is considered only as a possibility, but temporally, unit 2's radiation doses are said to have risen sharply in the night about one hour after. In the surveys you did until now, have you been matching [these data] with Fukushima Daini nuclear plant's radiations ?
Matsumoto:
No we haven't. In the future, well... I think it is probably necessary to compare the trend of radioactive releases with the meteorological conditions.
According to the radioactive release report released on 24 May ( http://www.tepco.co.jp/en/press/corp-com/release/2012/1204659_1870.html ), if we say that the release started at 21:00 on 14 March, as the wind was blowing toward the south, the Fukushima Daini plant beeing right in the south, that the radiation dose rose is... well... in a sense... it is matching. That's our line of thought. Well, it is after it. On 13 March at 09:00, 12:00, 20:00 here we compared the venting timing of unit 3, and well, we did a little analysis. Well, basically, it seems that it was a wind blowing to the south, so it is quite logical that Fukushima Daini's monitoring post radiation doses rose, I think.
NHK's Gotoh:
Do you think that it is necessary to perform this kind of data matching/comparison in the future ?
Matsumoto:
I think this kind of survey, or rather verification, will be necessary in the future. However, the analysis code we have, "Diana", is not able to perform analysis over such a wide area, so I think we will need to receive the cooperation of an outside laboratory.
NHK's Gotoh:
At that time it was necessary to operate the SR valve, but as a result of operating the SR valve...
Matsumoto:
... what do we feel about the fact that there is a high probability that it caused the outside release of large quantities of radioactive substances?
Concerning Fukushima Daichi unit 2, of course we suspect that venting the PCV, especially the wet well venting via the pressure suppression chamber was not sufficiently performed...
Matsumoto:
Well, I think this is probably the main point. At units 1 and 3 we succeeded in wet well venting, and as a result the concentrations were about one hundredth. At unit 2, well..., as regard the causes, we suspect that an important factor is the fact that things did not go smoothly with the connection of batteries and compressed air taking a lot of time.
NHK's Gotoh:
Thank you.
  • #175
A hundredth of what? Does he mean a hundredth of what was seen at unit 2? Why is he talking "concentration"? Does this mean someone was measuring the steam, in real time?
  • #176
It is rather vague. Perhaps he means that, roughly speaking, for every particle released into the atmosphere 99 particles remain in the water if the wet venting is done properly.
  • #177
That's what I thought too - but I know better than to rely on my linguistic intuition wrt a translation from language I don't speak at all. So, thanks.
  • #178
Thanks so much for that, it is good to see this information. Its an explanation we have come up with ourselves before, and have seen so briefly mentioned in a few reports, but usually not very well explained in such reports, or only acknowledged in a very round about manner.
Likewise we have also heard more recently about the concerns about reactor 2 at the time, due to the publication of its of the TEPCO videoconferences, and reactor 2 got quite a lot of press attention because I am under the impression that the footage from the 14th March was the only one with sound, and because there is still controversy and questions about TEPCOs worker evacuation plans.
Again the concerns about not being able to vent and the state of the suppression chamber on the 14th have been mentioned before in other reports. However there still exist a range of possibilities as to which concern the various people in charge were most afraid of, eg that made them consider evacuation more at this moment than prior ones. Was it the fact they hadnt been able to scrub via wet venting, the possibility of the meltdown being very bad due to inability to inject water for a very long time due to high pressure, fear of dramatic or explosive s/c damage or d/w damage? In one report the emphasis was on the site managers concerns about the suppression chamber, but from the teleconference it sounds like at least one persons big fear was for the drywell. It is unclear whether they feared the sort of drywell leak that actually ended up happening, or an even more dramatic one that could rip the drywell apart. These more explosive imagined scenarios might explain the attention on evacuation.
As for the exact path of release for the reactor 2 releases at the various times, there is still disagreement. We can be fairly confident about the drywell releases that happening on the morning of the 15th, but the path of release from 21:20 on the 14th and throughout much of the night is less clear. We had questions about whether any of the vents may actually have happened (rupture disc status unconfirmed and shared stack contaminated so can't be sure). At least one of the tables showing estimated magnitude of releases at different times has the night of the 14th large release coming from the height of the stack, and only the later releases from the height of the building. Others such as Matsumoto that you just quoted are suggesting the releases came from the drywell that night. And the author of the study behind a paywall ( at http://www.tandfonline.com/doi/abs/10.1080/00223131.2012.669237#preview ), thinks it was the suppression chamber that leaked on the night of the 14th and the drywell didnt start to spew significant quantities of stuff till the morning of the 15th. The question is further complicated by those who have theories that damage had occurred days earlier, and although no prior damage is necessary to explain the later emissions, we cannot utterly rule these possibilities out at this point.
I don't necessarily expect to learn much more of interest about the top of the drywell, so to narrow down some of the above possibilities I will be hoping to learn more about the stack contamination, rupture discs, and the exact nature of any suppression chamber damage at some point.
  • #179
What would be the path if the theory that the timing of radiation peaks at the Daini plant is correlated with the timing of SR valve operation is true? Under that theory, at that time, something was damaged downstream the SR valve, while the RPV upstream was still OK? For the contaminated gasses to go from the SR valve to the outside without passing through the wet well, you need two kinds of damage : a damage of the pipe between the SR valve and the wet well, and a damage of the dry well. That sounds rather complicated, or am I missing something ?
I have the same question for this Tanabe theory. What is the meaning of "suppression chamber... leaked" ? I can understand that if there is a hole through which water escapes, the water level might become too low, and the "wet well" not being wet enough, the scrubbing function fails. Otherwise, I don't see the difference if the gasses escape through a hole in the upper part of the wet well after being scrubbed. Does that make any difference with being released through the stack ? In other words, does Tanabe say that the suppression chamber released a) liquids b) unscrubbed gasses or c) scrubbed gasses ?
  • #180
He mentions large amounts of steam with radioactive materials flowing into the S/C water pool. And that large amounts of radioactive materials which escaped pool scrubbing could then have escaped through S/C breach. However he does not go into any detail about the breach, or how the materials escaped pool scrubbing.
Various people have already criticised his theories here, and its also worth noting that his study was in part a response to analysis modelling where, in order to get the modelling estimates for D/W pressure over time to match the actual recorded values, they had assumed both a drywell breach and a S/C breach of certain sizes occurring days before the 14th. But since then they have developed a different theory, to do with cooling effects of water in torus room, and thermal stratification of the S/C. eg pages 11-16 of this http://www.nisa.meti.go.jp/shingikai/700/14/240723/AM-1-2.pdf and then pages 27-35 dealing specifically with how this may apply to reactor 2 data. So I think his study is already out of date.
In other aspects his study was still of interest to me, just because it lays out a possible timetable for various sorts of melting in the RPV & drywell in a fairly clear way which many official reports somewhat avoid or get the timing wrong on. In particular he is not afraid to point out the various times that RPV pressure went too high for pumped water to reach the RPV, which ends up offering an explanation for why we didnt see steam coming from upper part of reactor 4 till after 8am, and a possible remelting of core material on the afternoon of the 15th.
  • · Replies 23 ·
  • · Replies 18 ·
