| New Reply |
Need a rigid insulation material??? |
Share Thread |
| May26-12, 08:49 PM | #1 |
I have a project that requires insulation sheets that are rigid and difficult to compress, about 1/8" thick. I was thinking about some type of ceramic material but can't find anything in that thickness. I'm not looking for some type of exotic material, just something I can get from grainger or mcmaster.
I was looking at using this polyimide material but not sure how compressive it would be. |
| PhysOrg.com |
engineering news on PhysOrg.com >> Multiview 3-D photography made simple >> Giant 3-D printed bugs shed light on insect anatomy >> A microphone that listens with light |
| May26-12, 10:25 PM | #2 |
ordinary teflon sheets are commonly available, fairly rigid, good electrical insulators, and dense enough to resist physical compression.
| May26-12, 10:43 PM | #3 |
Bobbywhy's idea is good if you are looking for electrical insulation.
But if you are looking for thermal insulation you have two good choices. Both the choices are basically the same, but from two different products sold by two different sources. One is to use foam core material sold though marine suppliers for boat building. The other is to find a large refrigeration contractor, one that would take a contract to insulate a warehouse for refrigeration. They use many different types of sheet foam. You would be looking for the variety they put on the floors that the forklifts drive over. |
| May26-12, 11:32 PM | #4 |
Pkruse, Thank you for your comments. Too bad I assumed the OP was looking for "ELECTRICAL" insulation sheets. Now, it seems you are guessing the OP was looking for "THERMAL" insulation sheets.
Topher925, will you please be specific? Exactly what kind of insulation are you seeking? Cheers, Bobbywhy |
| May27-12, 02:36 PM | #5 |
| New Reply |
Similar discussions for: Need a rigid insulation material???
| Thread | Forum | Replies | ||
| Measurement of material displacement using recorded material thermal data | Materials & Chemical Engineering | 3 | ||
| Ideal Material for a model rigid airship | Materials & Chemical Engineering | 2 | ||
| Rigid, Non-Rigid and System of Rigid Bodies??? | Advanced Physics Homework | 0 | ||
| thickness of insulation material | General Engineering | 1 | ||
| Material Science, Material Selection Question | Engineering, Comp Sci, & Technology Homework | 1 | ||
