Hypothesis: Tugging from the Sun to Earth Faster than Light?
  • Context: Graduate
  • Thread starter Thread starter BenWillcox
The discussion revolves around the hypothetical scenario of a solid rod extending from Earth to the Sun and whether a tug on one end would result in an instantaneous pull felt at the other end, potentially faster than the speed of light. Participants explore the implications of rigidity, elastic deformation, and the limits imposed by relativity on such a scenario.
  • Some participants propose that the concept of a perfectly rigid object is not feasible, as all materials exhibit elastic deformation over significant distances.
  • One participant mentions that the speed of the pulse along the rod, even if made of diamond, would be substantially less than the speed of light due to the material's properties.
  • Another participant introduces the idea that the speed of sound in materials is the relevant speed for such a pulse, suggesting that this speed is a limiting factor.
  • A later reply discusses the implications of extending such a rod to the nearest galaxy and questions whether the metric expansion of space would affect the scenario.
  • Some participants reference the principles of relativity, indicating that information cannot travel faster than light, which imposes limits on the rigidity of objects.
  • One participant connects the discussion to astrophysical phenomena, explaining how the collapse of white dwarfs into neutron stars relates to the loss of stiffness when particles move at relativistic speeds.
Participants generally agree that a perfectly rigid object cannot exist and that any deformation would propagate at a speed less than that of light. However, there are competing views regarding the implications of extending such a rod to astronomical distances and the effects of metric expansion of space, leaving some aspects of the discussion unresolved.
Limitations include the assumptions about material properties, the definition of rigidity, and the unresolved mathematical aspects of how deformation propagates through materials over large distances.
BenWillcox
I thought of this today...
Suppose a solid rod of diamond (so there would be no slack) existed that extended from Earth to the distance of the sun. For example, someone at a location the distance of the sun away would be holding one end of the rod, while the other end would be held by a person on earth. IF the person at the distance of the sun tugged on the rod, would the person on Earth feel a pull instantly? If light takes 8 minutes to travel from the sun to earth, couldn't the kinetic energy of this tug be felt by the person on Earth at a rate faster than the speed of light?
Of course none of this is possible and obviously isn't true, but I'm wondering why this wouldn't occur faster than the speed of light.
Thanks,
Benjamin Willcox
Astronomy news on Phys.org
Hi Ben
welcome to PF :)
what is your reasoning as to why would you even think the pulse along the rod would travel faster than light ?Questions along these lines pop up quite regularly here. the other variation is someone striking one end of a very long rod.
cheers
Dave
Thanks for your reply Davenn, I don't understand what you mean by pulse. Here is a picture I drew up to help explain it better:
The is no such thing as a perfectly rigid object. The other end of your diamond rod would always move at much less than light speed. The bulk modulus is the property that defines rigidity of an object. The bulk modulus of a diamond is only about twice that of aluminum.
Neutron stars represent the upper limit for rigidity of materials in the universe. In fact, limiting the speed of sound to c actually gives the basis for calculating the maximum theoretical mass of a neutron star - re: http://arxiv.org/abs/astro-ph/0011107
BenWillcox said:
Thanks for your reply Davenn, I don't understand what you mean by pulse. Here is a picture I drew up to help explain it better:View attachment 47177
yup I knew what you meant :)
by pulse I mean, when the rod is pulled, pushed or hit at one end there is going to be a pulse of that motion that moves along the rod towards the other end.
even for a rigid material like diamond, over any significant distance, its still going to exhibit an elastic deformation along its length. This is something that is valid even when looking at the Earth as part of solid Earth geophysics, on a small scale rock acts very solid but on large scale it quite happily deforms elastically.
So when you pull on one end of your rod its going to produce an extensional elastic deformation (if pushed or hit it will produce a compressional pulse) that will travel as a pulse along the length of the rod
And I would suggest that the speed of that pulse is substantantially less than the speed of light.
Maybe some one else may know the formula /maths for worthing that speed out ??
not in my field of expertise
hope that helps you visualise what is happening
cheers
Dave
russ_watters said:
BTW, that speed is the speed of sound.
Thanks Russ
I suspected that was the case, but wasnt sure so didnt post
Dave
We have an FAQ on this question https://www.physicsforums.com/showthread.php?t=536289
Thanks Ryan
didnt know that one existed
D
cheers
Dave
what if you could extend that rod to the nearest galaxy moving away from us due to metric expansion of space :confused: does it stop that weird phenomenon
It would probably be stretched by the two galaxies rushing away from each other, then broken when it can't take any more, I'm guessing.
Because relativity puts limits on how rigid an object can be. Since information can't travel faster than light, there's a limit on how stiff an object can be.
This is why white dwarfs collapse into neutron stars. Once the electrons start moving at the speed of light, they lose stiffness, and the star collapses. This is also why everything collapses to black holes. Once you compress anything to the point where things are moving near the speed of light, it also loses stiffness and things collapse.
  • · Replies 17 ·
  • · Replies 57 ·
  • · Replies 49 ·
  • · Replies 24 ·
