Find Tractive Force of 3000KN Weight Train in 1 min
The problem involves calculating the tractive force of a train weighing 3000 kN that accelerates from rest to a velocity of 54 km/h over one minute, while considering the frictional resistance of the track. Participants express confusion regarding the definition of "tractive force" and the calculations involved.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants attempt to calculate the tractive force using the mass and acceleration derived from the given data. Questions arise about the forces acting on the train, including weight, frictional resistance, and tractive force. Some participants suggest drawing free body diagrams to visualize the forces.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some guidance has been offered regarding the relationship between tractive force and resultant force, but there is no consensus on the correct approach to calculate the tractive force. Confusion remains about the frictional resistance calculation and its implications.
Participants note that the frictional resistance is specified as 5 N per kN of the train's weight, which raises questions about how to apply this information correctly in their calculations. There is also uncertainty regarding the definition of resultant force and its components.
manal950
Hi all
1 ) A train of 3000 KN weight starts from rest and reached a velocity of 54 km/h after one min . if the frictional resistance of the track is 5N/KN of the train's weight . Find the tractive force developed by the engine ?
I don't understand what is mean "tractive force " ??
anyway I start solve the question
w = 3000 kN
mass = 305810
u = 0
v = 54 km/h
v = u + at
a = 0.25
F = m X a
F = 305810 X 0.25
76452.5 N
manal950 said:
Hi all
w = 3000 kN
mass = 305810
u = 0
v = 54 km/h
v = u + at
a = 0.25
F = m X a
F = 305810 X 0.25
76452.5 N
Right a = 0.25 m/s2 (Always remember to put your units).
In the formula F=ma, a is the resultant acceleration of the mass m (Train in this case). So F is the resultant force.
If you draw a free body diagram, what are the forces on the train? (The tractive force is essentially the force generated by the train itself).
force on the train
1 weight
2 frictional resistance
3 tractive force
now How I can find the tractive force
I don't know where is the other helper ..
manal950 said:
force on the train
1 weight
3 tractive force
In which direction do these forces act?
How would you find the resultant horizontal force?
I don't know how to find resultant horizontal force?
anyway the direction for each one weight dawn , frictional resistance opposite of tractive force
Right so let's say frictional force is going left and the tractive force is going right. The train is moving to the right. How would you calculate the value of the force that the train is moving with from these two forces?
in other words, if we are in a tug of war competition and you are pulling with 10 N and I am pulling with 11 N, what would be the resultant force in this case?
Resultant force = tractive force - frictional force
Right!
So you calculated the resultant force in your first post. And they told you what the frictional force was. So you can rearrange to get the tractive force.
tractive force = Resultant force - frictional force
= 76452.5 - 3000
now this is correct ??
= 76452.5 - 3000
Check the signs in your equation.
76452.5 + 3000 ... ?
That should work.
= 76452.5 - 3000
Remember that the "tractive force", the force applied to the track by the locomotive, must be larger then the resultant force as it has to overcome the frictional force.
You can write it as "Resultant force- frictional force" if you remember to treat "frictional force" as negative.
now is my answer if fully correct ... ?
It should be.
my teacher said the answer is not correct
and he said why you don't multiply
5 X 3000
I don't know what he mean ?
and my other questions is the Resultant force
ma + tractive force
or only F = ma
5 X 3000
5 X 3000
unit is Kn or N
ma + tractive force
or only F = ma
  • · Replies 20 ·
  • · Replies 20 ·
  • · Replies 47 ·
