roam
- 1,265
- 12
Suppose we have a spring with a spring constant of [itex]k[/itex]. And it is attached to a magnet (or electromagnet) as in the following diagram that I've made:
I was wondering if it is possible to write an equation for the magnitude of the magnetic field [itex]\vec{B}[/itex] required to compress the spring?
Suppose we want to compress the coil for a specific distance d. All we know is [itex]k[/itex] (or the stiffness of the spring).The red area in the diagram is the electromagnet that can produce a reasonably uniform field of any strength we choose.
P.S. I haven't tried this before experimentally, so I'm not sure if this arrangement actually works but I think if a permanent magnet is attached to the other side of the spring, the electromagnet would compress the spring much more easily. Here is the diagram:
I'm curious how we can determine the amount of [itex]\vec{B}[/itex] needed to compress the spring.
http://desmond.imageshack.us/Himg254/scaled.php?server=254&filename=springmagnet.jpg&res=landing
http://desmond.imageshack.us/Himg534/scaled.php?server=534&filename=permanentmagnet.jpg&res=landing
