What type of digital signaling is more efficient, digital DC or digital AC?
The discussion revolves around the efficiency of digital signaling methods, specifically comparing digital DC and digital AC. Participants explore various aspects of efficiency, including complexity, error rates, energy consumption, and data rates, while also considering the implications of fluctuating DC signals.
  • Some participants suggest that without additional context, digital DC and digital AC may be considered equally efficient.
  • Others inquire about the definition of "efficient," proposing various criteria such as complexity of electronics, error rates, energy usage, and data rates.
  • One participant argues that DC logic devices are typically unipolar, which may affect complexity and error rates.
  • Another participant notes that if the difference between 1-level and 0-level is the same for AC and DC, their error immunity should also be similar.
  • Concerns are raised about DC's inability to pass through capacitors or transformers, which may be significant in certain applications.
  • A participant introduces the concept of fluctuating DC, questioning its behavior with capacitors and transformers compared to constant DC.
  • Discussion includes the idea that fluctuating DC may allow for energy discharge in capacitors, raising questions about its transmission characteristics.
  • One participant mentions that efficient signaling often relies more on coding algorithms than on the choice between AC or DC.
  • Historical context is provided regarding voltage levels used in older computing systems and modern interfaces like USB and RS-232.
  • A question is posed about the randomness of phase angles in sampled AC signals if the sampling rate does not match the AC frequency.
Participants express differing views on the efficiency of digital DC versus digital AC, with no consensus reached on which method is superior. Several criteria for efficiency are discussed, but opinions vary on their relevance and impact.
Limitations include the lack of a clear definition of efficiency, dependence on specific applications, and unresolved questions regarding the behavior of fluctuating DC in relation to capacitors and transformers.
Bararontok
With digital DC, the square-wave signal is only between a (+) value and 0.
With digital AC, the square-wave signal is between a (+) & (-) value.
Computer science news on Phys.org
The thread originator is requesting an answer to the question.
Without more context to the question, the answer is that they are the same.
Can you define efficient?
Which digital signalling method listed in post #1:
-Uses electronics that is less complex and prone to malfunction
-Is less error prone
-Uses less electrical energy
-Can operate at higher data rates
DC - Most logic devices are unipolar.
One measure of immunity from errors involves the amount of difference between a 1-level and a 0-level. If the difference between the levels for AC and DC transmission is the same, the immunity from errors should be the same.
I'm assuming you mean uses less electrical energy for the same bit error rate. I'm not sure there's a difference.
I can't think of any reason there would be a difference. In my experience more efficient signalling methods involve more efficient coding algorithms rather than relying on AC or DC.
DC has the disadvantage of not being able to pass through capacitors or transformers. This may be important if bandpass filters are used to reduce noise.
What if the DC is a fluctuating DC? A constant DC cannot pass through a capacitor in series because once the capacitor is fully charged, it can no longer permit current flow, but in a fluctuating DC, the capacitor has time to discharge its stored energy when the power is cut off.
In the case of a transformer, is a fluctuation in current enough for the primary inductor to emit radiation that can be absorbed by the secondary transformer or is a reversal of polarity necessary?
With both capacitors and transformers the fluctuation of the DC, which will include both data and noise, will pass through, but the DC bias will not. At that point we can no longer call it a DC transmission method.
That is correct since the DC bias comes from a constant DC power supply while the fluctuating DC signal is a separate component.
If the orignal post means digital signals used in common integrated circuits, then most logic just uses some positive voltage and zero voltage for the two states. Decades ago, computers like the HP 2100 mini-computer used +5, -2 volts for it's TTL logic on it's circuit boards.
Interfaces like USB send synchrounous (fixed clock rate) data via a differential pair of signals, +D and -D, where -D is an inversion of +D, each with a 3 volt range. There are also ground and +5 volt pins, which the host drives to send power to some USB devices. Wiki article:
http://en.wikipedia.org/wiki/Usb
Interfaces like RS-232 can range from +/- 3 volts to +/- 15 volts, and for the original PC, +/- 12 volts was used for RS-232. There is a ground pin used as a reference for 0 volts. Wik article:
http://en.wikipedia.org/wiki/RS_232
Won't the "phase angles" of a sampled A/C become random unless your sample rate is matched to the A/C frequency?
  • · Replies 41 ·
11K
  • · Replies 48 ·
