How the Reynold number of 4000 consist of laminar flow?
The discussion centers around the conditions under which a fluid can exhibit laminar flow at a Reynolds number greater than 4000, particularly in the context of pipe flow. Participants explore theoretical and experimental perspectives on Reynolds numbers, transition to turbulence, and the influence of factors such as pipe smoothness and fluid characteristics.
  • One participant questions how a fluid can maintain laminar flow at a Reynolds number greater than 4000.
  • Another participant suggests that the flow type (pipe flow vs. open flow) significantly influences the transition Reynolds number, noting that open flows can remain laminar at much higher Reynolds numbers.
  • A participant proposes that a very smooth pipe with a large diameter might allow for higher transition Reynolds numbers, although this is debated.
  • It is noted that the typical transition Reynolds number for pipe flow is around 2300, with some arguing that it can be delayed with smoother walls, but 4000 is generally considered turbulent.
  • Several participants discuss the historical context of Reynolds' experiments, mentioning that laminar flow can be maintained at higher Reynolds numbers under specific conditions, referencing Reynolds' original observations.
  • One participant challenges the accuracy of historical claims about Reynolds' findings, emphasizing the need for clarity regarding the definitions and values associated with Reynolds number.
  • Another participant clarifies that the lower limit of Reynolds number for maintaining laminar flow is around 2300 for long pipes, suggesting that turbulence can eventually develop even at higher Reynolds numbers.
  • A participant expresses confusion about the concept of Reynolds number and requests additional resources for clarification.
Participants express differing views on the conditions under which laminar flow can be maintained at high Reynolds numbers. There is no consensus on the specific factors that influence this phenomenon, and the discussion remains unresolved regarding the implications of Reynolds' findings.
Participants reference historical experiments and theoretical frameworks, but there are uncertainties regarding the specific conditions and definitions used in these discussions. The relationship between Reynolds number, flow type, and transition conditions is complex and not fully resolved in the conversation.
Waqar Amin
I was asked a question that the Reynold number of a fluid is greater than 4000 but flow Is Still laminar. How is it possible? can anyone explain?.
Is this a pipe flow? If it is an open flow like over an airfoil then the Reynolds number based on downstream distance ([itex]\mathrm{Re}_x[/itex]) is typically in the millions before transition occurs. For pipe flow, the diameter Reynolds number ([itex]\mathrm{Re}_D[/itex])is usually closer to 2300 at transition. The only way I can think of for a pipe to have a higher transition Reynolds number is if it was perfectly smooth or they were using some unconventional length scale such as circumference.
Thanx boneh3ad :)
is this also possible for a smooth pipe having very large diameter?
For a pipe flow, the characteristic length is usually the diameter already so the transition Reynolds number is independent of diameter. That is the beauty of nondimensional numbers. I misspoke earlier; the actual typical onset of transition is around 2300. You can theoretically delay this as you make the wall smoother. However, 4000 is really pushing it since that is typically not even considered transitional but a fully turbulent area so you would really need some sort of perfectly smooth pipe.
what kind of fluid?
HengHY said:
what kind of fluid?
That doesn't matter as long as it is Newtonian and not rarefied.
Laminar at Re = 4 x103 ?
That's not very high even for pipes.
Reynolds' original experiments noted
"The transistion was sensitive to the entry conditions and with special precautions laminar flow is maintained at Re to beyond 2x104 at least for distances up to 100 pipe diameters"
An Experimental Investigation of Circumstances which Determine whether the motion of water shall be Direct or Sinuous..."
Phil. Trans. Roy. Soc. 1883
He also observed the lower limit of Re =2.3 x 103 for large distances down the pipe.
This figure reappears in the construction of the Moody diagram (you should look this up)
which implies a pipe friction factor of <0.012
for laminar flow at Re = 4 x 103
Proc. Roy.Soc. vol91, p46, 1915.
Where does it say that anywhere in Reynolds' paper? He didn't call it the Reynolds number, so I know for a fact that he didn't use "Re" in the paper anywhere. I have his paper in front of me and I don't see anywhere mention of specific values of the Reynolds number (which he refers to only as [itex]\frac{\rho c U}{\mu}[/itex]). Were you referring to a line in another paper that cites Reynolds original paper or am I just missing something?
Meanwhile, any fluid mechanics textbook covering pipe flow will tell you that pipe flows are usually doomed to become turbulent starting in the range [itex]2300\leq\mathrm{Re}_D\leq4000[/itex]. Of course laminar flow is maintained for some distance downstream because the pipe still has to go through the transition process, but the general rule is that depending on the pipe roughness, that is the range of [itex]\mathrm{Re}_D[/itex] you expect before the flow will eventually transition. On the low end of that range the pipe will transition quite far downstream.
This actually isn't in contradiction to what you just said about having laminar flow present as high as [itex]\mathrm{Re}_D = 2 \times 10^4[/itex] because all your quote says is that laminar flow is maintained at least up to 100 pipe diameters, implying that it does still eventually transition as predicted by the common rule of thumb. Pipe flow is perhaps the only flow that follows such a simple rule of thumb like this that we know of.
Sorry I should have made this more clear, this lower limit is the limit below which induced turbulent flow dies out if the pipe is long enough.
Thanx to all for helping me. :)
but I have confused now and i think my concept about reynolds number is very weak yet. can anyone post a link here which explain and elaborate the concept of reynold number very clearly beyond conventional statements and it dependence on different parameters and nature of materials.
  • · Replies 20 ·
  • · Replies 0 ·
