| New Reply |
Transformer output voltage Vs turns ratio: HELP! |
Share Thread | Thread Tools |
| Jun23-12, 03:59 PM | #1 |
I just built a transformer to the specs of the original.
The transformer has a turns ratio of 1:16. Input to primary is 12V. The problem I am having is a very low voltage at the secondary side. The no load voltage was the highest (40V) that I have got out of it so far. The primary coil has a 200 Ohm resistor in series. I removed that to get more current to the primary but got the same results? Anyone here have any suggestions as to why I'm not getting the full secondary voltage? |
| Jun23-12, 05:25 PM | #2 |
If it gets hot then you could have a shorted turn.
How much current does the primary take when the secondary is open circuited. Is it possible that you have an enormous gap in the core? How does it perform with the primary and secondary reversed (using a low voltage source to feed the secondary). Why is there a 200 Ohm resistor in series with the primary? |
| Jun23-12, 05:58 PM | #3 |
Noe of the coils get hot, except the primary when I remove the resistor, then it gets too hot.
Primary current with secondary open is 45mA. There is a very small gap in the core (probably about .005"-.01") With the primary and secondary reversed (there are 3 secondary coils so I only connected to one) turns ratio is 5.4:1. I applied 12V to the secondary and with the primary open I get 400mV. When I short circuit the primary I get .5mA. |
| Jun23-12, 11:38 PM | #4 |
Are you using film insulated wire?
Try using a signal generator or function generator. Vary the frequency and see what you get. Are you using the same core material as the origional? Is there insulation over the core? Are you testing the transformer at the frequency the transformer was designed for? |
| Jun24-12, 05:58 AM | #5 |
Recognitions:
| Jun24-12, 06:23 AM | #6 |
| New Reply |
| Thread Tools | |
Similar Threads for: Transformer output voltage Vs turns ratio: HELP!
| Thread | Forum | Replies | ||
| Transformer - Calculating Output Voltage (AC Input Voltage) | Engineering, Comp Sci, & Technology Homework | 8 | ||
| Deciding no of turns on primary and secondary of tranformer given a voltage ratio? | Electrical Engineering | 8 | ||
| Transformer with bifilar wound primary (bifilar has higher voltage between turns)? | Electrical Engineering | 1 | ||
| constant output voltage from a variable output voltage source | Electrical Engineering | 3 | ||
| Transformer: Excitation Frequency and Turns Ratio | Electrical Engineering | 6 | ||
