| New Reply |
Fortran intrinsic functions source code |
Share Thread | Thread Tools |
| Jul8-12, 06:10 PM | #1 |
Hi
How can I see the source codes used for defining intrinsic functions in Fortran 90/95 ? e.g. what is the actual program for sqrt ? thanks |
| Jul8-12, 06:33 PM | #2 |
Recognitions:
The code is generated by the compiler. If the compiler has an option to output assembly code, you can look at the assembly code output by the compiler. Otherwise, you'll need to use a debugger using it's dissassembly mode in order to look at the generated code.
| Jul8-12, 06:50 PM | #3 |
Well I meant the programs written for intrinsic functions like sin and cos and sqrt. These programs are based on some mathematical algorithms. For example, sqrt might be exploiting some mathematical algorithm to find the square root. Somebody must have written these
programs long ago. How can I see it ? |
| Jul8-12, 08:34 PM | #4 |
Recognitions:
You should be able to see the library source code for open source compliers, for example http://www.g95.org/downloads.shtml
But don't expect the code will mean much, unless you already know a lot of numerical analysis. Start here: http://www.amazon.com/Elementary-Fun.../dp/0138220646 |
| Jul8-12, 11:39 PM | #5 |
Thanks Alephzero, I think even gfortran is open source too. Are their source codes open for download too ?
| Jul9-12, 07:16 AM | #6 |
Recognitions:
Well, if "open source" doesn't mean "the source is available", something's wrong somewhere
![]() FWIW gfortran was the first place I looked for a link but I couldn't find one (but my attention span looking for it was only about 30 seconds). |
| Jul9-12, 01:11 PM | #7 |
Recognitions:
| New Reply |
| Thread Tools | |
Similar Threads for: Fortran intrinsic functions source code
| Thread | Forum | Replies | ||
| FORTRAN- Same source code compiled with different compilers gives different output | Programming & Comp Sci | 6 | ||
| Fortran help: high precision intrinsic functions (kind = 16)...... | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Fortran - compilator dependent, intrinsic array manipulation, memory problem | Programming & Comp Sci | 1 | ||
| Convert latex code to fortran code? | Math & Science Software | 1 | ||
| Fortran 90 Intrinsic Function | Programming & Comp Sci | 0 | ||
