| New Reply |
Variational Operator/First Variation - Taylor Expansion |
Share Thread | Thread Tools |
| Jul16-12, 12:21 PM | #1 |
1. The problem statement, all variables and given/known data
Folks, how is the following expansion obtained for the following function ##F(x,u,u')## where x is the independent variable. The change ##\epsilon v## in ##u## where ##\epsilon## is a constant and ##v## is a function is called the variation of ##u## and denoted by ##\delta u \equiv \epsilon v## 2. Relevant equations 3. The attempt at a solution ##\Delta F=F(x,u+\epsilon v, u'+\epsilon v')-F(x,u,u')##. Expanding in powers of ##\epsilon## (treating ##u+\epsilon v## and ##u'+\epsilon v'## as dependent functions) ##\displaystyle \Delta F= F(x,u,u')+ \epsilon v \frac {\partial F}{\partial u}+ \epsilon v' \frac{\partial F}{\partial u'}+ \frac{(\epsilon v)^2}{2!} \frac{\partial^2 F}{\partial u^2}+\frac{(\epsilon v)(\epsilon v')}{2!} \frac{\partial^2 F}{\partial u \partial u'}+\frac{(\epsilon v')^2}{2!} \frac{\partial^2 F}{\partial u'^2}+....-F(x,u,u')## How is the above line obtained...I looked at Taylor expansion but could not recognize its application to this function. Any links or tips will be appreciated. Regards |
| Jul16-12, 01:22 PM | #2 |
It's basically Taylor expansion on functions of several variables.
On the other hand, the Euler-Lagrangian equation can be derived by not using Taylor expansion which may be more straightforward to some readers(using partial derivative and total differential). |
| Jul16-12, 03:46 PM | #3 |
| Jul16-12, 05:30 PM | #4 |
Variational Operator/First Variation - Taylor Expansion1) I am not sure why the author threw in the ##F(x,u,u')## at the end to balance the first term in last equation of original post...? 2) The book continues on from this last equation to write ##\displaystyle \epsilon v \frac{\partial F}{\partial u}+\epsilon v' \frac{\partial F}{\partial u'} +\epsilon R_1(\epsilon)## Does ##\epsilon R_1(\epsilon)## represent the higher order terms that can be neglected since they are small? This approaches 0 as ##\epsilon## approaches 0. |
| Jul16-12, 07:23 PM | #5 |
f(x)=f(a)+f'(a)(x-a)+0.5f''(a)(x-a)2+o(x-2). Ignoring 2nd and higher order terms, we have f(x)=f(a)+f'(a)(x-a). It says f changed from f(a) to f(x) due to independent valuable changed from a to x, where f(a) is the initial point, f(x) is the final point, and (x-a) is the change in the independent variable. Hence the net change Δf = f(x)-f(a)=f(a)+f'(a)(x-a)-f(a) |
| Jul19-12, 05:26 AM | #6 |
| New Reply |
| Thread Tools | |
Similar Threads for: Variational Operator/First Variation - Taylor Expansion
| Thread | Forum | Replies | ||
| Variational operator | Calculus & Beyond Homework | 5 | ||
| Variation of the metric's determinant [General Relativity, Variational Calculus] | Advanced Physics Homework | 7 | ||
| Need some help with variational calculus: First variation | Calculus | 0 | ||
| Taylor's Expansion | Calculus | 3 | ||
| entropy variation during free expansion | Introductory Physics Homework | 0 | ||
