| New Reply |
Creating FORTRAN Libraries |
Share Thread |
| May17-12, 01:29 PM | #1 |
First time poster... I am trying to create fortran libraries for a test code I am writing. I had some success in doing so with a few examples from (specifically the kronrod src files):
john burkardt website (sorry I can't post URLs) I would like to create a library from a file "electron_interactions.f95" that contains functions which are called by the main source. This is not an issue as long as I remove the global variables that are used throughout "electron_interactions.f95." This is what the commands look like in terminal: g95 -c -g electron_interactions.f95 ar qc libelectron_interactions.a electron_interactions.o mv libelectron_interactions.a /Users/David/lib/ g95 -c -g test.f95 g95 test.o -L$HOME/lib/ -ltest mv a.out test Where test.f95 is some main program calling the functions contained in the library. Is it possible to create a library from a module that stores global variables, so I don't have to remove them to build the executable test? Currently, I have src files with "use global" everywhere I want to access these variables. I wind up needing a nasty makefile. |
| New Reply |
| Tags |
| fortran, library, linking |
Similar discussions for: Creating FORTRAN Libraries
| Thread | Forum | Replies | ||
| Fortran Builder 5.2 and Nag libraries | Programming & Comp Sci | 0 | ||
| Fortran 90 creating an array of unknown size | Programming & Comp Sci | 3 | ||
| Fortran: creating array containing characters | Programming & Comp Sci | 1 | ||
| Accessing Fortran Modules within a Fortran library from Fortran | Programming & Comp Sci | 0 | ||
| SGI libraries | Programming & Comp Sci | 0 | ||
