Kinematics: Defining an Absolute Frame of Reference
The discussion revolves around the definition of an absolute frame of reference in the context of kinematics. Participants explore how a reference frame can be defined without relying on other frames, and the implications of such definitions in both kinematics and dynamics.
  • Some participants propose that an inertial frame of reference can be defined as one that does not involve pseudo or inertial forces.
  • Others argue that defining a reference frame absolutely requires an initial point of measurement, which inherently introduces a reference frame.
  • A participant references David J. Griffiths' insights, suggesting that the principle of relativity complicates the identification of a "rest" frame, as laws of physics apply equally in uniformly moving frames.
  • One participant emphasizes that kinematics involves space and time, while dynamics relates to inertia and matter, suggesting a distinction between the two fields.
  • Another participant asserts that a frame of reference is a set of values assigned to variables within a system, and that dynamics and kinematics are fundamentally linked through motion.
  • Concerns are raised about the relationship between rotation and inertia, with a participant suggesting that rotation does not inherently involve inertia.
  • One participant expresses the need for assurance that a set of points is not rotating to accept it as a frame of reference, highlighting the role of inertial forces in detecting rotation.
Participants do not reach a consensus on the definition of an absolute frame of reference. Multiple competing views remain regarding the relationship between kinematics and dynamics, the role of inertia, and the implications of defining reference frames.
Participants highlight the complexity of defining reference frames without introducing assumptions or other frames, indicating potential limitations in their arguments.
mani
Under "Dynamics", an Inertial frame of Reference can be defined absolutely as one that does not use "pseudo" or inertial forces.
Under "Kinematics" how do we define absolutely (any) "Frame of Referaece"?
"Reference Frame"
How is a "Reference Frame" defined absolutely (i.e. without introducing another Frame) under Kinematics ?
Er... the moment you say "I'm going to measure the position of everything with respect to this point here", then you have defined a reference frame. An "inertial reference frame" will have a more stringent constraint than that.
Zz.
David J. Griffiths offers some insights in his Introduction to Electrodynamics
Page 477:
Classical Mechanics obeys the principle of relativity: the same laws apply in any inertial reference frame. By "inertial", I mean that the system is at rest or moving with constant velocity. 1
1. This raises an awkward problem. If the laws of physics hold just as well in a uniformly moving frame, then we have no way of identifying the "rest" frame in the first place, and hence no way of checking that some other frame is moving at constant velocity. To avoid this trap, we define an inertial frame formally as one in which Newton's first law holds. If you want to know whether you're in an inertial frame, throw some rocks around -- if they move in straight lines at a constant speed, you've got yourself an inertial frame, and any frame moving at constant velocity with respect to you will be another inertial frame.
I don't see how it makes a difference whether you are working with kinematics or dynamics; both are just aspects of classical mechanics, in which this definition applies.
Okay...that's really not cool! Don't double post man! :mad: I posted a reply here:
https://www.physicsforums.com/showthread.php?t=55114
then I see a duplicate thread with the exact same question.
"I don't see how it makes a difference whether you are working with kinematics or dynamics;"
Kinematics is "Space" (or Geometry) + Time; where we can talk about moving "points"only.
Inertia is a concept that comes with matter under Dynamics.
Rotation can be detected only with inertia.
frame
As I understand it a 'frame of reference' is not dependent on the system considered per se, it is a set of values given to any and all variables within the system at some initial condition , and hence a referential situation.
To me dynamic and kinematic are the same thing involving motion , they may or may not involve rotation , which is a dimension , not included in inertial frames .
You must define carefully which variables you include or not -- then apply values to them as a reference 'point' ( multidimensional ).
To reply to whoever -- rotation has nothing to do with inertia -- inertia in the rotational sense is clearly due to momentum but momentum is the resistance to change in whatever direction in space. Rotation of zero mass does not involve momentum , it could be just the frame of reference ..
Ray.
That was a bit above my head!
In kinematics, i can take a "rigid" set of points as a Frame, if someone can assure me that it is not rotating but moving only translation. If any other set of points is moving only in translation w.r.t. the above "certified" frame, that also can be accepted as a frame.
Absolute rotation of only a material frame can be detected by the inertial forces
  • · Replies 94 ·
  • · Replies 88 ·
  • · Replies 18 ·
  • · Replies 54 ·
  • · Replies 25 ·
