New Reply
is it possible to connect two hydraulic jacks?
Share Thread Thread Tools
Aug8-12, 03:18 AM   #1
it is possible to connect two hydraulic jacks together? i want to lift an inclined board using two hydraulic jacks at both ends of the board. is there a way that i can connect two hydraulic jacks together so that when i pump one of the jacks, the other is also being pumped. Any ideas how to lift the inclined board will also be helpful. thanks.
Hydraulic pump 1---------Hydraulic pump 2
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Aug8-12, 03:20 AM   #2
Aug8-12, 03:22 AM   #3
Aug8-12, 03:47 AM   #4
Why not split the fluid feed into two, i.e. connect them in parrallel. You will have no control over them separately though.
Aug8-12, 05:14 AM   #5
I've manifolded jacks together many times, lifting as much as 800 tons.
But they will all see the same pressure. This can be a problem if they do not also see the same load. So install a shut off valve in front of each jack to control the fluid going to that jack individually.
Aug8-12, 05:53 AM   #6
Recognitions:
Homework Helper Homework Help
Well... you could hook them all to the same pump.
However - there are simpler ways: look up "hydraulic lift table" or just look at the hydraulic platforms at the back of trucks.
Aug8-12, 03:53 PM   #7
Mentor
Quote by tomallan View Post
Multiple posting the same question across PF forums is against the rules here (and you have been previously warned about this). Check your PMs.
I have merged the 3 threads into this one.
New Reply
Tags
hydraulic pump, hydraulics, physics
Thread Tools
Similar Threads for: is it possible to connect two hydraulic jacks?
Thread Forum Replies
Hydraulic lift problem - hot hydraulic fluid Mechanical Engineering 1
hydraulic jacks Mechanical Engineering 1
May connect MySQL or Access in Force's Fortran77? If not, what database may connect i Academic Guidance 0
Its Jacks Birthday General Discussion 10
