| New Reply |
Efficiently computing the parity of the Hamming weight of a binary sequence |
Share Thread |
| Aug11-12, 02:04 AM | #1 |
Hello,
I'm wondering if there are any tricks to quickly determine the parity of the weight of a binary number, i.e., whether it's even or odd. I'm not interested at all in the actual weight of the number, but in the parity of it. I know that if say x = a XOR b, then x has odd weight iff exactly one of a, b, has odd weight. But would you have come across a good algorithm for this problem before? The web seems full of the actual Hamming weight problem, but haven't noticed anything special about this other case. Thanks a lot guys. |
| Aug11-12, 04:02 AM | #2 |
Hey burritoloco.
Have you come across error correcting codes? Hamming actually wrote a book on these and deals with the construction of error correcting codes where not only can you detect errors, but you can even correct some of them depending on how the code is constructed. You can construct these with matrices where sums are considered sums modulo 2 instead of just normal sums. The different kinds of codes are constructed based on a lot of Venn diagrams. You can construct different codes to correct specific kinds of errors, but the general thing is that you need to add more bits to correct more errors. Notice that you will be representing a lot more than your minimum data. |
| Aug11-12, 05:41 AM | #3 |
Recognitions:
For example, my (Pascal) code for "word" parity would be something like: Code:
var a : word;
ah,al : byte;
parity : byte;
p_look : array[0..15] of byte = (0,1,1,0,1,0,0,1,1,0,0,1,0,1,1,0);
begin
a := $E234; {word to test}
ah := hi(a); al := lo(a);
parity := p_look[ah shr 4] xor p_look[ah and $0f] xor
p_look[al shr 4] xor p_look[al and $0f];
writeln(parity); {parity is "1" for the given test word}
end.
| Aug11-12, 12:02 PM | #4 |
Recognitions:
If your PC is relatively new, it's processor may have the "popcnt" instruction, which returns the number of 1 bits in a value. For Visual Studio 2010 C/C++, this can be accessed using the intrinsic function _popcnt().
http://msdn.microsoft.com/en-us/library/bb385231.aspx Odd parity would just be an odd count of bits. To do this in Visual Studio 2010 C: Code:
#include <intrin.h>
parity = _popcnt(a ^ b) & 0x01;
Otherwise, just use a table as suggested by uart. |
| Aug11-12, 03:04 PM | #5 |
Thanks guys.
Chiro, I took a class on Finite Fields and Coding theory over a year ago. I'm currently doing some work over GF(2) and bits are all over ;). Thanks uart, but I think that maybe your method might be exponential in time. Given an N-bit word and a look-up table of weight parities of n-bit words, you seem to be XORing 2^{N-n} words to get the result. rcgldr, thanks for the comment; you already had me informed of popcnt in another post of mine ;). It would be real unfortunate if one would have to count all the '1's in a sequence just to know its parity. Just another quick question: What are the time complexities of the bitwise arithmetical operations, OR, XOR, &, shifts. Thanks again everyone. |
| Aug11-12, 03:16 PM | #6 |
uart, you are also using 2^(N-n) arithmetical operations to slice the N-bit word into 2^(N-n) n-bit words...
| Aug11-12, 03:18 PM | #7 |
Don't know about you guys, but something in my gut tells me that there should be a quicker way to get the parity of the weight that doesn't involve computing its actual weight.
| Aug11-12, 06:50 PM | #8 |
Recognitions:
http://en.wikipedia.org/wiki/Hamming_weight |
| Aug12-12, 01:51 AM | #9 |
Recognitions:
![]() Of course you can make it one lookup plus one xor per 8 bits if you don't mind making the lookup table bigger. |
| Aug13-12, 01:14 PM | #10 |
Your method is great when N is bounded above (usually by 64 these days). Unfortunately, I'm dealing with arbitrarily large integers; maybe I should have said that earlier ;). p.s. pocnt and __builtin_popcount are so fast it's unbelievable. In my computer, these two give the weights of all integers from 1 to 2^61 - 1 in about 0 seconds! BTW, GCC also has the __builtin_parity function included; visual studio probably has one as well. |
| Aug14-12, 01:14 AM | #11 |
Recognitions:
| Aug14-12, 10:52 AM | #12 |
Recognitions:
I wonder if, in the case that this is just a benchmark and the results aren't being stored or used in anywhere, if some optimizing compiler is not optimizing your code right out of existence? |
| Aug17-12, 09:44 AM | #13 |
rcgldr, interesting. Are you sure they aren't using look-up tables?
| Aug17-12, 12:06 PM | #14 |
Recognitions:
No matter which way you look at it you're going to need at least 4 machine language instructions per iteration. Now lets say your computer is really good, say it runs at 10GHz and can unroll the loop and do 100 instructions in parallel per clock cycle! It would still take over 100 years to complete your code! Do the maths, (4*2^61) / (100*10^10) / (3600 * 24) = 106.75
| Aug17-12, 12:54 PM | #15 |
Recognitions:
| Aug17-12, 01:23 PM | #16 |
Recognitions:
It's late at night here.Anyway, still a very long time compared with "0 seconds".
| Aug17-12, 04:52 PM | #17 |
long m = (1L << 63) - 1; for(long i=0; i < m; i++) { __builtin_popcountl(i); } Even worse, I then measured in milliseconds, and... again, 0 ms. I then removed the -O2 option in the build; same time. My laptop is an Acer 5736Z, Pentium(R) Dual-Core CPU T4500 @ 2.30GHz × 2, x64, not a super-computer. Have you tried a similar experiment by yourself? I would love to output the assembly code if anyone would show me how? |
| New Reply |
Similar discussions for: Efficiently computing the parity of the Hamming weight of a binary sequence
| Thread | Forum | Replies | ||
| [C++] Efficiently counting the number of '1' bits inside blocks of a binary number | Programming & Comp Sci | 4 | ||
| reduce the sequence..or how to calculate it efficiently | General Math | 1 | ||
| Algorithm for computing conjugacy classes in subgroups of the GL(n,F_p) efficiently | Calculus & Beyond Homework | 0 | ||
| Hamming Code, Parity Matrix | Linear & Abstract Algebra | 0 | ||
| Show the following properties of Hamming weight... | Calculus & Beyond Homework | 3 | ||
