Discovering the Shape of Spacetime from the Big Bang: A Scientific Exploration
  • Context: Graduate
  • Thread starter Thread starter AlbertE
    Shape Spacetime
The discussion revolves around the shape of spacetime as it relates to the Big Bang, focusing on the topological representation of the universe and the implications of galaxies moving away from each other. Participants explore various models and analogies to conceptualize this shape, while addressing misconceptions about the nature of the universe's expansion.
  • One participant suggests that the shape of the universe could be likened to various objects, such as a donut or a soccer ball, depending on how one interprets the topology of space.
  • Another participant argues that the shape of the universe is more accurately described as flat based on current evidence, and that the observable universe does not have a definitive outer edge.
  • Some participants clarify that the Big Bang did not occur at a single point in space, but rather at every point simultaneously, challenging the notion of a central origin.
  • There is a discussion about whether the universe is finite or infinite, with some suggesting that current observations are consistent with both possibilities.
  • One participant expresses a strong belief that the universe must have a finite size based on the timeline of the Big Bang, while others contest this view, stating that it is a misconception in modern cosmology.
  • Several participants engage in a thought experiment regarding the wrapping of galaxies in a cloth, with one noting the limitations of such an analogy given the universe's potential infinitude.
  • There is a debate over the interpretation of galaxies moving apart, with some asserting that this does not imply they were once all together in a single location, while others question the validity of this statement.
Participants do not reach a consensus on the shape of the universe or the implications of the Big Bang. Multiple competing views remain, particularly regarding the nature of the universe's expansion and the interpretation of its topology.
Participants highlight limitations in understanding the universe's shape due to the complexities of cosmological models and the nature of spacetime. There are unresolved assumptions about the implications of the Big Bang and the interpretation of observational data.
  • #121
bapowell said:
although not globally isotropic
as you say, and in addition this form of organization would require some justification because it does not comply with the minimal-sufficiency principle. To my knowledge n-spheres are the highest entropy shapes
Astronomy news on Phys.org
  • #122
Maybe, but the universe could still exhibit toroidal topology, and it satisfies your three criteria.
  • #123
OK, I forgot a fourth criterion: minimal sufficiency. In absence of possible verification, no weird proposal of universe shape can be formally rejected, raising the risk of degeneration of this subject. Hence, in an attempt to maintain some rigor in this field, a principle of minimal sufficiency should be observed by rejecting imaginative but supererogatory hypotheses.
I am not aware of data supporting torus
  • #124
There is no data supporting any global geometry/topology -- period. But, data does indicate a local universe consistent with flatness, which is evidence consistent with toroidal topology.
Could you articulate your minimal sufficiency principle?
EDIT: I'm not advocating for a toroidal universe, just pointing out that it's a perfectly viable possibility.
  • #125
it is simply making the effort to not introduce hypotheses that are not strictly riquired by new observations. Are you sure that the torus does not cumulate positive and negative curvatures? n-spheres are locally flat as well
(but I ackowledge that the torus is prettier for graphical representations)
  • #126
It has positive and negative principle curvatures, but the Gaussian curvature is zero.
They are not -- they are positively curved everywhere.
Right, but none of your criteria are strictly required by observations. We have no data supporting the size (finite vs. infinite) of the universe, whether it is globally compact or bounded, or whether it is globally homogeneous. What we know from observations of the observable universe is that it is approximately homogeneous and close to flat locally. Empirically, all three manifolds of constant curvature -- Euclidean (including toroidal and other flat geometries), spherical, and hyperbolic spaces -- are equally in the running.
  • #127
My feeling is that this curvature is more mathematical than concrete, but it is just a feeling
to faint to be mesurable. Sir Eddington calculated that for a small circle with a radius of 5 m with a mass of 5 tonnes at its center, one would deviate from pi only at the level of its 24th decimal..
I believed that night would not have been black in an infinite universe? (necessarily forever..)
  • #128
No, that was dealt with conclusively quite some time ago as not being the case. I don't have a reference offhand but I assure you it is true. It has to do with the expansion of the universe. For one thing, it is irrelevant whether the universe is infinite since the only light that reaches us is from the OBSERVABLE universe.
  • #129
OK thanks. The observable universe is the part for which the redshifted wavelengths remain in the visible range?
  • #130
In addition to phinds' response, I'll add that the finite age of the universe also resolves this paradox.
  • #131
something infinite has necessarily always been infinite. The finite age proves that the euclidean 3D space cannot be retained
  • #132
You are talking about infinite in space, which may or may not be true. The post you were commenting on was referring to the finite AGE of the universe.
  • #133
Technically, that is exactly correct. In practise, "visible" requires extraordinarily strong telescopes for a long period (see the Hubble Deep Field).
  • #134
By finite age, I mean finite time since the big bang. Obviously, if the big bang occurred 13 billion years ago, then there are still CMB photons, as well as starlight, that have simply not had time to reach us yet. This is why the finite age resolves the paradox. It has nothing to do with the size of the spatial geometry.
  • #135
OK I understand
  • #136
I asked this question because I read an other interpretation (with which I have some concerns) that the unobservable universe located behind the horizon, corresponds to galaxies for which the recession velocities exceed light speed. Is it erroneous according to you?
  • #137
Not only is it NOT erroneous, it is an understatement in that galaxies IN the observable universe are "now" ("now" gets a bit tricky) are already receding from us FTL. In fact, those at the edge of the OU are receding at about 3c
  • #138
I definitely cannot understand this point. My intuitive expectation was that the expansion rate cannot exceed c because it it was the case, everything would disconnect at once, even between the sun and Earth and between your eyes and your screen..
Did you read the problem of the ants on a rubber rope <http://en.wikipedia.org/wiki/Ant_on_a_rubber_rope>
  • #139
Did you read the problem of the ants on a rubber rope <http://en.wikipedia.org/wiki/Ant_on_a_rubber_rope>[/QUOTE]
The first thing you need to do when studying either cosmology or quantum mechanics it TOTALLY get rid of the concept that your intuition is worth squat. It is not. It's something we all have to get used to.
What you are not understanding is that nothing is traveling FTL in the same reference frame. The universe is expanding. The recession rate has nothing to do with c.
  • #140
The expansion is a rate, meaning that the recession velocity increases over distance. The further away something is the faster it recedes. So a galaxy can receded from us at 0.01c that is relatively nearby while another that is very very far away can recede at 2c or 3c or whatever. Note that this also includes light emitted from those galaxies. A galaxy receding from us at 2c that emits light away from us would NOT catch up to the light. In the galaxies frame of reference it is stationary and the light moves at 1c away from it.
  • #141
I know that v=H*D. If the Hubble constant was constant, this would lead to an exponential recession.
I understood how H is determined (through the variations of redshifts as fonction of distance). I also see how distances can be determined.
But I don't know how recession velocities are measured? do you knwo?
  • #142
There are no galaxies residing beyond the surface of last scattering whose photons have not yet reached us. Nothing but hot plasma exists beyond z~1100 [source of the cmb].
  • #143
Recession velocities are measured via redshift. Research the Doppler Effect to understand why Redshift comes about. We can determine which spectral emission lines we can expect to see in stars of certain materials (I can't remember how,) and see how redshifted the stars are. Plug into our easily derivable formula for the relativistic doppler effect, and we're done.
  • · Replies 28 ·
  • · Replies 45 ·
16K
  • · Replies 21 ·
