Thread Closed
How is molecular hydrogen detected?
Share Thread
Jul15-12, 09:59 AM   #86
Recognitions:
Gold Membership Gold Member
Quote by Bobbywhy View Post
Now I am a trained listener and a professional public speaker (Toastmasters International=28 years) but, unfortunately, I never could figure out what message you were trying to communicate in each of those four modules. Perhaps your written script could be revised to be more coherent and to clearly address the point you want to make. The point is I couldn't find the point.
I have made three more modules. Hopefully you will find these more coherent.
Secondary Explosion Explanation. In this module, I discuss why is it that I am multiplying 1 mile per hour times the age of the universe.
Reductio Ad Absurdam vs. Strawman: In this module I discuss the reasons why a kinematic model of the universe has been rejected. From what I have seen, they are all based on straw-man arguments posing as ruductio-ad-absurdam.
If I'm right, What do we have to "throw away" about what we know about gravity?: In this module, I discuss the particular reasonong which was addressed earlier in posts 45, 47, and 48, 53, 56, 54, in this thread. For your convenience, I am re-posting all the relevant parts of that argument below. You will notice that post 56 and 54 have been reversed, chronologically, in the tradition of the dialectic--in post 56 I had posted a hypothesis, that distant forces were observer dependent, and then later realized that twofishquant had already posted the contradiction to this hypothesis--that indeed the distant forces could, with bookkeeping, be found to be the same.
Quote by JDoolin View Post
Do you have some other reasoning, perhaps based on an application of Gauss's Law? I'm asking that because I'm pretty sure that I've seen such an argument made by none other than Einstein himself. However, I don't remember where I saw it; some book I've long since returned to the library (in frustration).
Ah, yes, thank you for that article. This was exactly the argument that I was thinking of. I've seen this argument in books, but I had never found it online. I was calling it "Gauss Law" but it is "Birkhoff's Theorem."
While I am essentially in agreement with Birkhoff's theorem, the article you reference is making a major error in its application, (and if I am not mistaken, Einstein made this same mistake, and was perhaps its originator.) If you are calculating the forces on particles A, B, C, and D, it is completely inappropriate for you to draw a circle around an arbitrary observer O, and then treat all of the mass in that circle as though it were a point mass at point O.
It would make much more sense to account for the masses near the objects A, B, C, D, respectively, to calculate the forces that are acting upon them.
(The other major error in the article is equation 2.3... Failure to apply time dilation and the relativity of simultaneity.)
Quote by twofish-quant View Post
Here's another way of thinking of it.....
I have point A. You can argue that all of the forces are balanced at point A, so it doesn't accelerate.
I have point B. You can argue that all of the forces are balanced at point B, so it doesn't accelerate.
AHA!!! You say, the universe must then be non-accelerating!!!!
But that doesn't work. If I start with point A as my origin, and then look at point B, I find that there is a force at point B pulling it toward point A. But wait, I just showed that the forces are balanced if I take point B as the origin? What gives?
The issue here is that the forces at point B when viewed from point A are *different* from the forces at point B when viewed from point B, because when you change coordinate systems then the forces change. But how can that be? Don't forces stay the same when you change between inertial coordinate systems?
Yes, but from point A's point of view, point B is not an inertial coordinate system, it's accelerating, and because it's accelerating, when you switch between point A and point B, the forces change. From point B's point of view, it's an inertial coordinate system, and A is accelerating. So when you switch between A and B, you have to change the forces to take into account the fact that the coordinate systems are non-inertial.
From A's point of view, there is a force on B pulling B toward A, and there is zero forces at A. Now when you switch to B's point of view, you are a non-inertial reference frame from A's point of view. To make it inertial, you have to subtract the forces that are acting on it. That causes the forces at B from B's point of view to go to zero, and then causes the A to go from zero force to the opposite of what was the force that A sees acting on B.
So if you take any point as the origin, you will see a force of zero for that point, but you will see non-zero forces for points other than the origin.
Now then you see how the universe works. We don't have any infinite clouds, but we have clouds that are "practically" infinite. You take something like the interstellar medium with a one light year cube, and then take a piece that is much, much smaller, and see how you calculate gravity.
Thank you for giving further explanation here.
I still think that ignoring the relativity of simultaneity is a flaw, but I also realize now that I was misunderstanding Einstein's argument.
He was literally saying that the force on a distant particle is an observer dependent quantity, while time is an observer independent quantity. That seems amazing to me, and I will have to think about it further.
And if you do your bookkeeping right, you come up with the same answer. The important thing is to keep track of what reference frame you are in so that you can account for non-inertial effects correctly.
I meant to ask, precisely what bookkeeping is done, so that you all get the same non-zero answer? I can agree that with correct bookkeeping, you should get the same answer, but by my calculation that answer should be zero. Because I don't believe that "correct bookkeeping" is represented by drawing a circle extending out to the radius of the object and stopping (as is done on page 2-3 here: http://www.ast.cam.ac.uk/~pettini/Ph.../lecture02.pdf) . I think the circle needs to be drawn to encompass a large volume around the object. At least, make the circle large enough to encompass the masses that are in the object's immediate vicinity.
With this sort of bookkeeping, all observers would, indeed, agree that the force on the object would be the same. But the "same value" that everyone would come up with, would be zero.
Jul15-12, 11:34 PM   #87
Thank you. But actually, I encourage you to question that! Don't take my word for it; go and actually read "Relativity, Gravitation, and World Structure," if you can find the time.
It's not so much a matter of reading books but rather doing the math.
Also, it *is* known that you can have homogenity rather than isotropy and isotropy without homogenity. Again, it's not a matter of reading books, but just thinking about the situation.
I'd like to understand why people argue with me over this.
I don't think that people are arguing with you over *this*. I think people are arguing with you over something else.
Mathematically, you can have an isotropic universe without homogenity, so what? Big deal.
The Milne model seems to be misrepresented everywhere I look
I don't think it's misrepresentation rather than "definition creep." When cosmologists talk about the Milne model they are talking about a situation in which galaxies move according to the velocities of Milne. Unless you are willing to throw away GR, the only way this can happen is if you have an empty universe.
It's not so much an effort to misrepresent Milne, but rather salvaging something.
Jul15-12, 11:44 PM   #88
The type of homogeneity assumed in the FLRW metric is an infinite homogeneous distribution of matter.
Right. But for FLRW to work you just need things to be bigger than the cosmic horizon. If things cut off at 100 billion light years, you get the same results.
But at those distances, 10, 20, 30 billion light-years, we possibly can't see anything as dim as a galaxy anyway.
Yes we can. This is a very simple calculation. Take the absolute brightness of a galaxy. Take the detection limit of our current telescopes. It's a very easy calculation to show that the drop off in galaxies that we see is *real* and not an observational effect.
It's not even close.
You need to be able to point at something that tells me clearly that there is no increase in density at the extreme periphery of the visible universe, and I have strong doubts that we have observations that are that good.
Again, you need to be able to do library research. I've been more patient than most people at "spoon feeding" you data (since this may be of interest to someone else), but at some point you have to be able to do your own library research. (Start with google and early galaxies and dark ages).
And yes, our observations *are* that good. Again, detection limits is something that you can do research on your own. It's a very simple calculation that you can do, and I'll leave it to you as an exercise to figure out how to do it.
Also from Milne's Model, there should be a directional difference in the distribution of galaxies. I would expect an asymmetry in the distribution of galaxies that fairly precisely matched the asymmetry in the dipole anisotropy of the CMBR.
We don't see this.
Now, if none of these expectations are happening, then perhaps we can reject Milne's model based on comparing hypotheses to data. But as long as Milne's model is being rejected because it is a zero-mass model, then we're not rejecting Milne's model. We're rejecting a straw-man.
No we aren't. For Milne to be consistent with GR you have to have zero mass. Therefore to accept Milne in the absence of matter, then you have to reject GR. Since we have good observational tests for GR, this is something that people aren't going to do lightly.
Jul15-12, 11:49 PM   #89
Once you have matter that is in an accelerating reference frame then the acceleration becomes a "fictious force".
If you have an closed sphere, then the masses that are outside the circle between the origin and the point are canceled out by the mass on the other size of the hollow region.
Yup, but if you are in a non-interial reference frame then zero force would = acceleration.
Jul16-12, 01:12 AM   #90
The younger universe means we should have less galaxies.
Once you get past z=8 or so, we see *NO* galaxies and *NO* stars.
Jul16-12, 01:24 AM   #91
I think that you still don't "get it."
On the northwest corner of 1st Avenue and 14th Street in New York City, there is fast food place that sells hot dogs. Now someone argues that there is a French restaurant there.
You cannot by any purely mathematical or philosophical argument refute that position.
It is perfectly mathematically and philosophically possible for there to be a French restaurant at the corner of 1st ave and 14th street. There is no logical contradiction for there to be a French restaurant at the NW corner of 1st and 14th. If you ask me to prove through logical arguments that there isn't a French restaurant there, I can't.
But there isn't. You can go to that location, and see that it's a hot dog joint. If you can't get a plane ticket to NYC, you can go onto google maps, and see that there isn't one there.
Same goes with cosmology. I cannot by pure mathematics or logic show that Milne is wrong. I can just look a the sky and show that he is wrong about how the universe is set up, and most of those measurements were taken decades after Milne was around.
Also, the point of theory is to tell the observers what to look for. You are asserting (incorrectly) that we can't see distant galaxies because our telescopes aren't good enough. Now even if that were true, then the question should be "how good do our telescopes have to be?"
One of the points that I'm trying to make here is that cosmology is not philosophy. It's grounded in observations in much the same way that oceanography is.
Jul16-12, 02:55 AM   #92
Recognitions:
My apologies for refering to you as James, Jonathan. I perceive your error as one of philosophy, not science - e.g., I agree with twofish. Cosmology is a conjecture founded on observation. While I agree cosmology is still largely a matter of conjecture, it is a conjecture based on observational evidence. Once you leave the realm of observational evidence you enter the realm of metaphysics.
Jul16-12, 08:16 AM   #93
Golly, this thread has gone off topic. I was going to say that the Fermi telescope has good things to say about molecular hydrogen (not always well traced by CO), but I have a feeling a new topic would be better...
Jul16-12, 10:49 PM   #94
Quote by Chronos View Post
And this is a serious, serious philosophical problem when you deal with things like multiverses, pre-event zero, and the anthropic principle stuff.
However, once you get past the very, very early universe, you don't have to worry about these issues.
One problem with the way that cosmology is presented to the general public is that there is so much focus on the "this is *WEIRD* and *SPOOKY* stuff" that people aren't aware that most of cosmology isn't different from oceanography or planetary science, and observing the big bang isn't any different from observing the moon. We know the moon is there because we can see it. We know the big bang happened because we see that too. In some ways, we know more about the formation of the universe than we do about the formation of the moon.
Jul17-12, 11:55 AM   #95
Recognitions:
There IS an error of philosophy here, but I don't think it is mine.
The problem is that you are doing philosophy rather than physics. You are treating isotropy and homogenity as if they were mathematical axioms when they aren't.
If homogeneity is NOT a mathematical axiom, then it should not be possible to make a mathematical argument with it as your premise.
Once you start with the premise that the universe is isotropic and homogenous, then at large distances things are going to be flying away from each other at > c, and Lorenz transformation will break down.
The issue here is that your cosmology professor actually IS using the idea of an infinite homogeneous universe as an axiom. He then uses that axiom to draw logical consequences. He then uses those logical consequences to throw out the idea of Special Relativity applied at large scales.
Jul17-12, 12:14 PM   #96
Mentor
I have closed this thread. There have been several pages of violations of Physics Forums Rules, which I explicitly posted earlier in this thread (post #26).
Thread Closed
Similar discussions for: How is molecular hydrogen detected?
Thread Forum Replies
Formation of molecular hydrogen in HI clouds Advanced Physics Homework 0
Atomic and Molecular Hydrogen Chemistry 3
heat enthalpy of molecular hydrogen Advanced Physics Homework 0
hydrogen molecular ion Quantum Physics 2
