| New Reply |
how exctly the higgs field originted after the big bang? |
Share Thread |
| Jul21-12, 02:32 PM | #1 |
i know that they are trying to recreate the higgs boson at CERN LHC, but talking about when the big bang happened, how was the higgs field suppose to happen?
| Jul22-12, 11:54 PM | #2 |
I was under the impression that the higgs field always existed, and it was only once the energy levels of the universe were reduced below a certain point that things acquired mass.
| Jul31-12, 07:17 PM | #3 |
Phase Transitions in the Early Universe - Electroweak and QCD Transitions
The Higgs-particle field has a potential energy that's shaped like a bowl with a hump in the middle. When the temperature is high enough to make Higgs particles (T >~ mH ~ 125 GeV), then the resulting Higgs-field fluctuations compensate for that central hump, and above about 300 GeV, make it disappear altogether. That means that the Higgs field stops having a nonzero average value at about then, ending the low-energy Higgs mechanism. [hep-ph/9702324] Finite temperature effects on the neutrino decoupling in the early Universe - thermal fluctuations create effective masses for every particle, with mass values about (interaction strength) * T. |
| Aug1-12, 08:48 AM | #4 |
The descriptions I've seen are similar to the prior post.
My understanding is the Higgs field[s] are associated with particular types of vacuums. I have never heard it proposed that before the big bang there existed a Higgs field[s] everywhere. Such a Higgs mechanism |
| Aug1-12, 09:06 AM | #5 |
I think the Higgs field[s] is a manual input to inflation....and the standard model of particle physics.....just like the inflation which originated with Guth is a manual input...a mathematical tool used to solve some issues and produce some observational predictions...
I also checked several sections of Wikipeida...via "Higgs mechanism" and ended up here: But if they describe the origin of the field I missed it: They say the Higgs boson is a tachyon...but not faster than light.... edit: here is a related discussion: http://www.physicsforums.com/showthread.php?t=621236 and I am reminded from it that the Higgs field is associated with a non zero expectation vacuum...hence I believe that suggests the Higgs field did NOT exist before the BB....maybe an 'expert' will clarify for us. |
| Aug1-12, 12:17 PM | #6 |
The field that makes inflation is sometimes called the inflaton (no i), and it's like a spin-0 one.
However, the inflaton cannot be the Higgs particle, because of the great difference in energy scales: Higgs: ~ 300 GeV inflaton: ~ 1015 GeV |
| New Reply |
Similar discussions for: how exctly the higgs field originted after the big bang?
| Thread | Forum | Replies | ||
| Did a Higgs Boson trigger the big bang? | Cosmology | 6 | ||
| Higgs Field, Big Bang, and Spacetime | Cosmology | 7 | ||
| Higgs field & Big Bang | High Energy, Nuclear, Particle Physics | 1 | ||
| Gravity as a Goldstone-Higgs field, instead of a Gauge Field | General Physics | 0 | ||
| the Higgs field: so gravitational field by itself cannot confer mass? | High Energy, Nuclear, Particle Physics | 4 | ||
