Bell Spaceship Paradox: A and B's Viewpoint
  • Context: Graduate
  • Thread starter Thread starter mananvpanchal
    Bell Paradox Spaceship
The discussion revolves around the Bell Spaceship Paradox, focusing on the perspectives of two accelerating spaceships (A and B) and an outside observer (C). Participants explore the implications of constant acceleration, length contraction, and the relativity of simultaneity in different frames of reference.
  • Some participants argue that from the perspective of the outside observer (C), the distance between A and B remains constant, leading to confusion about how the string could break.
  • Others propose that length contraction affects the string, suggesting that the distance between the ships exceeds the contracted length of the string, resulting in it snapping.
  • A few participants emphasize the role of simultaneity, noting that events perceived as simultaneous in one frame may not be in another, complicating the understanding of the scenario.
  • Some contributions question the application of length contraction to "space" itself, debating whether it can be treated similarly to the string.
  • Participants discuss the implications of different frames of reference, with some asserting that the conditions for the string snapping are met in both the ships' frame and the launch frame.
There is no consensus among participants. Multiple competing views remain regarding the implications of length contraction and the relativity of simultaneity, leading to ongoing debate about the nature of the paradox.
Participants express uncertainty about the definitions and implications of length contraction, simultaneity, and the frames of reference involved. The discussion highlights the complexity of applying relativistic concepts to the scenario.
mananvpanchal
Hello,
Suppose, A and B spaceships are moving with constant acceleration. There is a string tied to spaceships center to center. A is on left of B and B is on right of A. C is outside observer.
As speed increase, A sees that B going further ahead, and B sees A going further behind. So, from ships PoV, string would be broken.
But, from C's PoV, distance between A and B remains constant.
So, I cannot understand, how string would be broken from C's PoV?
Thanks.
From C's PoV the string gets length-contracted. So the (constant) distance between A and B is greater than the (contracting) length of the string. Therefore the string snaps.
The only way that the length of the moving string could remain constant is if it were being stretched apart. (Consider length contraction.)
This--Bell's Spaceship paradox--has been discussed many, many times here. Do a search to find the relevant threads.
mananvpanchal said:
Hello,
Thanks.
Here is a very good explanation, complete with detailed math.
DaleSpam, Doc Al, GAsahi
The A and B starts simultaneously and continue with simultaneous constant acceleration in C's frame. But, not in spaceship's frame. The simultaneous changes of speed in C's frame remains spaceships at constant distance in C's frame. The distance remains equals for all journey even the distance is equal to the distance before journey.
From spaceships' frame, distance between them increased than distance before journey. Because, B starts and changes speed before A in spaceships' frame.
Length contraction cannot applied to only string. It can also apply to the space. If space between ships not contracted than how only string can?
It is impossible to understand what you are writing (at least, for me). Did you read the Analysis? Do you realize that there are two different frames (launcher vs. the frame comoving with the two rockets)? Do you realize that relativity of simultaneity plays a big role in solving the problem?
Because, as the problem statement says, IN THE FRAME OF THE LAUNCHER, the rockets accelerate in such a way that they KEEP THE DISTANCE BETWEEN THEM CONSTANT. Whereas the length of the string appears contracted due to Lorentz contraction.
Why do you think the space between the ships is not contracted?
The distance between the ships stays constant in the launch frame. But the atoms of the string are contracting in the launch frame. At some point they cannot span the constant distance anymore.
You can replace the string with a chain, and consider the individual chain links as rigid elements, which are all contracting as the chain accelerates:
Yes, I said that.
I have no idea what you are talking about. What is "space's" rest frame, and what is its length in that frame? To use the length contraction formula you have to have an object with a rest frame and a length in that rest frame. I don't know how you would apply that to "space".
Good point. Here's how I interpreted his statement about 'space' contracting: Imagine you have two ships traveling at high speed with respect to another observer (arranged as in the Bell set up, once the acceleration is completed). According to the ship frame, the distance between them is L. According to that other observer, the distance is L/γ.
If something happens to "space" then "elongation". Moving objects occupy less space then they do while at rest. This can be interpreted as:
a) Moving object is shorter than at rest (the usual interpretation)
b) Space is elongated for a moving object
Interpretation b) sounds a bit weird. But when you go into a rotating frame, rulers at rest measure a circumference greater than 2πr. You cannot claim that the rulers are contracted, because they are at rest. You must conclude that the space along the circumference is elongated.
A rotating frame is non inertial so rulers at rest can contract. You cannot simply apply the formulas for inertial frames.
Yes, that is reasonable. Then the condition for snapping is that the distance between the ships is greater than the length of the string. In the ships frame that condition is met because the length stays the same and the distance increases. In the launch frame that condition is met because the distance stays the same and the length contracts.
Right!
But it is not the length contraction from movement, because they are at rest. It is the apparent contraction that we get, when observing rulers resting further down in a gravitational field from a distance. This is however usually not interpreted as "contraction of the rulers", but rather "distortion of space".
Ok... Thanks guys.. for detailed explanation.
I usually recommend <http://arxiv.org/abs/0906.1919> for this.
  • · Replies 47 ·
  • · Replies 20 ·
  • · Replies 75 ·
  • · Replies 21 ·
  • · Replies 28 ·
  • · Replies 21 ·
  • · Replies 98 ·
10K
