Electric susceptibility of a gas/solid for the same kind of atoms
The electric susceptibility of a solid formed from a gas of the same atoms is generally decreased compared to the gas phase. This conclusion arises from the relationship defined by the susceptibility formula χ = N/V * α, where N/V represents the average particle density and α is the atomic polarizability. While the particle density increases in the solid state, the local field effects from neighboring atoms reduce the overall susceptibility. Thus, the presence of these interactions in solids leads to a lower susceptibility than that observed in the gas phase.
  • Understanding of electric susceptibility and its mathematical representation
  • Knowledge of atomic polarizability and its implications in different phases
  • Familiarity with the concepts of local fields in solid-state physics
  • Basic principles of phase transitions from gas to solid
  • Research the effects of local fields on electric susceptibility in solids
  • Study the relationship between atomic polarizability and phase changes
  • Explore experimental methods for measuring electric susceptibility in different phases
  • Investigate the role of particle density in determining material properties
Students and researchers in physics, particularly those focused on solid-state physics, material science, and the study of electric properties of materials.
vst98
For the same kind of atoms, if a solid is formed from a gas, is the susceptibility increased or decreased compared to the gas phase ?
Why ?
Susceptibility of a gas is given as
χ=N/V * α
where N/V is average particle density and α is the atomic polarizability.
At first sight, since N/V would increase with solid formation the susceptibility would also increase.
But I doubt that this is a plausible answer.
Is there anyone here who simply knows is the electric susceptibility of
a gas smaller or larger compared to solid for the same kind of substance/atoms ?
Are there some experimental physicist here ? It does not have to be an explanation.
I know that when solid forms we will have a field acting on individual atoms coming from neighboring atoms. Then the sum of applied external field and the field coming from the neighboring atoms gives the resulting local field. But I'm not sure is this local field related to increase/decreased of susceptibility in a solid.
I would appreciate if someone would just share his thoughts on this.
  • · Replies 27 ·
