Why Is the Transition Region Between Slopes of -1 Significant in Inverters?
The discussion centers around the significance of the transition region between slopes of -1 in inverters, particularly focusing on digital inverters. Participants explore the implications of this slope in the context of transfer functions and power dissipation during the transition between logic states.
  • Some participants inquire about the significance of the transition region with a slope of -1 in the context of digital inverters.
  • Others clarify that the digital inverter is highly non-linear, with an average gain of -1, but a much larger incremental gain during transitions between logic states.
  • A participant notes that the transition region's slope can significantly affect logic output, with a steep slope indicating a clearer logic state.
  • Concerns are raised about power dissipation in the transition region, which can be much higher compared to fully ON or OFF states.
  • One participant mentions that the choice of the transition region is somewhat arbitrary but necessary for comparing results across different technologies.
  • It is noted that modern deep submicron technology results in a peak slope that is typically less than -10, contributing to increased power dissipation.
Participants express varying views on the significance of the transition region and its implications for logic states and power dissipation. There is no consensus on a definitive interpretation of the slope's importance.
Some assumptions about the behavior of digital inverters and the implications of slope in the transition region remain unresolved. The discussion highlights the complexity of the topic without reaching a unified conclusion.
prusaga
Regarding the transfer function of the inverter,why do we take the transition region between the slopes of '-1'.Is there any special significance for this slope in this context of inverter.
Thank you all
Are you talking about a digital inverter (a NOT gate), or an analog inverter (e.g., op-amp)? :confused:
An analog inverter has a gain, Vo/Vin = -1, but only while not being overdriven into distortion.
Oh don't mind me,I was talking about the Digital Inverter. Thank You
The digital inverter is very non-linear. It may have an average gain of -1 over the full range of input/output voltages, but during the transition from logic 0 to logic 1 (or visa-verse) the incremental gain magnitude will typically be larger value.
For the NOT gate, this narrow linear region has a |Vo/Vin| slope of much greater than 1. What you might be thinking of is that some families of gates allow their simpler inverting gates to serve as crude op-amps, so if you equip such a gate with a feedback resistor and an equal-value input resistor you produce an inverting amplifier of small-signal gain equal to -1.
So can we say that,the slope in the transition region tends to increase at a very high rate which makes it,not probable to get the logic.What if the transition region has not a very steep slope?
The output in that region of operation is neither logic HIGH nor LOW. This may or may not be important to any application. It also means for most families of logic gates that the gate in that transition region is dissipating many times (possibly x100) more power than when fully ON or fully OFF.
Thank you all
To answer you original question, we take the transition region to be between the two points where the gain is -1 as a convention. It's arbitrary. It's still important, though, because only by agreeing on that can we compare results of different technology.
And the slope (or "gain") of a digital inverter is not really that steep in modern deep submicron technology. The peak slope is typically less than -10 nowadays. This is one reason power dissipation is increasing in scaled CMOS technologies.
In old logic (like you would see in a 7400 series chip) the gain was MUCH larger.
  • · Replies 53 ·
