Maxwell's Equation: Magnetic B Field from Moving Charges
  • Context: Graduate
  • Thread starter Thread starter martin f
A moving electric charge consistently generates a magnetic field, as established by the Biot-Savart Law. This law provides the mathematical framework for calculating the magnetic field produced by point charges in motion, particularly in a vacuum. When the velocity of the charge is significantly less than the speed of light (v² ≪ c²), Maxwell's equations can be utilized to approximate the electric and magnetic fields. The derivation of these equations is attributed to Oliver Heaviside in 1888, highlighting their historical significance in electromagnetism.
  • Understanding of Maxwell's equations
  • Familiarity with the Biot-Savart Law
  • Knowledge of electric charge and magnetic field concepts
  • Basic principles of classical electromagnetism
  • Study the derivation of the Biot-Savart Law for point charges
  • Explore Maxwell's equations in detail
  • Investigate the implications of moving charges on electromagnetic fields
  • Learn about the historical context and contributions of Oliver Heaviside
Students of physics, electrical engineers, and researchers in electromagnetism will benefit from this discussion, particularly those interested in the behavior of magnetic fields generated by moving charges.
martin f
Under what circumstances does a moving electric charge fail to produce a magnetic field?and what is the equation for finding the magnetic B field produced by multiple charges moving in a vacuum?
A moving electric charge always generates a magnetic field. The Laws of Biot and Savart describe how the magnetic field is generated by the electric charge. Although the expressions for this law often are written in terms of electric current, there are expressions appropriate for point charges.
Here is a link that may help.
http://en.wikipedia.org/wiki/Biot–Savart_law
“In the case of a point charged particle q moving at a constant velocity v, then Maxwell's equations give the following expression for the electric field and magnetic field:[
<connect to link to see the equations in reference>
When v2 ≪ c2, the electric field and magnetic field can be approximated as
These equations are called the "Biot–Savart law for a point charge"[6] due to its closely analogous form to the "standard" Biot–Savart law given previously. These equations were first derived by Oliver Heaviside in 1888.
  • · Replies 17 ·
