New Reply
convert stretech ratio to engineering strain, reasonable?
Share Thread
May17-12, 07:11 PM   #1
Hi, Dear all,
Currently try to modelling the unibixial tensile loading in some software.
We know that when you stretch something, it will generate stress. Then we will have stress-strain relationship.
I also read something about stretch ratio, which as defined in wikipedia
"The stretch ratio or extension ratio is a measure of the extensional or normal strain of a differential line element, which can be defined at either the undeformed configuration or the deformed configuration. It is defined as the ratio between the final length ℓ and the initial length L of the material line."
http://en.wikipedia.org/wiki/Deformation_(mechanics)
e(engineering strain)=λ(stretch ratio)-1.
Is it reasonable for me to convert the stretch ratio data set to engineering strain for application in abaqus or ansys in engineering real application?
i am worried it may have negative effect on my modelling when i do it, so need your advices.
Thank you.
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
New Reply
Similar discussions for: convert stretech ratio to engineering strain, reasonable?
Thread Forum Replies
Convert Strain gauge readings to stress General Engineering 0
Engineering problem (uses stress, strain, Young's Modulus) Engineering, Comp Sci, & Technology Homework 0
How to convert force displacement curve to stress strain curve Engineering, Comp Sci, & Technology Homework 1
Materials Engineering (Crystal Structure) - C/A Ratio? Engineering, Comp Sci, & Technology Homework 0
What is a reasonable end user/tech support ratio? Computing & Technology 0
