| New Reply |
Center of mass of half square without a half circle |
Share Thread | Thread Tools |
| Jun23-12, 08:17 AM | #1 |
1. The problem statement, all variables and given/known data
Find the position of the center of mass for a thin sheet and homogeneous, with sides R and 2R ,from which has been subtracted a half circle of radius R. ![]() [Xcm=(2/3)*R*(4-pi)] 2. Relevant equations Rcm=(1/M)*∫rdm 3. The attempt at a solution By simmetry we know Ycm=0. For de calculus of Xcm we rewrite the equation: Xcm=(1/Area)*∫xdA dA=dx*y; \[y=2\,R-2\,{\left( {R}^{2}-{x}^{2}\right) }^{0.5}\] For determinate the dA we take a Xcm=(1/A)*[itex]\int\2\,x\,R-2\,x\,{\left( {R}^{2}-{x}^{2}\right) }^{0.5}\[/itex] -R≤x≤R \[Xcm=\frac{{R}^{3}}{3\,A}\] \[A=\frac{4\,{R}^{2}-\pi\,{R}^{2}}{2}\] \[Xcm=\frac{6\,R}{4-\pi}\] I´ve been attempting in a lot of ways to solve the problem but i didn't get the result. This is an exercise from my exams in Physics I of 1º grade chemical engineering . PS: I don't know how to make the formulas visible in LaTex |
| Jun23-12, 09:47 AM | #2 |
The CM of rectangle R×2R=CM half circle + CM shaded area.
| Jun23-12, 09:56 AM | #3 |
You should use the guyndanh formula for sheet
| Jun23-12, 10:01 AM | #4 |
| Jun23-12, 10:02 AM | #5 |
Xcmrectangle= R/2 Xcmcircle= (4/(3*pi))*R Xcm=(R/2)-(4/(3*pi))*R=0.0755*R Correct answer: Xcm=(2/3)*R*(4-pi)=0.055*R |
| Jun23-12, 10:07 AM | #6 |
| Jun23-12, 10:11 AM | #7 |
| Jun23-12, 10:19 AM | #8 |
you should also consider the mass as proportional to area and not just subtract the x's.
| Jun23-12, 10:19 AM | #9 |
Require reference to x-axis |
| Jun23-12, 11:00 AM | #10 |
Okey, so the center of mass for the semicircle should be R-(4/(3*pi))*R?
Asr=Area of semirectangle, Asc=Area of semicircle. Then: Xcm=[Asr*(R/2)-Asc*( R-(4/(3*pi))*R)]/(Asr-Asc); Xcm=0.223*R;(I've reviewed my calculations) |
| Jun27-12, 09:21 AM | #11 |
Xcm=∫(R/2+√(R^2-X^2)/2)(R-√R^2-X^2)dX/∫(R-√R^2-X^2)dX
limits are from 0 to R OR from -R to R that does not matter because of symmetry.It gives that.verify this yourself. |
| Jun27-12, 10:02 AM | #12 |
And I tried to solve your equation with Maxima but i didn't get the result. |
| Jun28-12, 09:06 AM | #13 |
Hello SergioQE,
You can handle your question without appealing to calculus, provided you know : (1) Center of mass position of semicircle (removed part) and center mass of full rectangle. (2) The basic expression for center of mass. Now the semicircle and the truncated mass (shown figure) form such a system whose center of mass lies on the position of full figure.(use a suitable coordinate system).Please note that they have different masses so you need to be careful.As a matter of fact any calculus derivation of your problem employs the same method. Does this help? regards Yukoel |
| Jul3-12, 10:48 AM | #14 |
"Asr=Area of semirectangle, Asc=Area of semicircle. Then: Xcm=[Asr*(R/2)-Asc*( R-(4/(3*pi))*R)]/(Asr-Asc);" I've considered the different masses, taking lambda= Mass(sr)/Area(sr), and the same for the sc. And the result still wrong. I've used the coordinate system shown in the figure. Thanks for answer. PS: I add the final expression in LaTex for comfort : [itex]Xcm=[\frac{{R}^{3}-\frac{\pi\,{R}^{2}\,\left( R-\frac{4\,R}{3\,\pi}\right) }{2}}{2\,{R}^{2}-\frac{\pi\,{R}^{2}}{2}}][/itex] |
| Jul4-12, 08:18 AM | #15 |
Your expression sounds correct to me and so do your calculations.Your answer seems correct too. regards Yukoel |
| Jul4-12, 09:47 AM | #16 |
edit:4-∏ is in denominator. |
| Jul4-12, 10:20 AM | #17 |
You have used the inverted coordinate system I think(x=0 at the center of the semicircle).Your answer is correct with respect to that.SergioQE's value of x(cm) and your value add up to R if my calculations are correct .This shows that you have chosen the center as reference for x=0.Correct me if I am wrong. regards Yukoel |
| New Reply |
| Thread Tools | |
Similar Threads for: Center of mass of half square without a half circle
| Thread | Forum | Replies | ||
| Magnetic field at center of half square | General Physics | 2 | ||
| Equation of circle in quarter/half of a circle | Precalculus Mathematics Homework | 2 | ||
| Mass Moment of Inertia issues with half circle | Engineering, Comp Sci, & Technology Homework | 9 | ||
| Mass falling along half circle | Introductory Physics Homework | 6 | ||
| Center of mass of a half-ball | Calculus & Beyond Homework | 1 | ||
