New Reply
Stationary sound waves problem
Share Thread
Jul29-12, 10:32 AM   #1
1. The problem statement, all variables and given/known data
A car is driven at 30m/s between two sources, each producing sound waves of 1.50x10^6 Hz. The sound heard by driver rises and fades as he travels from one sound source to the other. Find the period of regular fading.
2. Relevant equations
No relevant equations provided.
3. The attempt at a solution
Since the sound rise and fades along the line connecting the two sources, I believe a standing wave has been formed, where the two end points are open ends. I figure that in one second, the car moves 30m and the waves make 1.50x10^6 cycles, so the wavelength (which is the distance covered in one cycle) must equal 2x10^-5 m (or λ=v/f). Since fading takes place at every node, that is λ/2, distance between adjacent nodes = 0.00001 m. how do I translate
that into time interval between successive nodes? The answer given is 3.3 seconds.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Jul29-12, 10:56 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Hi, Simplyjack. Are you sure the frequency that you gave is correct? I don't think even batman could hear that high of a frequency.
I suspect this is a problem where you are meant to use the concepts of the "Doppler effect" and "beats". Are those things that you've studied?
Jul29-12, 11:10 AM   #3
Recognitions:
Actually, your approach to the problem will yield the correct answer. You just need to find the time for the traveler to go from one node to the next. You know the distance (λ/2). So, how much time does it take the car to move this distance?
I still think the frequency given in the problem is strange. Also, the answer of 3.3 s seems odd. For such a high frequency, I would expect the answer to be of the order of microseconds.
Jul29-12, 11:16 AM   #4
Recognitions:
Quote by Simplyjack View Post
In the expression λ = v/f, v is not the speed of the car. What speed is it?
Jul30-12, 11:03 AM   #5
Hi TSny,
Thanks for your comments. I got this question from a friend but as i did not copy it word for word, I did not remember correctly and misinterpreted the problem. I think it's not sound waves but rather radio waves, hence the high frequency. Therefore I can use v = 3.0x10^8 m/s and f = 1.50x10^6 Hz and obtain λ as 200m.
Since distance between successive nodes = λ/2 = 100m, and car velocity is 30m/s, I can equate 30 to 100/T, giving T to be 3.33 s. But Im not sure if driver will still be able to "hear" the rise and fall of such high frequencies.
Thanks for helping me to solve my own problem.
Simplyjack
New Reply
Similar discussions for: Stationary sound waves problem
Thread Forum Replies
How does stationary sound waves in open tubes happen? Advanced Physics Homework 5
How are stationary waves produced in an air column different from normal Waves? Advanced Physics Homework 0
stationary waves energy problem Classical Physics 5
Sound Waves Problem Introductory Physics Homework 2
Sound waves problem Introductory Physics Homework 15
