What Happens to Higgs-Bosons Without Conservation of Mass?
The discussion revolves around the implications of the conservation of mass (or lack thereof) on Higgs bosons, exploring whether they are destroyed or decay into other particles. The conversation touches on theoretical aspects of particle physics, conservation laws, and the nature of mass and energy.
  • Some participants question the conservation of mass and its implications for Higgs bosons, suggesting they may be destroyed or decay.
  • Others assert that there is a conservation of mass, arguing that mass is conserved in processes like electron-positron annihilation, where mass is converted to energy but not lost.
  • Some participants clarify that the Higgs boson is a virtual particle when mediating its field, which complicates the discussion of decay.
  • There are claims that photons, despite having no rest mass, contribute to gravitational effects, indicating a distinction between mass and energy conservation.
  • Several participants express differing views on whether mass conservation holds in all scenarios, with references to energy-mass interconversion.
  • One participant emphasizes that the principle of conservation of mass is only approximately true in classical physics, while energy conservation is more universally applicable.
Participants do not reach a consensus on the conservation of mass versus energy, with multiple competing views remaining on the topic. The discussion reflects significant disagreement regarding the definitions and implications of mass and energy conservation.
Limitations in the discussion include varying definitions of mass and energy, assumptions about particle behavior, and the complexity of virtual particles versus real particles in decay processes.
SneakyG
If there is not a conservation of mass, then what happens to higgs-bosons? Are they destroyed, or decay into something else (if that is even possible...)?
There is a conservation of mass, so I don't understand what you are asking.
Also, the higgs boson, when mediating it's field, does so as a virtual particle, not a real one, so there are no decays.
Higgs bosons are extremely short-lived (~10-26 sec) and decay in many different ways. For example, h → γ + γ or h → Z0 + Z0. Z0's of course immediately decay also, perhaps into μ+ + μ-. These decay patterns are how Higgs events are identified.
EDIT: The Higgs lifetime depends on what mass it has. For the observed mass around 125 GeV the lifetime is closer to 10-23 sec
Is there a conservation of mass at all ? I thought the conservation is for energy.
Conservation of mass IS conservation of energy. The best example I can think of is in electron-positron annihilation that produces 2 gamma ray photons. The rest mass of both particles is converted into energy and radiated away. The mass is not gone however, as any system that includes those photons still has the exact same mass, it has simply moved.
I doubt that can be called a conservation of mass, it has the same energy converted from mass-energy into photons. But photon's mass are 0
There is not a conservation of mass, but there is for energy.
Yes, that is why conservation of mass IS conservation of energy. The reverse is also true in the case of two photons producing an electron-positron pair.
Drakkith said:
I'm not sure I see your point. This is exactly what I've been saying.
no it is not. I get what you are trying to say, but it is not right to say that.
If there was a conservation of mass, then if you measure the mass of the universe at anytime it will always show the same exact number.
But that is not the case, because of the Electron-Positron example. If a pair annihilated and then you measure the mass of the universe, it will show a different number
new mass = previous mass - (electron + positron)
but does that mean that the mass disappear ? No, and that is your point, they are transformed into other form of energy. But just because they have the ability to form the previous masses again and return to the old number, doesn't make the mass value always constant.
But when talking about Conservation of energy, in the annihilation, the energy of the photons didn't pop out of nothing. They were stored in Mass-energy (E = mc^2), and then got transformed into photons. So the energy (including mass-energy) value always stays constant when measured at anytime.
To answer SneakyG's question, it is what Bill_k said, It decays.
No, this is 100% wrong. IF we could measure the mass of the universe, it would be exactly the same before AND after the annihilation of the electron-positron. Energy has mass and it is conserved.
If what you say is true, then Photons are massive, and they shouldn't move at c
Photons have no REST mass. They have energy and they do, in fact, contribute to gravitation.
As an example, if you take a box made out of perfect mirrors and put light in it, it will have MORE mass than an identical box with no light in it.
This is exactly why Conservation of energy holds while Conservation of mass doesn't
The principle of matter conservation may be considered as an approximate physical law that is true only in the classical sense ... when particles that are considered to be "matter" (such as electrons and positrons) are annihilated to make photons (which are often not considered matter) then conservation of matter does not take place, even in isolated systems.
http://en.wikipedia.org/wiki/Conservation_of_mass
It was found that particles that have rest mass, and those that do not, are subject to interconversions. There can occur creation and annihilation of (ponderable) matter particles, and imponderable non-matter particles. Matter is then not conserved. Matter particles (such as electrons) can be converted to non-matter (such as photons), or even into potential or kinetic energy.
http://en.wikipedia.org/wiki/Conservation_of_energy
If you are talking about Mass-Energy, or the Energy content in mass, then I would agree.
but the mass is not conserved.
According to GR, it is the energy (Mass-energy included) that contributes to Gravitation, so Photons are included because they have energy not mass.
Montadhar, you objections are pointless. Both mass and energy are fully conserved in any case. I'm sorry I lack the ability to explain it well enough.
I think the OP got the answer of his question, there is no need to extend the off-topic discussion any more.
I believe it is obvious that we meant different things when each of us mentioned the term 'Mass'.
