Understanding Contact Forces: Normal and Tangential Force Explained
  • Context: High School
  • Thread starter Thread starter luis20
    Force
The discussion revolves around the nature of contact forces, specifically normal and tangential forces, in the context of collisions and friction. Participants explore the definitions, relationships, and implications of these forces in various scenarios, including inclined planes and different types of collisions.
  • Some participants assert that the normal force is always perpendicular to the surface, while the frictional force is tangential and proportional to the normal force under certain conditions.
  • There is a discussion about whether all tangential forces are due to friction, with some arguing that other forces can have tangential components, such as gravity on an inclined plane.
  • Participants question the relevance of tangential forces in fast collisions, with some suggesting that they can be neglected depending on the context.
  • One participant highlights that tangential forces can influence momentum distribution in non-head-on collisions, particularly when friction is significant.
  • There is a debate about the conditions under which tangential forces are relevant, especially in collisions that produce torque.
  • Some participants discuss the implications of tangential forces on the motion of objects post-collision, including the effects of sliding versus rolling without slipping.
  • Concerns are raised about the accuracy of models that assume no sliding during collisions, with examples provided to illustrate different outcomes based on the nature of the collision.
Participants express differing views on the role and significance of tangential forces in various scenarios, indicating that multiple competing perspectives remain without a clear consensus.
Participants note that the treatment of tangential forces may vary based on the type of collision discussed, and there are unresolved questions regarding the assumptions made in different analytical models.
luis20
Hi. I have two questions
All contact forces are normal to the surface right? If there was no friction, there wouldn't be any tangential force?
Thanks
The normal force is indeed always normal to whatever surface you are talking about. The frictional force is tangential to that surface, and is proportional to the Normal force in elementary analysis.
Not quite. The maximum static friction force is proportional normal force. The actual tangential frictional force is anything up to that.
Thanks for the replies
What I want to know is if all tangential forces are due to friction.
In a fast collision, the tangential force can be neglected?
Not at all. Any kind of force may have a component tangent to the trajectory.
See for example motion on inclined plane. The gravity has a tangential component.
For what purpose?
The effect of tangential forces on the final momentum distribution may become important for collisions that are not "head-on". For example, throwing a ball towards a wall at an angle. If the ball-wall friction is large the tangential component of the momentum will decrease and the angle of "reflection" will be smaller than the angle of incidence.
See for example motion on inclined plane. The gravity has a tangential component.For what purpose?
What I meant was all tangential forces on a surface are due to friction. The tangential component of gravity will only affect the surface if there is friction. So I think my statement may be correct.
The thing you said about the ball is what I wanted to read. My teachers neglect the tangential component when we talk about collisions. Maybe that's because they are engineers.
Edit: But if you see collision articles, they talk only about the force which is normal to the contact surface! (tangential neglected) Collision is considered fast so the tangential force might be very little?
Well, what kind of collisions are discussed by your teachers? Are they head-on collisions?
I mean, is there a tangential component of the momentum of the colliding object(s) or not?
There is a tangential component. It's like your example of the ball.
Collisions which produce torque, where the normal force is not in the direction of the center of mass, those have tangential force for sure right?
It's not a question of whether the normal force passes through the centre of mass. The test is whether the relative motion of the points of contact immediately before collision is normal to the contact plane. Thus, a ball striking a flat surface at an angle will experience a tangential frictional force on impact unless it happened to be spinning in exactly the right way so that it made rolling contact instantaneously.
Also, I don't think one can argue that the contact is too brief for the tangential force to matter. The maximum tangential force is proportional, at each instant, to the actual normal force, just as in normal static arrangements, and the tangential and normal forces operate over the same brief time period.
If a ball radius R rebounds from a surface with speed V at θ to the normal, no sliding, I would think that the ball is now spinning at rate V sin(θ) / R.
This would be the case if the ball were to smoothly roll off the wall. That model is inaccurate in two ways.
1. The ball may slide across the wall instead of rolling without slippage. This would tend to apply in, for instance, the case of a steel ball hitting a steel wall at a glancing angle.
In the limit your spin rate omega(final) = omega(initial).
2. Rotational rebound.
In my youth we used to play with "super balls". These were hard rubber balls that rebounded pretty efficiently (90 to 95% restitution). They were also sticky enough that they would catch immediately and roll without slipping. If you threw one of these at the floor and got a good spin on it you could watch it go into a back and forth bouncing pattern with the direction of rotation reversing at each bounce.
In the limit your spin rate omega(final) = 2 V sin(θ) / R - omega(initial)
The spin rate resulting from any actual collision could be expected to lie somewhere in this range.
I did specify "if no sliding"
True - I did forget about that.
  • · Replies 35 ·
  • · Replies 32 ·
  • · Replies 20 ·
  • · Replies 60 ·
  • · Replies 33 ·
  • · Replies 18 ·
  • · Replies 51 ·
