Black Holes: Infalling Observers and BH Evaporation
The discussion revolves around the nature of black holes, specifically addressing the behavior of infalling observers and the implications of black hole evaporation via Hawking Radiation. Participants explore theoretical aspects, observational paradoxes, and the effects of time dilation near the event horizon.
  • Some participants question how an infalling observer can cross the event horizon if black holes evaporate in a finite time from an outside observer's perspective.
  • It is suggested that the appearance of an object never entering a black hole is an optical illusion due to the time it takes for light to reach an outside observer.
  • One participant asserts that an infalling observer does reach the singularity in finite time, contrasting with the perception of freezing at the event horizon.
  • There is a discussion about the time it takes for an observer to cross the event horizon, with some suggesting it is simply a function of distance and speed.
  • Some participants argue that black holes are currently accreting matter rather than evaporating, with future evaporation dependent on temperature exceeding the cosmic microwave background radiation (CMBR) temperature.
  • Disagreement arises regarding the presence of Hawking radiation, with some asserting that it exists but is negligible compared to infalling matter.
  • Concerns are raised about the effects of tidal forces and spaghettification for infalling observers, particularly in relation to the size of the black hole.
  • Time dilation effects are discussed, noting that the perception of time for an infalling observer differs significantly from that of an external observer.
Participants express multiple competing views regarding the nature of black hole evaporation, the experience of infalling observers, and the implications of time dilation. The discussion remains unresolved with no consensus reached on several key points.
Participants note that the understanding of black hole behavior is dependent on various assumptions, including the definitions of evaporation and the effects of external radiation. There are unresolved questions regarding the mathematical treatment of these phenomena.
Drakkith
Mentor
Assuming that black holes do in fact evaporate via Hawking Radiation, how can an infalling observer ever get inside the event horizon if the black hole evaporates in a finite time from an outside observers frame?
Astronomy news on Phys.org
Think of it as an optical illusion.
It **appears** from an outsider observation that the falling object never enters the black hole, that's because light from the infall takes an infinite amount of time to reach the outside observer.
Does an infalling observer ever enter the black hole?
Yes, and they hit the singularity in finite time.
It's easiest to think of the apparent "freezing" of an object as it falls into a black hole as an "optical illusion". As something gets closer to the event horizon the time it takes for a light flash to make it to a distant observer increases. Once you cross the event horizon, the light never makes it out.
But if you try to flash the light to someone that is falling with you, then you'll see nothing unusual.
Approximately how long would it take for an observer to cross the event horizon?
The length of his body times his speed. It's just d=rt. The in-faller feller is not aware of the EH.
A characteritic aspect of BH of any size is that they are not actually evaporating these days but rather accreting as they absorb matter and energy. They'll likely begin to decrease in size when their temperature exceeds the slowly cooling CMBR temperature...currently around 2.73 degrees K some billions of years from now. And even then big BH will evaporate very slowly as the Hawking radition in inversly proportional to their size and such evaporation will take billions upon billions of years additional time.
Naty1 said:
A characteritic aspect of BH of any size is that they are not actually evaporating these days but rather accreting as they absorb matter and energy. They'll likely begin to decrease in size when their temperature exceeds the CMBR temperature...around 2.73 degrees K some billions of years from now. And even then big BH will evaporate very slowly as the Hawking radition in inversly proportional to their size and such evaporation will take billions upon billions of years additional time.
While I agree w/ the end result of events as you describe them, I disagree that there is no Hawking radiation at present. What there IS is a whole lot LESS Hawking radiation than there is infalling stuff, including from the CMB so that the net result IS as though the BH is not radiating. I don't think this is just semantics.
Sorry, I mean according to an outside observer. If that even makes sense since we can't see him fall in.
I don't think Naty meant that there is no Hawking radiation present, only that the BH will not evaporate until billions of years from now.
Ah ... I think the answer there is "forever" but that can't be quite right since it doesn't take forever for the BH to evaporate.
Yeah, I wasn't sure, thus my quibble.
Keep in mind the external universe is also time dilated from the infalling observers perspective. If the external observer ship sent a constant interval pulsed laser signal toward the hapless infalling volunteer, the time between pulses would increase as the infaller approached the event horizon. This is because the infaller approaches the speed of light as the event horizon is approached making it increasingly difficult for external photons to 'catch up' with the infaller.
I edited my wording above for clarity reasons but DID mean a black hole doesn't radiate now. [edit: I am wrong see below.] Does a black body cooler than it's surroundings radiate?? apparently so:
found the answer here:
http://en.wikipedia.org/wiki/Hawking_radiation#Black_hole_evaporation
Evaporation of a black body is not dependent on surrounding temps:
[you can find some formulas there]
The power in the Hawking radiation from a solar mass () black hole turns out to be a minuscule 9 × 10−29 watts. It is indeed an extremely good approximation to call such an object 'black'.
I withdraw my assertion...apparently, it does radiate but we can't observe it because it's so small.
Obviously it has no effect on the original question.
Separately,
two fish:
You can do that as a distant observer, but woe be to the free falling inbound observer who decides 'to stop and take a look' nearby outside the horizon...and accelerates there to remain stationary...The horizon is 'VERY real' there and the observer will be fried almost instantaneously by high energy radiation.
Naty1 said:
... no one in these forums has provded a reason why they should radiate
There was a long thread about this some time back if you're interested (sorry, I don't have a link), which is why I happened to remember about it. There was a strong assertion that there is no Hawking radiation when the BH is below the CMB temp, but that assertion was shown to be incorrect.
Chronos said:
... because the infaller approaches the speed of light as the event horizon is approached
I don't dispute this, but it leads me to a quesiton:
For really large BH's the infaller does not experience sphagettification at the EH, but that seems inconsistent w/ traveling near c. It seems to me that such a high speed would imply a strong tidal force. I have no great sense that I'm right about this, and I'd appreciate your comment on what I'm not understanding.
The acceleration gradient is very small at the EH of a supermassive black hole, which means [assuming you jump in feet first] your feet are not being accelerated much faster than your head. You would not be 'spaghettifed' until the parts of you nearer the singularity were subject to much greater acceleration than your more distant parts.
So the fact that you are traveling near c is irrelevant to the spaghettification? I guess that's the part I got confused on.
The effect of the infaller's speed relative to distant observers competes with gravitational blueshift of light/sgnals from distant observers. Both, taken separately, approach infinity. The ratio, is quite finite (I think about 2 for infaller's from infinity). The result is that infaller sees only modest shift and time distortion from distant observers. In particular, if an infaller counts pulses a millisecond apart as emmitted from a distant source, they receive a well defined finite number of such pulses before hitting the singularity, and they don't see the pulses becoming ever slower (as in the reverse case - the infaller sending millisecond pulses to the distant observer - these slow down by an unbounded factor as the infaller nears the horizon as perceived by the distant observer).
This doesn't contradict what you say, but I think it is important to emphasize the competing effects for the infaller, and the resulting asymmetry between infaller and distant observer.
An observer in free fall does not experience gravitational time dilation, as I recall. I am entirely open to correction on this point, if in error.
I'm pretty sure that no, traveling near c is unrelated to spaghettification.
I'm not 100%, ofc, but I don't see how a relativistic velocity can lead to tidal forces. If the traveler is accelerating to c... but then it would need to have different parts of his or her body accelerating at different rates, right? But since we're talking about a free-falling person falling into a supermassive black hole, I don't think that that will happen, according to my understanding, at least.
So back to the original topic. How long would it take for an infalling observer to reach the event horizon of a black hole? According to an outside observer, they would never reach it. But they would also disappear and never reappear as the black hole would evaporate over time and leave nothing behind. Am I correct?
Using whose clocks? They don't call it relativity for nothing... :-) :-) :-)
An outsider stationary observer would never see the object cross the event horizon.
Something like that.
But...
There are some theories of quantum gravity in which the Hawking radiation would be affected by the object crossing the event horizon. This is one solution to the black hole information paradox.
Calculated in the reference frame of the stationary outside observer?
Consider two observers, observer A that falls across the the event horizon and observer B that hovers at a finite "distance" above the event horizon, and two types of (uncharged) spherical black holes, a classical black hole that doesn't emit Hawking radiation and a semi-classical black hole that does.
For the classical black hole case, B "sees" A on the event horizon at infinite future time, and B never sees the singularity.
For the semi-classical black hole case, at some *finite* time B simultaneously "sees": A on the event horizon; the singularity. In other words, the singularity becomes naked, and A winks out of existence at some finite time in the future for B.
In both cases, A crosses the event horizon, remains inside the event horizon, and hits the singularity. In both cases, B, does not see (even at infinite future time) A inside the event horizon, as this view is blocked by the singularity.
These conclusions can be deduced from Penrose diagrams, FIGURE 5.17 and FIGURE 9.3 in Carroll's text, and Fig. 12.2 and Fig, 14.4 in Wald's text, or
http://motls.blogspot.ca/2008/11/why-can-anything-ever-fall-into-black.html.
This is one of my favorite explanations fromearlier discussions in these forums. I'm guessing this is the 'classical' version as described by George above...
[unsure which 'expert' originally posted this]
Won't it take forever for you to fall in? Won't it take forever for the black hole to even form?
Not in any useful sense. The time I experience before I hit the event horizon, and even until I hit the singularity-- the "proper time" calculated by using Schwarzschild's metric on my worldline-- is finite. The same goes for the collapsing star; if I somehow stood on the surface of the star as it became a black hole, I would experience the star's demise in a finite time.
On my worldline as I fall into the black hole, it turns out that the Schwarzschild coordinate called t goes to infinity when I go through the event horizon. That doesn't correspond to anyone's proper time, though; it's just a coordinate called t. In fact, inside the event horizon, t is actually a spatial direction, and the future corresponds instead to decreasing r. It's only outside the black hole that t even points in a direction of increasing time. In any case, this doesn't indicate that I take forever to fall in, since the proper time involved is actually finite.
You can say that if you also note that they don't experience speed related time dilation relative to a distant observer in the 'normal' way. That is, their effective relative speed compared to a distant observer should not be considered the same as their speed relative to a local stationary observer. To compare relative speed to a distant observer, pick some (non-unique) path over which to parallel transport their 4-velocity. Then you find that the transport through the gravitational well [of distant observer's 4-velocity] gives them (free faller) much smaller relative velocity compared to distant observer than compared to a nearby stationary observer.
Alternatively, for a simple geometry like SC, you can factor effects on a free faller into speed time dilation (symmetric) relative to a local stationary observer, and gravitational redshift/blueshift relative to a distant observer.
Either way, the upshot is that a free faller crossing the event horizon has only modest time difference compared to infinity [at the moment of crossing the horizon, from free faller's point of view], with the exact result depending on the free fall trajectory (that is, whether the fall is 'from infinity' or from a closer start).
Here is another perspective...but I don't like the word 'illusion' as it implies to me something faulty with that distant perspective when it is as valid as any other.
From Kip Thorne in BLACK HOLES AND TIME WARPS
when the star forms a black hole:
Finkelstein's reference frame was large enough to describe the star's implosion ...simultaneously from the viewpoint of far away static observers and from the viewpoint of observers who ride inward with the imploding star. The resulting description reconciled...the freezing of the implosion as observed from far away with (in contrast to) the continued implosion as observed from the stars surface...an imploding star really does shrink through the critical circumference without hesitation...That it appears to freeze as seen from far away is an illusion...General relativity insists that the star's matter will be crunched out of existence in the singularity at the center of the black...
and a related description [source unknown]
One often sees people interested in the question "where is the infalling probe "now"". For instance, they want to know if the probe has crossed the horizon "now" yet, or not. The best answer to this question is the same as it was in special relativity - there is no universal notion of "now" - the question is ambiguous. It may be slightly annoying to attempt to think of everything in terms of the raw data that one will actually receive (such as curves of redshift vs time), but this is really the safest course. Thinking of things in terms of "where the probe is now" will inevitably lead to confusion, because there is no universal definition of what "now" means, different observers will regard different points as being simultaneous even in SR, and this does not change in GR.
Here is another perspective [source unknown] :
... the Schwarzschild metric has a coordinate singularity at the event horizon, where the coordinate time becomes infinite. Recall that the coordinate time is approximately equal to the far away observer's proper time. However, a calculation using transformed coordinates shows that the infalling observer falls right through the event horizon in a finite amount of time (the infalling observer's proper time). How can we interpret solutions in which the proper time of one observer approaches infinity yet the proper time of another observer is finite?
The best physical interpretation is that, although we can never actually see someone fall through the event horizon (due to the infinite redshift), he really does. As the free-falling observer passes across the event horizon, any inward directed photons emitted by him continue inward toward the center of the black hole. Any outward directed photons emitted by him at the instant he passes across the event horizon are forever frozen there. So, the outside observer cannot detect any of these photons, whether directed inward or outward.
There's no coordinate-independent way to define the time dilation at various distances from the horizon—a clock is ticking relative to coordinate time, so even if that rate approaches zero in Schwarzschild coordinates which are the most common ones to use for a nonrotating black hole, in a different coordinate system like Kruskal-Szekeres coordinates it wouldn't approach zero at the horizon,
I can't find it, but "As the free-falling observer passes across the event horizon.." Leonard Susskind has explained the 'information' of the infalling object/observer gets 'smeared' across the horizon...so I continue to wonder if one could assume an image of the object remains on the horizon for that distant observer...while the actual infalling object/ observer continues inward, uninterrupted, in his own proper time.
Ah well, time to go and walk my Yorkies!
Interesting. Thanks all!
Yes. That bothers me too.
Maybe "perspective" or "vantage point" would be better term,
I believe Chronos explains this by noting that the horizon can be viewed as a light hypersurface...which is moving at lightspeed...I don't fully understand that perspective that but he's seem right about everything else.
edit: nope, its pervect:
"There's no such thing as a stationary clock at the event horizon... any clock crossing the event horizon must be moving at the speed of light - or rather, since the event horizon can be thought of as trapped light, any physical infalling clock, which is stationary in its own frame, will see the event horizon approaching it at the speed of light."One thing I do understand: Approaching a big BH from the exterior is no different than approaching a big dense planet...except, I guess, the BH is, well, black...the gravity itself [gravitational potential] is strong up close, but the gravitational potential gradient [the curvature of tidal force spaghettification] is nothing unusual. In other words, the gravitational gradient becomes extreme at the singularity not at the horizon; apparently the only 'unusual' thing at the horizon is a Schwarzschild coordinate ['fictitous'] singularity in time...so things appear to slow down from a stationary distant frame, but locally to a free falling observer things all seem 'normal' and no horizon can even be detected by such an soberver.
  • · Replies 16 ·
  • · Replies 51 ·
